Results 1 to 4 of 4
Thread: how to define separate Wire for 2 SSD1306 OLED Display on Teensy 4.0
    Feb 2020
    2
    maybe simple question but....
    this is my source code:
    #include <Wire.h>                     //OLED
    #include <Adafruit_SSD1306.h>         //OLED
    //OLED
    #define SCREEN_WIDTH 128
    #define SCREEN_HEIGHT 64
    int showoff = 1;
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
    Adafruit_SSD1306 display2(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
      if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
        Serial.println(F("OLED F"));
        for(;;);
      if(!display2.begin(SSD1306_SWITCHCAPVCC, 0x3D)) {
        for(;;);
          display.clearDisplay();
          display.setTextSize(2);
          display.setCursor(1,0);
          display.setTextColor(SSD1306_WHITE);
          display.println(F("SCREEN 1"));
          display.display();
          display2.clearDisplay();
          display2.setTextSize(2);
          display2.setCursor(1,0);
          display2.setTextColor(SSD1306_WHITE);
          display2.println(F("SCREEN 2"));
          display2.display();
    2 displays are already connected to 18/19 pins (SDA0/SCL0), now I want to connect 2 more displays and knowing fact that SSD1306 has only 2 addresses in selection I've figured out that I could get them connected to pins 17/16 (SDA1/SCL1)... but as I saw that need to be declared in setup (Wire.begin()). I'm fresh at this and little confused how to do it.
    Could someone help?
    10,571
    All references for the displays on Wire1 17/16 would need to be done using Wire1 instead of Wire.
    Feb 2020
    2
    so it will work if I simply define this display as follows?
    Adafruit_SSD1306 display3(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, -1);
    Adafruit_SSD1306 display4(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, -1);
    10,571
    Indeed that should do it
