Results 1 to 21 of 21
Thread: Teensy 4.0 with OctoWS2811
    I'm using Arduino 1.8.11 / Teensyduino 1.50 with the Teensy 4.0 / OctoWS2811 Adapter Board. When I run the BasicTest I get the following error:
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811/OctoWS2811.cpp: In member function 'void OctoWS2811::begin()':
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811/OctoWS2811.cpp:94:2: error: 'GPIOD_PCOR' was not declared in this scope
      GPIOD_PCOR = 0xFF;
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811/OctoWS2811.cpp:177:19: error: 'GPIOD_PSOR' was not declared in this scope
      dma1.destination(GPIOD_PSOR);
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811/OctoWS2811.cpp:184:19: error: 'GPIOD_PDOR' was not declared in this scope
      dma2.destination(GPIOD_PDOR);
    It looks like the OctoWS2811 library isn't currently supported by Teensy 4.0, is there a known workaround or plan to support OctoWS2811 in the future?
    Oct 2013
    16
    Have the same issue myself. Did you figure anything out?
    10,771
    I was curious, so I thought I would take a quick look,
    Looks like this one would be a bit of a challenge and it is not something I have or use... Actually I think I did buy one in my last PJRC purchase, but...
    Some of the challenges associated with this include:
    The board is setup to use pins: 2, 14, 7, 8, 6, 20, 21, 5 on the T3.x (and LC) which maps to Port pins D0-D7 on T3.6/3.5 (did not look at others, but assume on same Port pins 0-7)
    Problem(s) with T4: These pins are not on the same port nor are there any 8 pins that are consecutive bits on the same port, nor does the T4 have 8 bit access to IO ports (access is 32 bits).
    These 8 pins are spread out like4.4, 1.18, 2.17, 2.16, 2.10, 1.17, 1.16, 4.8)
    So I don't see any obvious way to translate the DMA operations used in this library over to something that would work on T4.
    My guess is it would take a sort of rethink... For example if one has 8 pins on the same IO buss, could this could be setup to do DMA not to the Data register but only use the SET/CLEAR registers... Or if 8 pins were all on the same FLEX IO controller, could we setup to do this.. Note: would probably need to be FLexIO 1 or 2 as 3 does not have DMA...
    So sorry, I don't think I am much help here, probably needs someone like Paul who set this up originally.
    It might not help you specifically since it isn't compatible with OctoWS2811, but Ward demonstrated a way to drive WS2811 strips using the FlexIO and some external shift registers:
    https://forum.pjrc.com/threads/59023...FlexIO-and-DMA
    26,563
    I've committed code on github for OctoWS2811 on Teensy 4.0.
    https://github.com/PaulStoffregen/Oc...bf0a2d4c607f13
    This will be in Teensyduino 1.52, which will begin beta testing next week.
    Awesome! Can you share a little about your method to provide output on an arbitrary set of 8 pins?
    It looks like you set up DMA to transfer 32 bits to each of GPIO1, GPIO2, GPIO3, and GPIO4 in sequence (as opposed to the T3 code which transfered 8 bits to a single GPIO) - is that correct?
    Thanks! I was waiting for this! Directly upgraded two of the LED walls you can see in the video which were using OctoWS2811 on a T3.6 to a T4.0 and the increase in performance makes the animation run way smoother! It went from varying around 40 fps to maxing out at 140 fps (the limit for the amount of leds/strip I'm using). Thank you so much!
    https://youtu.be/cdfFI6miXMU
    26,563
    Thanks for sharing. Would it be ok to give this unlisted video a shout-out on social media?
    26,563
    Quote Originally Posted by easone View Post
    Yes, that's exactly how it works.
    Because the data expanded to 128 bits is so large, it's generated on-the-fly into a pair of buffers. DMA scatter-gather is used to seamlessly transition between using each buffer.
    Yes, please go ahead
    Oct 2013
    16
    Im trying to use this with a bno080 over i2c but what happens is, the frame-rate drops for a while then the sensor doesn't return readings anymore. If I don't call leds.show(), the sensor works normally. Could this library interfere with i2c in some way?
    I also tried using bno055 on i2c and a different thing happens, works fine for a while then the frame-rate drops and doesn't recover. The sensor still returns values though.
    These are the pins I'm using: uint8_t pinList[] = {34, 36 , 28 , 38, 31, 39, 35, 37};
    Using bno080 on spi works ok but its not an option for us because of the distance to the sensor. We are making a dress covered in about 3200 leds, and the IMUs are supposed to be in the hands.
    Any ideas how I should debug this?
    Oct 2013
    16
    After looking a bit more this is what i found so far.
