I wanted to build 'Notes and Volts' TS-1 which was originally designed for the Teensy 3.2.
See: https://www.youtube.com/watch?v=Inwbu9DgVeU&t=7s
As the Teensy 4 was available, it seemed a better choice, so I ordered one with its corresponding audio adapter. I had to change the TS-1 connections slightly to accommodate the changes between Teensy 3.2 and 4.0, and altered the sketch to correspond. Fortunately Teensyduino 1.49 was released just as I was about to load the sketch, so the Midi port option was there (I've since updated to Teensyduino 1.50 in case of a software issue). As speed isn't an issue, I'm running it at 150MHz.
Once it was basically connected up, it worked after fixing a couple of errors. I then fixed everything in place and screwed the bottom of the box on, feeling very confident and pleased with myself; even leaving a comment on the N&V Youtube page. Unfortunately, it's never worked since.
Here is the sketch:
It uses a 6N138 as a MIDI In opto-isolator and a 74HC4067 as a multiplexer. There is a circuit diagram in the YT presentation.
I have of course checked all of my connections and solder joints in case anything was dislodged during the final installation. I have also removed the Teensy from the circuit and soldered it back in again, but it refuses to work. I loaded a test sketch which runs an audio sweep, and that runs fine, so the audio adapter seems OK. In case there was a problem with the MIDI input, I tried running it via the USB from my PC, but it didn't respond.
I have checked with an oscilloscope and found that the MIDI data is going into the Rx pin (I've tried RX1 and RX4). But when I put the 'scope on the Mux pins (address or output), there was nothing, which makes me think that the Teensy has stopped.
I hope that I've provided enough information.
Here is the sketch:
// Teensy-Synth Part 10
// Hardware Controls
// By Notes and Volts
// www.notesandvolts.com
// Requires 'MIDI Library by Forty Seven Effects'
// Install in Arduino IDE using 'Sketch/Include Library/Manage Libraries'
// Tools menu Settings:
// Board: "Teensy4.0"
// USB Type: "MIDI"
//#include <SD.h>
#include <MIDI.h>
//Mux Pins
#define MS0 5 //A3 for RX1
#define MS1 A0 //A6 for Teensy 3.2/3.1
#define MS2 9 //8 for Teensy 3.2/3.1
#define MS3 A8 //A7 for Teensy 3.2/3.1
#define MZ A3 //A2 for RX1
#define MnumControls 15
#define MUXosc1 5
#define MUXosc2 6
#define MUXdetune 7
#define MUXmix1 9
#define MUXmix2 10
#define MUXmix3 11
#define MUXattack 3
#define MUXdecay 4
#define MUXsustain 2
#define MUXrelease 1
#define MUXlfospeed 0
#define MUXlfodepth 14
#define MUXlfomode 8
#define MUXfilterres 12
#define MUXfilterfreq 13
//Switch pin numbers
#define numSwitch 3
#define SWosc1 2
#define SWosc2 3
#define SWlfo 4
//MIDI CC control numbers
#define CCmixer1 100
#define CCmixer2 101
#define CCmixer3 102
#define CCoctave 103
#define CCattack 104
#define CCdecay 105
#define CCsustain 106
#define CCrelease 107
#define CCosc1 108
#define CCosc2 109
#define CCdetune 110
#define CCfilterfreq 111
#define CCfilterres 112
