Results 1 to 5 of 5
Thread: won't compile, one wire crossed......
    Feb 2020
    6
    this line in the audio code will not compile playSdWav2.play(&mySounds[tracknum]); //??????????
    apologies in advance, I cannot even do that code in the window thing......
    String mySounds[]= {
    "surf0001.WAV",
    "surf0002.WAV",
    "surf0003.WAV",
    "surf0004.WAV",
    "surf0005.WAV",
    "wavetest.WAV"
    // copy the Design Tool code here
    AudioPlaySdWav           playSdWav2;     //xy=115,388
    AudioPlaySdWav           playSdWav3;     //xy=116,532
    AudioPlaySdWav           playSdWav1;     //xy=120,264
    AudioMixer4              mixer1;         //xy=300,274
    AudioMixer4              mixer2;         //xy=307,399
    AudioEffectFade          fade2;          //xy=470,396
    AudioEffectFade          fade1;          //xy=471,275
    AudioMixer4              mixer3;         //xy=666,436
    AudioOutputI2S           i2s1;           //xy=832,352
    AudioConnection          patchCord1(playSdWav2, 0, mixer2, 0);
    AudioConnection          patchCord2(playSdWav2, 1, mixer2, 1);
    AudioConnection          patchCord3(playSdWav3, 0, mixer3, 2);
    AudioConnection          patchCord4(playSdWav3, 1, mixer3, 3);
    AudioConnection          patchCord5(playSdWav1, 0, mixer1, 0);
    AudioConnection          patchCord6(playSdWav1, 1, mixer1, 1);
    AudioConnection          patchCord7(mixer1, fade1);
    AudioConnection          patchCord8(mixer2, fade2);
    AudioConnection          patchCord9(fade2, 0, mixer3, 1);
    AudioConnection          patchCord10(fade1, 0, mixer3, 0);
    AudioConnection          patchCord11(mixer3, 0, i2s1, 0);
    AudioConnection          patchCord12(mixer3, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=574,610
    // Use these with the Teensy Audio Shield it is slower than the onboard SD card reader
    //#define SDCARD_CS_PIN    10
    //#define SDCARD_MOSI_PIN  7
    //#define SDCARD_SCK_PIN   14
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
    //audio setup code starts here
      AudioMemory(8);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
      pinMode(13, OUTPUT); // LED on pin 13
      mixer1.gain(0, 0.5);
      mixer1.gain(1, 0.5);
      mixer2.gain(0, 0.5);
      mixer2.gain(1, 0.5);
    #define RAMPSIZE 10000
    int ramper=0,ramper2=10000,stepled,stepledlast;
    int up=1;
    long int ramp=100000;
    //These return a number between 0 to 4294967295. For millis, that's 49.7 days. For micros, 1 hour+
    elapsedMillis milliDontTouch,milli1,milli2,milli3;
    bool tenmS=0,tenmSLong=0;
    //elapsedMicros micro1,micro2,micro3;
      tenmS=(((milliDontTouch%10)==0)&&!tenmS&&!tenmSLong); // on for a single scan ...this may not work 100.000%, because of == could concievably skip if any scan time exceeds 1mS
      if (tenmS){
        tenmSLong=1;  //on for multiple scans over a full mS
      if(tenmSLong&&((milliDontTouch%10)!=0)){ //next millisecond has clicked by
        tenmSLong=0;
      if(tenmS){
        playbackingtrack(3,0.5);
    byte channelnum=1; //channel 1 or 2 only
    byte tracknum=-1;
    float gayn;
    bool playbackingtrack(int newtracknum, float newgain){
      if(tracknum<0||tracknum>6){ //illegal track number, stop playing everything
        fade1.fadeOut(2000);
        fade2.fadeOut(2000);
        //playSdWav1.stop();  //should fade out first
        //playSdWav2.stop();
      else if (newtracknum!=tracknum){ // track change
        tracknum=newtracknum;
        if(channelnum==1){
          fade1.fadeOut(4000);
          fade2.fadeIn(4000);  //note both tracks are still playing even with one faded out, this may slow down processor???? or can call stop() after the fade out has happened
          channelnum=2;
        else if(channelnum==2){
          fade2.fadeOut(4000);
          playSdWav1.play(&mySounds[tracknum]);
          fade1.fadeIn(4000);  //note both tracks are still playing even with one faded out, this may slow down processor???? or can call stop() after the fade out has happened
          channelnum=1;
      Serial.print("Start playing ");Serial.print(mySounds[tracknum]);Serial.print("  on channel # ");Serial.println(channelnum);
      if(gayn!=newgain){
        gayn=newgain;
        mixer3.gain(0,gayn); //not fading it in at this time
        mixer3.gain(1,gayn);
      return(playSdWav1.isPlaying() || playSdWav2.isPlaying());
    11,506
    Added # CODE blocking above - click the # and insert code between - or select all text and click the toolbar "#" symbol to add:: [C0DE] //code here with upper case "O" not ZERO [/C0DE]
    1,317
    .play only accepts a "const char *" for the filename, not a String. Change "String mySounds[]= {" to "const char * mySounds[]= {"
    and then remove the & from the calls to .play.
    Pete
    21,825
    Or if you really want to use String, just use .c_str() to get a C style string for play(). Like this:
          playSdWav2.play(mySounds[tracknum].c_str());
    Feb 2020
    6
    defrag.........elementary sir, and appreciate the tutelage
    supremo.........brilliant.........you are da man
    paul..........ok way beyond me but great to know stephen hawking is still with us ..............
