Results 1 to 4 of 4
Thread: Lost Serial port
    Lost Serial port
    My Teensy 3.5 won't respond on Serial. In Arduino, it shows the serial port as hid#vid_16C0&pid_0478 Bootloader (Teensy 3.5). How do I get the serial port restored?
    Germany NRW
    6,243
    Upload a simple (known to work) sketch with usb-type set to serial.
    If it does not respond, press the button on the teensy.
    10,641
    "hid#vid_16C0&pid_0478 Bootloader"is what I see here when I press the a Teensy button to put the Teensy into bootloader mode.
    That button is not Reset - but rather takes the Teensy offline to bootloader where the PC will see that indication,
    repower/replug the Teensy and what shows up?
    I did get the board responding again. I had to remove it from the PCB in order for it to recognize the serial port by loading a simple program. Once the simple program was loaded, I was able to re-install the main program. Oddly enough, most of the values stored in EEPROM were trashed.
    Thanks for the advise.
