Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
Thread: Is it possible to have a high resolution FFT.
  1. #26
    1,416
    If I understand you correctly, that is not going to work. I haven't used an Si5351 but I don't see how you use a frequency from the Teensy to "tune" the Si5351. The Si5351 is a clock generator, not a frequency synthesizer.
    You would be a lot better off implementing the encoding of the WSPR digital signal directly in the Teensy and then use that to drive a synthesizer chip.
    I have generated JT65 signals with a Teensy++2 and a DDS-60 which uses an AD9851 synthesizer to transmit on 40 metres. I've also implemented FT4 audio encoding in a Teensy. Neither of those is a trivial thing to do but they are a whole lot easier than trying to make the Teensy discriminate between four tones which are separated by 1.4648 Hz and then somehow use that to drive a synthesizer.
    Pete
  2. #27
    Feb 2020
    Chicago,IL
    32
    I am working odf experience using the SI5351 for standalone WSPR. I would be using the Teensy and the Si5351 arduino library to set the frequency. https://github.com/etherkit/JTEncode...5351JTDemo.ino shows an example of someone's program for directly sending from the arduino using the SI5351.
    I could just skip all this and wait until I have enough money to actually afford a HF radio (or build one) but this seemed like a fun project to try and work on.
  3. #28
    1,416
    I stand corrected. I hadn't expected that I2C would allow sufficient control to maintain the symbol timing.
    You would certainly be better off using the encoder to generate the WSPR signal.
    Pete
  4. #29
    Feb 2020
    Chicago,IL
    32
    I am trying to convert FT8 audio to the RF. I could try doing sending of it using that library. Hm.
