Results 1 to 7 of 7
Thread: MIDI and Sleep/Wake
    Feb 2020
    4
    MIDI and Sleep/Wake
    A couple of questions regarding MIDI and sleep and wake up in Windows.
    1) After waking up Windows from sleep, my teensy USB-MIDI does not respond until I reset the DAW settings. My Roland USB-MIDI keyboard doesnt have this behaviour and works right away after waking up. Any way of making the teensy work like the Roland?
    2) Is there a way to wake up Windows with a teensy in USB-MIDI mode (like a mouse would)?
    Thanks!
    Apr 2021
    3
    Quote Originally Posted by tomas1808 View Post
    Hi
    I am having the same issue with sleep disconnecting the USB-MIDI and also have a device (Arduino Leonardo) that does not have this issue. id you ever find a fix?
    Feb 2020
    4
    No, unfortunately. I didn't dig too deeply, though. So don't be discouraged!
    Apr 2021
    3
    Thanks. what version of the teensy were you using? i am wondering if it version specific or a problem with the built in midi library or something else. i am using a 4.1
    Feb 2020
    4
    Quote Originally Posted by TomW1605 View Post
    I have like 10 active projects at any given type so it gets really difficult remembering these things. However I seem to remember it was actually a 'ProMicro' Arduino Clone using the teensy libraries. Pretty sure I didn't have an actual teensy a year ago.
    Apr 2021
    3
    ok thanks. that seams pretty conclusively that it is a thing with the library. maybe there is a keep alive message that it is not sending that i need to look into.
    Feb 2020
    4
    If you figure it out please let me know!