#define CCbendrange 113
#define CClfospeed 114
#define CClfodepth 115
#define CClfomode 116
AudioSynthWaveform waveform2; //xy=382,453
AudioSynthWaveform waveform1; //xy=386,394
AudioSynthNoisePink pink1; //xy=394,504
AudioMixer4 mixer1; //xy=577,454
AudioFilterStateVariable filter1; //xy=725,457
AudioEffectEnvelope envelope1; //xy=888,458
AudioOutputI2S i2s1; //xy=1049,465
AudioConnection patchCord1(waveform2, 0, mixer1, 1);
AudioConnection patchCord2(waveform1, 0, mixer1, 0);
AudioConnection patchCord3(pink1, 0, mixer1, 2);
AudioConnection patchCord4(mixer1, 0, filter1, 0);
AudioConnection patchCord5(filter1, 0, envelope1, 0);
AudioConnection patchCord6(envelope1, 0, i2s1, 0);
AudioConnection patchCord7(envelope1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=565,556
// GLOBAL VARIABLES
const byte BUFFER = 8; //Size of keyboard buffer
const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
byte globalNote = 0;
byte globalVelocity = 0;
int octave1 = 0;
int octave2 = 0;
const float DIV127 = (1.0 / 127.0);
float detuneFactor = 1;
float bendFactor = 1;
int bendRange = 12;
unsigned int LFOspeed = 2000;
float LFOpitch = 1;
float LFOdepth = 0;
byte LFOmodeSelect = 0;
int FILfreq = 10000;
float FILfactor = 1;
byte osc1Mode = 255; // 255 = Nonsense value to force startup read
byte osc2Mode = 255;
MIDI_CREATE_INSTANCE(HardwareSerial, Serial4, MIDI); //changed to RX4 in case RX1 is faulty
AudioMemory(20);
pinMode(SWosc1, INPUT_PULLUP);
pinMode(SWosc2, INPUT_PULLUP);
pinMode(SWlfo, INPUT_PULLUP);
pinMode(MS0, OUTPUT);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(MS3, OUTPUT);
MIDI.begin();
MIDI.setHandleNoteOn(myNoteOn);
MIDI.setHandleNoteOff(myNoteOff);
MIDI.setHandlePitchBend(myPitchBend);
MIDI.setHandleControlChange(myControlChange);
usbMIDI.setHandleControlChange(myControlChange);
usbMIDI.setHandleNoteOff(myNoteOff);
usbMIDI.setHandleNoteOn(myNoteOn);
usbMIDI.setHandlePitchChange(myPitchBend);
sgtl5000_1.enable();
sgtl5000_1.volume(0.32);
waveform1.begin(WAVEFORM_SAWTOOTH);
waveform1.amplitude(0.75);
waveform1.frequency(82.41);
waveform1.pulseWidth(0.15);
waveform2.begin(WAVEFORM_SAWTOOTH);
waveform2.amplitude(0.75);
waveform2.frequency(123);
waveform2.pulseWidth(0.15);
pink1.amplitude(1.0);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 0.0);
envelope1.attack(0);
envelope1.decay(0);
envelope1.sustain(1);
envelope1.release(500);
usbMIDI.read();
MIDI.read();
LFOupdate(false, LFOmodeSelect, FILfactor, LFOdepth);
checkMux();
void myNoteOn(byte channel, byte note, byte velocity) {
if ( note > 23 && note < 108 ) {
globalNote = note;
globalVelocity = velocity;
keyBuff(note, true);
LFOupdate(true, LFOmodeSelect, FILfactor, LFOdepth);
void myNoteOff(byte channel, byte note, byte velocity) {
keyBuff(note, false);
void myPitchBend(byte channel, int bend) {
float bendF = bend;
bendF = bendF / 8192;
bendF = bendF * bendRange;
bendF = bendF / 12;
bendFactor = pow(2, bendF);
oscSet();
void keyBuff(byte note, bool playNote) {
static byte buff[BUFFER];
static byte buffSize = 0;
