Results 1 to 2 of 2
Thread: Blynk Support for Teensy boards running Ethernet shields
    Jan 2020
    Toronto, Canada
    25
    https://github.com/khoih-prog/BlynkEthernet_WM
    This is the library designed to help you eliminate hardcoding your Blynk Credentials in Teensy (3.x, 4.0) and Arduino Mega 1280, Mega 2560 boards using Ethernet shields (W5100, W5200, W5500, etc).
    You can update Blynk Credentials any time you need to change via Configure Portal. Data are saved in configurable locations in EEPROM.
    This is the link to Blynk
    http://docs.blynk.cc
    Blynk was designed for the Internet of Things. It can control hardware remotely, it can display sensor data, it can store data, visualize it and do many other cool things.
    Jan 2020
    Toronto, Canada
    25
    Update Feb 20th 2020
    Releases v1.0.6
    ***New in this version***
    1. Add support for ENC28J60 Ethernet shields and other boards such as SAMD, etc,
    2. Add checksum
    3. Add more examples for ENC28J60 shields
