Results 1 to 5 of 5
Thread: Values get cut short from esp8266 Huzzah to Teensy 3.6
    Feb 2019
    Netherlands
    11
    Hi
    I'm working on a project that needs to send values from my esp8266 HUZZAH to my Teensy 3.6.
    I got the communication working between the two but there is a slight problem.
    The values get "cut".
    I send 200 and 50
    But the result on the monitor of the Teensy is:
    205205205205205205
    How can I fix this issue?
    This is the code on the Teensy:
    Serial1.begin(115200);
    // Send bytes from Teensy to computer
    if ( Serial1.available() ) {
    Serial.write( Serial1.read() );
    analogWrite (13, Serial1.read() );
    This is the code on the Esp8266 HUZZAH
    // Setup computer to Arduino serial
    // Setup Arduino to ESP8266 serial
    // Use baud rate 115200 during firmware update
    Serial.write ("200");
    delay (1000);
    Serial.write ("50");
    delay (1000);
    Thank you for reading! Please comment if you have any idea that could help
    Feb 2019
    Netherlands
    11
    Update:
    When I remove
    analogWrite (14, Serial1.read() );
    From the code it sends over the complete value like this:
    502005020050200
    So that is a slight improvement.
    But I would like to control a led with the value. So I Tried to store the value like this:
    char val = 0;
    // Send bytes from ESP8266 to computer
    val = Serial1.read();
    analogWrite (13, val);
    Which results to this on the serial monitor:
    0⸮00⸮00⸮00
    What am I overlooking?
    10,926
    The value read is into a char - so it will print as a char ? Should that be uint8_t val=0; ?
    Also is this intended to read Serial1 twice ? Alternate readings with Print one then analog write the other:
    Or should it be:
    Serial.write( val );
    Feb 2019
    Netherlands
    11
    Thank you that did the trick! It is now sending over the values in the correct way.
    But the led is not turning on.
    Any clue why that is not happening?
    Nov 2017
    Belgium
    215
    Quote Originally Posted by Ko de Beer View Post
    teensy code:
    In setup() you need to add the pinMode command to configure pin 13 as an output or the led will not work.
    In loop() change Serial.write to Serial.println(to send an ASCII representation of the binary value).
    esp8266 code:
    Remove the double quotation marks used in the Serial.write commands(to send a binary value instead of an ASCII representation).