// Add Note
if (playNote == true && (buffSize < BUFFER) ) {
oscPlay(note);
buff[buffSize] = note;
buffSize++;
return;
// Remove Note
else if (playNote == false && buffSize != 0) {
for (byte found = 0; found < buffSize; found++) {
if (buff[found] == note) {
for (byte gap = found; gap < (buffSize - 1); gap++) {
buff[gap] = buff[gap + 1];
buffSize--;
buff[buffSize] = 255;
if (buffSize != 0) {
oscPlay(buff[buffSize - 1]);
return;
else {
oscStop();
return;
void oscPlay(byte note) {
waveform1.frequency(noteFreqs[note + octave1] * bendFactor * LFOpitch);
waveform2.frequency(noteFreqs[note + octave2] * detuneFactor * bendFactor * LFOpitch);
float velo = 0.75 * (globalVelocity * DIV127);//TEST velocity limit to 0.75
waveform1.amplitude(velo);
waveform2.amplitude(velo);
pink1.amplitude(velo);
//envelope1.releaseNoteOn(5);//TEST
envelope1.noteOn();
void oscStop() {
envelope1.noteOff();
void oscSet() {
waveform1.frequency(noteFreqs[globalNote + octave1] * bendFactor * LFOpitch);
waveform2.frequency(noteFreqs[globalNote + octave2] * detuneFactor * bendFactor * LFOpitch);
void myControlChange(byte channel, byte control, byte value) {
switch (control) {
case CCmixer1:
mixer1.gain(0, 0.3 * (value * DIV127)); //TEST gain limit to 0.3
case CCmixer2:
mixer1.gain(1, 0.3 * (value * DIV127));
case CCmixer3:
mixer1.gain(2, 0.3 * (value * DIV127));
case CCoctave:
switch (value) {
case 0:
octave2 = 24;
case 1:
octave2 = 12;
case 2:
octave2 = 0;
case 3:
octave2 = -12;
case 4:
octave2 = -24;
oscSet();
case CCattack:
envelope1.attack((3000 * (value * DIV127)) + 10.5);//TEST Attack min limit to 10.5ms
case CCdecay:
envelope1.decay(3000 * (value * DIV127));
case CCsustain:
envelope1.sustain(value * DIV127);
case CCrelease:
envelope1.release(3000 * (value * DIV127));
case CCosc1:
switch (value) {
case 0:
osc1Mode = 0;
case 1:
waveform1.begin(WAVEFORM_TRIANGLE);
osc1Mode = 1;
case 2:
osc1Mode = 2;
case 3:
waveform1.begin(WAVEFORM_PULSE);
osc1Mode = 3;
case CCosc2:
switch (value) {
case 0:
waveform2.begin(WAVEFORM_SINE);
osc2Mode = 0;
case 1:
waveform2.begin(WAVEFORM_TRIANGLE);
osc2Mode = 1;
case 2:
osc2Mode = 2;
case 3:
waveform2.begin(WAVEFORM_PULSE);
osc2Mode = 3;
case CCdetune:
detuneFactor = 1 - (0.05 * (value * DIV127));
oscSet();
case CCfilterfreq:
FILfactor = value * DIV127;
FILfreq = 10000 * (value * DIV127);
if (LFOmodeSelect < 1 || LFOmodeSelect > 5)filter1.frequency(FILfreq);
case CCfilterres:
filter1.resonance((4.3 * (value * DIV127)) + 0.7);
case CCbendrange:
if (value <= 12 && value > 0) {
bendRange = value;
case CClfospeed:
float xSpeed = value * DIV127;
xSpeed = pow(100, (xSpeed - 1));
LFOspeed = (70000 * xSpeed);
case CClfodepth:
LFOdepth = value * DIV127;
case CClfomode:
LFOmodeSelect = value;
void LFOupdate(bool retrig, byte mode, float FILtop, float FILbottom) {
static float LFO = 0;
static unsigned long LFOtime = 0;
static bool LFOdirection = false;
unsigned long currentMicros = micros();
static bool LFOstop = false;
static float LFOrange = 0;
static byte oldMode = 0;
static bool retriggered = false;
