Results 1 to 4 of 4
Thread: Teensy 3.2 and WS2812B NOT WORKING?
    Feb 2020
    10
    Can anyone help me get this code working? This code is working on the Arduino but not transitioning to the Teensy.
    I am trying to illuminate 3 LEDs on the WS2812B with my Teensy 3.2.
    #include <Adafruit_NeoPixel.h>
    #define LED_PIN    3
    #define LED_COUNT  3
    Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
    void colorWipe(uint32_t color, int wait) {
      for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
        strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
        strip.show();                          //  Update strip to match
      colorWipe(strip.Color(0,  255,   0), 0); // Green
    21,474
    Are you sure that works on normal Arduino? I don't see how it could, since you're missing "strip.begin();" to initialize the library.
    I tested just now with a Teensy 3.2 and the missing line added.
    Here's the full code I tested:
    #define LED_PIN    3
    #define LED_COUNT  3
      strip.begin();
    21,474
    Also consider that some WS2812 LEDs (NeoPixel) do not work with 3.3V signals.
    But most newer ones do accept 3.3V, as do the very oldest ones.
    Feb 2020
    10
    I forgot to copy that line over to my Teensy sketch . All working now, thankssss
