Results 1 to 4 of 4
Thread: AudioAnalyzeFFT1024 two instances doesn't work
    Jan 2020
    10
    I would like to play with two FFTs, but as soon as I add the second one none of them will work, that is, available() is always false on both.
    Any chance to get this working?
    Note: Uncomment the commented lines and the problem should be visible.
    // design with https://www.pjrc.com/teensy/gui/
    AudioInputI2S            i2s1;           //xy=160,109
    AudioOutputI2S           i2s2;           //xy=482,51
    //AudioAnalyzeFFT1024      fft1024a;       //xy=488,165
    AudioAnalyzeFFT1024      fft1024b;       //xy=488,205
    //AudioConnection          patchCord1(i2s1, 0, fft1024a, 0);
    AudioConnection          patchCord2(i2s1, 0, i2s2, 0);
    AudioConnection          patchCord3(i2s1, 1, fft1024b, 0);
    AudioConnection          patchCord4(i2s1, 1, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=176,209
      AudioMemory(12);
      sgtl5000_1.enable();
      sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
      Serial.println("Rdy");
    /*   if (fft1024a.available()) {
         Serial.println("A");
       if (fft1024b.available()) {
         Serial.println("B");
    Feb 2017
    399
    Maybe reserve more AudioMemory?
    Jan 2020
    10
    Thanks, AudioMemory(16); did it.
    1,318
    Each instance of fft1024 requires 8 audio memory blocks to hold the samples for the FFT. Just to be safe, I would allocate a bit more than 8*number_of_FFT1024.
    But 16 works. Go for it
    Pete