if (retrig == true) retriggered = true;
if (currentMicros - LFOtime >= LFOspeed) {
LFOtime = currentMicros;
if (mode != oldMode) {
if (mode == 0 || mode == 8) {
LFOpitch = 1;
oscSet();
else if (mode >= 1 || mode <= 7) {
LFOpitch = 1;
oscSet();
else if (mode >= 9 || mode <= 13) {
oldMode = mode;
LFOrange = FILtop - FILbottom;
if (LFOrange < 0) LFOrange = 0;
// LFO Modes
switch (mode) {
case 0: //Filter OFF
return;
case 1: //Filter FREE
filter1.frequency(10000 * ((LFOrange * LFO) + LFOdepth));
case 2: //Filter DOWN
if (retriggered == true) {
LFOdirection = true;
LFO = 1.0;
case 3: //Filter UP
LFO = 0;
case 4: //Filter 1-DN
LFOstop = false;
LFO = 1.0;
if (LFOstop == false) filter1.frequency(10000 * ((LFOrange * LFO) + LFOdepth));
case 5: //Filter 1-UP
LFOstop = false;
LFO = 0;
case 8: //Pitch OFF
return;
case 9: //Pitch FREE
LFOpitch = (LFO * LFOdepth) + 1;
oscSet();
case 10: //Pitch DOWN
LFO = 1.0;
oscSet();
case 11: //Pitch UP
LFO = 0;
oscSet();
case 12: //Pitch 1-DN
LFOstop = false;
LFO = 1.0;
if (LFOstop == false) {
oscSet();
case 13: //Pitch 1-UP
LFOstop = false;
LFO = 0;
oscSet();
// Update LFO
if (LFOdirection == false) { //UP
LFO = (LFO + 0.01);
if (LFO >= 1) {
LFOstop = true;
if (LFOdirection == true) { //Down
LFO = (LFO - 0.01);
if (LFO <= 0) {
LFOstop = true;
void checkMux() {
static byte muxInput = 0;
static int muxValues[MnumControls] = {};
if (currentMicros - LFOtime >= 1000) {
int muxRead = analogRead(MZ);
if (muxRead > (muxValues[muxInput] + 7) || muxRead < (muxValues[muxInput] - 7)) {
muxValues[muxInput] = muxRead;
muxRead = (muxRead >> 3); //Change range to 0-127
switch (muxInput) {
case MUXosc1:
muxRead = muxRead / 32;
if (muxRead != osc1Mode) myControlChange(0, CCosc1, muxRead);
case MUXosc2:
if (muxRead != osc2Mode) myControlChange(0, CCosc2, muxRead);
case MUXdetune:
myControlChange(0, CCdetune, muxRead);
case MUXmix1:
myControlChange(0, CCmixer1, muxRead);
case MUXmix2:
myControlChange(0, CCmixer2, muxRead);
case MUXmix3:
myControlChange(0, CCmixer3, muxRead);
case MUXattack:
myControlChange(0, CCattack, muxRead);
case MUXdecay:
myControlChange(0, CCdecay, muxRead);
case MUXsustain:
myControlChange(0, CCsustain, muxRead);
case MUXrelease:
myControlChange(0, CCrelease, muxRead);
case MUXlfospeed:
myControlChange(0, CClfospeed, muxRead);
case MUXlfodepth:
myControlChange(0, CClfodepth, muxRead);
case MUXlfomode:
muxRead = muxRead / 24;
myControlChange(0, CClfomode, muxRead);
case MUXfilterres:
myControlChange(0, CCfilterres, muxRead);
case MUXfilterfreq:
myControlChange(0, CCfilterfreq, muxRead);
muxInput++;
if (muxInput >= MnumControls) muxInput = 0;
digitalWrite(MS0, muxInput & B0001);
digitalWrite(MS1, muxInput & B0010);
digitalWrite(MS2, muxInput & B0100);
digitalWrite(MS3, muxInput & B1000);
checkSwitch();
void checkSwitch() {
if (digitalRead(SWosc1)) {
octave1 = 12;
octave1 = 0;
if (digitalRead(SWosc2)) {
octave2 = -12;
octave2 = 0;
if (digitalRead(SWlfo)) {
if (LFOmodeSelect < 8) LFOmodeSelect = LFOmodeSelect + 8;
if (LFOmodeSelect >= 8) LFOmodeSelect = LFOmodeSelect - 8;
