Results 1 to 6 of 6
Thread: Teensy 4.0 how to persist data, how to connect serial
    Jan 2020
    10
    I'm quite new to the Teensy world, running a 4.0 and the audio shield. I realize many things are different from the chips I'm used to use (Microchip, MSP, XMC4000 etc), so many things I could not answer by crawling the forum - so please help.
    First, I need to store some configuration data - less than a 100Byte - and wondered if theres is any built-in capability? Like EEPROM, SerialFlash (btw, how to access the on-board W25Q16-chip?) Not sure if I really need to spend an SD card for this.
    Second, I'm looking for an 3.3V adaptor to RS232. I used to smash an x232-IC on a board when needed, but they are all 5V. Any suggestions?
    Looking at the many interesting pins on the bottom side of the board, I wonder how those are supposed to get attached to the circuitry. Solder? Pogo-pins? if so, are there any recommendations?
    21,303
    Quote Originally Posted by McTime View Post
    Yes, using the EEPROM library. In Arduino click File > Examples > EEPROM to get started.
    The top 64K of the flash memory is used to emulate 1080 bytes of EEPROM, so you'll be using about 10% of the possible storage.
    Jan 2020
    10
    Ok, thats good news. Thanks!
    Jan 2020
    10
    Damn! My Teensy seems to be dead. I happened to make a short between the 5V and GND pins briefly (my fault of course) while measuring. USB-port immediately shut off power.
    Pressing the PROG-Button seems to bring back the Bootloader- red LED lights up and shows repetitive low flickers.
    Any idea, or time to go shopping a new one?
    Jan 2020
    10
    Hmm, pulled the Teensy out of the pin headers, back in - back to life! Some self-healing fuses? At least I'm happy for now.
    Germany NRW
    6,202
    Yes, a self healing fuse.
