Below is a short test program where I try to attachInterrupt(IRQ_LPSPI4...). It appears I am not using the correct value for the interrupt.
I am looking at the MOSI signal on a scope and all the code is doing what you would expect, except my ISR is never being called.
Where can I find the number that would correspond to LPSPI4_IER=LPSPI_IER_FCIE ?
#include <avr/io.h>
#include <avr/interrupt.h>
//from Teensy 4 imxrt.h
// IRQ_LPSPI1 = 32,
// IRQ_LPSPI2 = 33,
// IRQ_LPSPI3 = 34,
// IRQ_LPSPI4 = 35,
// IRQ_GPIO6789 = 157, // RT1060 only
const int slaveSelectPin = 10;
int i=0;
Serial.begin(38400);
pinMode (slaveSelectPin, OUTPUT);
digitalWrite (slaveSelectPin, HIGH);
SPI.begin();
SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
while(i++<20)
{ //wiggle High signal to oscilloscope, trigger scope using slaveSelectPin going low
digitalWrite(slaveSelectPin,LOW);
SPI.transfer(0xFF);
//wiggle Low signal to oscilloscope, trigger scope using slaveSelectPin going low
SPI.transfer(0x00);
//SPI.usingInterrupt(IRQ_LPSPI4);
attachInterrupt(IRQ_LPSPI4, SPI_FrameComplete, HIGH); //IRQ_LPSPI3 cuases this function to called immediately
volatile uint32_t cnt_ist=0;
void SPI_FrameComplete() //IRQ_LPSPI4
//Serial.printf(" i'm here.\n");
cnt_ist++;
LPSPI4_SR = 0x3f00;//Reset All flags and errors
asm("dsb");
// NOTE: The SPI write code below only works because I am giving the system 100ms between writes.
// This is an example for discussing the SPI Frame Complete Interrupt (not proper SPI buffering).
Serial.printf(" CNT: ***** %d *****\n",cnt_ist);
i=0;
while(i++<20)
{ //wiggle EVEN bits to oscilloscope, trigger scope using slaveSelectPin going low
LPSPI4_TCR = LPSPI_TCR_RXMSK | 0x0000007; asm volatile("nop");
LPSPI4_TDR = 0xAA; asm volatile("nop");
//wiggle ODD bits to oscilloscope, trigger scope using slaveSelectPin going low
LPSPI4_TDR = 0x55; asm volatile("nop");
// the above works almost the same, but my slaveSelectPin goes HIGH almost immediately, long before the END of Frame.
// Let's enable the SPI interrupt and use that to set my slaveSelectPin HIGH
//LPSPI4_CR = 0x0300; //Disable SPI, reset FIFOs
//asm volatile("nop");
LPSPI4_IER=LPSPI_IER_FCIE; //Set Frame Complete Interrupt Enable
//LPSPI4_IER=LPSPI_IER_FCIE | LPSPI_IER_TDIE; //Set Frame Complete Interrupt Enable AND Transmit Data Interrupt Enable
//LPSPI4_CR = 0x0001; //Enable SPI
i=0;
while(i++<20)
{ //wiggle LEFT bits to oscilloscope, trigger scope using slaveSelectPin going low
LPSPI4_TDR = 0xF0; asm volatile("nop");
//digitalWrite (slaveSelectPin, HIGH); // This should be done in ISR
//wiggle RIGHT bits to oscilloscope, trigger scope using slaveSelectPin going low
LPSPI4_TDR = 0x0F; asm volatile("nop");
