Results 1 to 12 of 12
Thread: Teensy 4.0 + RA8875
    Jan 2020
    12
    Teensy 4.0 + RA8875
    Hey guys,
    So currently I have hooked up an 4.3" RA8875 TFT screen to my teensy 4.0 and it works fine.
    I was just wondering if there was some intuitive program that could be used as a GUI editor, such as Qt or GUIslice builder.
    Both of these claim to have support for the Teensy 4.0 and/or the RA8875 screens, but I cannot find any documentation or tutorials on how to get this to work.
    Any and all help is appreciated.
    Kind regards.
    Jan 2020
    12
    To give an update, this is how far i've come myself:
    This is what i created in GUI Slice Builder
    This is what my display shows. So technically i'm close, but also far off.
    This is the test file that was generated by GUI Slice Builder:
    https://pastebin.com/uCYMP7TF
    This is the config I've adapted:
    https://pastebin.com/CNyXVLm9
    4,581
    You may want to check you display resolution:
      // Select the RA8875 display resolution:
      // - RA8875_480x272 = 480x272 (4.3" display)
      // - RA8875_800x480 = 800x480 (5" and 7" displays)
      #define DRV_DISP_ADAGFX_RA8875_INIT RA8875_800x480
    You may need to change this is 480x272 instead of 800x480. Never used these builders so would have to dig into it. You may have to edit display file as well for your display not sure
    Jan 2020
    12
    I did not see this, thanks for your keen eye. I will try this first thing in the morning.
    Also, there is an DPI setting, would this, or could this affect the way the screen works? If so, I couldn't find the DPI value of the Adafruit RA8875 480x272 4.3" display anywhere, and measuring it up manually would seem a bit inaccurate.
    4,581
    The dpi setting is the 480x272. Yep it can define the way it works but you have to give it a try. If you look at the comments right about what I think you may want to try is:
    #define DRV_DISP_ADAGFX_RA8875_INIT RA8875_480x272
    which the comment next to is says is for a 4.3in display. The way its set up is for a RA8875 800x480 dpi display.
    Jan 2020
    12
    That I understand, but in GUI Slicer you can also set up the width, height and dpi (dots per inch) of the screen. I'm not sure if the dpi setting influences anything.
    4,581
    You will probably have modify in a couple of other places as well to get it to work properly. I saw this in one of the issues to set up a config:
    Uncomment /configs/ard-adagfx-ra8875-notouch.h in /src/GUIslice_config.h
    Then you may have to edit the ra8875 config file as well. There doesn't seem to be one place where its all at.
    EDIT: also check your pin numbers to make sure they line up but probably they are since you are getting something.
    Jan 2020
    12
    Unfortunately checking both files for anything that could cause problems, and tweaking those, didn't really change anything. Even the setting you spotted earlier didn't change it. I guess I'll just use the "hardcore" way of defining your own shapes for now.
    6,078
    Also maybe check the SPI speed. Maybe depending on your setup, it is trying to drive SPI too fast...
    Jan 2020
    12
    Hmm possible, I'll see if I can find where this is located, if tweakable at all.
    Jan 2020
    12
    I have reached a dead end, do you guys know of any other possible causes? Or simply the fact that this new processor is not properly setup in the low level code of this software?
    I have currently "hacked" it to think that it is actually flashing to a Teensy 3.6, but couldn't find any influences of this on the workings.
    6,078
    Sorry, I don't know exactly your setup?
    That is I downloaded (forked and cloned from) https://github.com/ImpulseAdventure/GUIslice
    As far as I can tell it does not know anything about Teensy 4... Examples don't compile, Tried to copy your config file will try again...
    From what I can tell, this is not using our version of RA8875, but instead is using the Adafruit_RA8875 library.
    The Adafruit library does work on my displays with the T4, although I often might have to powercycle it or the like after programming it.
    Not sure how hard it would be to convert it over to using our RA8875 library that was derived from Sumotoy...
