Results 1 to 11 of 11
Thread: Question about Teensy 4 second USB port.
    Feb 2020
    5
    I have an existing project running on a Teensy 3.2 which receives commands from a PC connected via USB through a second USB port that is a FT232RL USB to TTL Serial Adapter Module connected to the Teensy I/O.
    The reason for using a second USB port on the Teensy 3.2 is so that the primary/built in port can be used to update the firmware and also drive a serial console that shows the status / debug.
    I need to make a new system so am thinking that i can use a Teensy 4 which includes a secondary USB port.
    My question is can the second USB port on a Teensy 4 be used as a standard USB port to receive commands from a PC (thus negating the need to use a FT232RL USB to TTL Serial Adapter Module connected to the Teensy I/O like i do with the Teensy 3.2).
    The documentation refers to the port as "USB Host" which infers that it intended to be a USB controller device rather than a listener (hope that makes sense)
    Are there any other components needed to use the second USB port on the T4 other than a physical port connector ?
    Many Thanks
    Jay
    Germany NRW
    6,874
    There is no software to use the second port in device mode - and it would'nt make much sense..?
    Do you want a second usb-serial? That would be possible.
    There were several requests for this (from me, too) - so far I not aware of a solution that would survive a teensyduino-update.
    All these USB modifications need patching some files - and all mods are gone after every update.
    Too elaborate for me, I'm too comfortable for that.
    Feb 2020
    5
    There were several requests for this (from me, too) - so far I not aware of a solution.
    Hi Frank B,
    I just want to be use the second USB port to receive serial data from a PC, and keep the primary port for firmware updates and debug.
    Are you saying that it's not possible ?
    Cheers
    Jay
    Germany NRW
    6,874
    No i'm saying I'm not aware of any existing code for a second port.
    It's possible.
    Or even HID + Serial would help (maybe even better).
    So, if you want to dig into into...
    Fame and glory would be yours.
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    257
    I'd be interested in seeing these mods for a second virtual serial port. Have you posted them somewhere or made a pull request? (I can't seem to find them...)
    Germany NRW
    6,874
    No I have nothing like this.
    Sorry if my English leads to misunderstandings.
    A long time ago I saw it here in the forum - for T3.2 maybe?
    But I don't like such patches - having to repeat them after every update makes me ... thirsty for beer.
    May 2015
    San Francisco
    257
    No problem, Frank! Makes me thirsty too!
    Nov 2015
    Cold hollow VT
    139
    Using an FT232 adaptor on say serial1, or serial2 would work to receive commands on a Teensy. If you use serialEvents be sure to specify the port being used. I have done this and have also placed a serial datalogger from SparkFun on the same port to record all port activity to a flash drive.
    Feb 2020
    5
    Quote Originally Posted by grease_lighting View Post
    @grease_lighting,
    Thats how my existing project on Teensy 3.2 works now.
    My understanding from the above comments from Frank B is that it's not possible to use the second USB port on the Teensy 4.0 in device mode as currently there are are no library's that support it.
    Thats a real shame and a trick missed .... maybe PJRC can add it as a feature to the Teensy API in the future.
    Cheers
    Jay
    21,820
    Quote Originally Posted by JayMonkey View Post
    Confirm, this is correct where "possible" means using existing libraries.
    If "possible" means the hardware could do it if library code were written (or converted from the first port), then it is possible with that sort of programming.
    Yes, this is on my todo list. We even purchased special cables to sell for this, which have been sitting unused in a box.
    But the reality is this is a much lower priority than so many other things, like USB Audio and porting OctoWS2811, plus new hardware. There are only so many hours in every day. We have to prioritize, and indeed support for using both USB ports in device mode is on the list, but not expected to have a nice library anytime soon.
    Feb 2020
    5
    @PaulStoffregen,
    Many thanks for the clarification ....
    For now we will implement the same hardware/software we used with Teensy 3.2 (FT232RL USB to TTL Serial Adapter Module connected to Teensy I/O).
    Cheers
    Jay
