Results 1 to 13 of 13
Thread: Teensy 4.0 Theoretical Max Clock Speed
    Jan 2020
    9
    Hi all, I have been experimenting with the overclocking on the teensy 4.0 but didn't go above 816MHz. I was curious about what the theoretical maximum clock the hardware would support if overheating is not an issue.
    I assume that the maximum voltage the board would be able to supply would affect this speed?
    1,214
    I think this statement from page 1044 of the reference manual (Rev 1) is the one you need:
    PLL1 (also referred to as ARM_PLL) - This is the PLL clocking the ARM core complex. It is a programmable integer frequency multiplier capable of output Clock Management frequency of up to 1.3 GHz. Note that this frequency is higher than the maximum chip supported frequency 1.0 GHz.
    Pete
    10,573
    I've tested over 900 MHz - at a minimum a heat sink is needed, and a fan across the whole board is perhaps better - especially good in combination.
    Paul has posted pics of his heat sink - seems tall thin fins - and I got a RasPi copper chunk with a grid of chunky blobs that works well enough at 916 MHz.
    I plugged in a new T4 without heatsink/fan or any required cooling and using IDE that had 916 or higher 960 MHz setting I did not expect - the T4 melted inside.
    It can function at or near 1008 MHz - great cooling needed and YMMV . Going over 600 MHz raises internal voltage easily from the processor's ~1.25V range - but expect shortened part life.
    There is a TeensyDuino included TempMon that is of some value to print the temp - though without proper cooling rather than going up gradually through usable temp range - the temp can spike and the Teensy will restart/shutdown before going even to 50 or 60C when normally it can operate above that temp when loaded. If that behavior is observed cool more or slow it down, and/or buy a spare T4.
    Jan 2020
    9
    Sounds like 1008 MHz is the max then? I am testing a liquid cooling system for the t4 but I was not sure what the max clock to test would be.
    10,573
    In the IDE TeensyDuino 1.50 it offers 1.008 GHz - that is the max unsafe ( ) OC Speed tested to work AFAIK. Note TD before 1.50 offered 1008MHz - but ended up with a 996MHz setting.
    I suppose you've found the code set_arm_clock() for changing the speed at runtime? And are using tempmonGetTemp() to get a reading on the internal temp? With TD 1.50 the T_4 will now reset on overtemp, not just shutdown.
    In some testing getting heat off the chip is good { @FRDM4236 } - maybe liquid will be enough better removing heat - but a fan cools surrounding structure so it can draw out heat as well and that is a couple degrees improved over what a heat sink was showing.
    Jan 2020
    9
    I've either been setting F_CPU in the Makefile or calling set_arm_clock() at runtime and monitoring tempt with tempmomGetTemp(). I'm hoping liquid will be enough to remove the heat to run stable.
    Germany NRW
    6,165
    I remember the first raspies - it was needed to burn a internal fuse to unlock overclocking.
    That way, they could check the fuse when they got raspies back. If it was set, they did not refund anything.
    Might be a good idea for PJRC, too.
    A special program that burns a fuse (are there any fuses that can be used?) to unlock overclocking.
    @wdmerges: Use dry ice :-)
    Jan 2020
    9
    Could be a good idea, I'm not sure how often people try and refund.
    Of course if I burn anything out when overclocking I would never expect a refund.
    Germany NRW
    6,165
    I don't suppose so!
    But there are always people who do.
    Of course this needs a fuse that can be read out when the T4 is dead... maybe on the bootloader chip?
    10,573
    The one I toasted when unmounted showed a clear internal short - you can't do that without abusing it somehow.
    Germany NRW
    6,165
    That's a valid argumentation :-)
    21,288
    The maximum speed PLL1 can generate is 1.296 GHz. If you call set_arm_clock(1296000000), it will try to configure that speed. The CPU can't possibly run that fast... at least as far as anyone knows, based mostly on tests with heatsinks and forced are cooling. But it will try (and almost certainly crash). If you give set_arm_clock() higher numbers, it will cap your request to 1.296 GHz, because that is the maximum for PLL1.
    When you try overclocking, please at least run the CoreMark benchmark to confirm the speed.
    https://github.com/PaulStoffregen/CoreMark
    Look at the results carefully. CoreMark checks to verify all its algorithms produced the correct results. Some speeds which are too fast (but just short of completely crashing) can actually complete the benchmark, but give wrong results. The CoreMark iterations/sec number is invalid if any of those verifications fail.
    If you do get any speeds faster than 1.008 GHz to consistently pass CoreMark, I hope you'll share the results and photos of the extreme cooling used to achieve it.
    10,573
    Also the RSA test. Just before the final change to the voltage calc at or after T_4 release(?) I had one work and one fail at 800 MHz, it was likely coremark - but that was daze ago. Also ran buddabrot and maybe fastcrc - seems it was 4 total and two gave failures … before 10/8/19.
    Would be interesting to see pics of the liquid cooling assembly. Just a radiator for cooling - any fan - what moves the liquid?
    And it looks like I did this for loop() 10/6/19:
    uint32_t ii=0;
      ii++;
    #if defined(__IMXRT1062__)
      Serial.printf("\n\n F_CPU=%u", F_CPU_ACTUAL );
      Serial.printf( "\tdeg  C=%u\tPass#%u\n" , (uint32_t)tempmonGetTemp(),ii );
      coremark_main(); // Run the benchmark  :-)