    Using the debug feature of the bno080 library I get:
    Received: Header: 12 00 05 64 Body: E3 22 0E 01 AC 00 A3 35 00 00 00 00 00 00 Length:18 Channel:Gyro-vector
    Received: Header: 12 00 05 66 Body: E3 22 0E 01 AC 00 A3 35 00 00 00 00 00 00 Length:18 Channel:Gyro-vector
    Received: Header: 12 00 05 68 Body: E3 22 0E 01 AC 00 A3 35 00 00 00 00 00 00 Length:18 Channel:Gyro-vecto
    Received: Header: 12 00 05 6A Body: FF FF FF FF FF FF FF FF FF FF FF FF FF FF Length:18 Channel:Gyro-vector <- this seems to be where the problem starts
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    Received: Header: 14 01 00 00 Body: 00 01 04 00 00 00 00 80 06 31 2E 30 2E 30 00 02 Length:276 Channel:Command <- still figuring out
    Received: Header: 14 00 02 00 Body: F1 00 84 00 00 00 01 00 00 00 00 00 00 00 00 00 Length:20 Channel:Control <- what these two mean
    Received: Header: 05 00 01 00 Body: 01 Length:5 Channel:Executable <- this means the sensor reset itself
    The library first reads four bytes to get the header and figure out how many bytes are coming then reads the rest in a separate read. In the packet where the problem starts this second read seems to fail for some reason.
    Oct 2013
    16
    I don't know how to really interpret this but it seems the library somehow borks i2c.
    Another debug trace:
    Received: Header: 12 00 05 BA Body: 4B 10 FF 02 D0 00 D0 3D 00 00 00 00 00 00 Length:18 Channel:Gyro-vector
    Received: Header: 12 00 05 BC Body: 4B 10 FF 02 FF FF FF FF FF FF FF FF FF FF Length:18 Channel:Gyro-vector <- sh*t hits the fan
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout
    I2C timeout everything below here just means the sensor reset itself and is sending another 'hello im here, this is who i am'
Name:	Screenshot 2020-05-20 at 14.37.51.jpg
    The image shows a logic analyser trace at the point it all borks.
    Oct 2013
    16
    Tried using teensy4_i2c instead of Wire but it also fails and reports a timeout. :/
    26,563
    Can you try it with all the LEDs disconnected, so Teensy does all the same things but no LEDs actually receive the data. The idea is to check whether their massive changes in power consumption are somehow interfering? Spending a lot of time on the software side would be a shame if the problem is due to power.
    Oct 2013
    16
    Hey Paul, yes I tried doing that early on. Actually as I'm trying to debug this I only have the control box and nothing but the IMU connected. The only thing that helps is not calling leds.show(). Without that call the IMU works for hours (left it over night), with the call, i2c freezes (teensy stops clocking) in less than 10 seconds. I pretty much tried everything I know to find out what is going on. Debugging OctoWS2811 is WAY over my head.
    OctoWS2811 with Teensy 3.1
    Will the Teensy 4,1 also work seamlessly with the OctoWS2811 PCB and Teensyduino 1.52 ?
    I'm assuming the 60K EEPROM emulationn that applies to the Teensy 4.0 will also apply to the 4.1?
    thanks
    26,563
    Quote Originally Posted by Ausplex View Post
    Yes, Teensy 4.1 works with the OctoWS2811 board.
    For "seamlessly", you need to get the 14 pin sockets and tall 14 pin headers. Used together, these stack up to vertically position Teensy 4.1 (or 3.5 or 3.6) so the longer part of the board overhangs the RJ45 jacks. If you use only normal length header pins, it physically won't fit.
    On Teensy 4.0 or 4.1, the OctoWS2811 can be configured to use any combination of digital pins. But the default setting is the same set of 8 pins used on Teensy 3.x, so it will "just work" with the OctoWS2811 board.
    Yes, but it's not 60K. On Teensy 4.1 the top 252K (just below the 4K restore program) is used for eeprom emulation.
    The actual emulated size is 4284 bytes. Details here:
    https://www.pjrc.com/teensy/td_libs_EEPROM.html
    Does this mean you can drive more than 8 WS2811 strings on the Teensy 4? Looks like you can do as many strings as there are data pins when I skimmed through the code. If so, that's a pretty impressive feature I haven't seen specifically called out anywhere.
    Oct 2020
    1
    Quote Originally Posted by fsk View Post
    Did this get resolved? I'm thinking of getting a teensy to use with OctoWS2811 but not sure whether teensy 4 or teensy 3 will be best at this point.
    Junior Member Loufe's Avatar
    May 2021
    Canada
    4
    For future reference yes it did. Be careful not to use the library through the arduino menu - the up to date version is installed and accessible already by arduino by the teensyduino installer.
