Results 1 to 7 of 7
Thread: Sending data from C# to Teensy 3.2 over Bluetooth HC-05 module?
    Feb 2020
    10
    I am attempting to send data from a C# GUI to the Teensy 3.2 via the OUTGOING Bluetooth port on my PC but am having no luck. The data transfer is working in the opposite direction (sending data from Arduino to C# GUI). I am using the INCOMING Bluetooth port on Putty to try to see the "test string" but am getting no results. I am, however, getting a constant string of -1s????
    Teensy code:
    #define HWSERIAL Serial1
      HWSERIAL.begin(9600);
      String command = HWSERIAL.read();
      HWSERIAL.print(command);
      HWSERIAL.println();
    C# code (I am basically just sending a test string on repeat):
     private void button11_Click(object sender, EventArgs e)
                portBTSend = new SerialPort("COM24", 9600, Parity.None, 8, StopBits.One);
                portBTSend.RtsEnable = true;
                portBTSend.DtrEnable = true;
                try
                    portBTSend.Open();
                catch (Exception e1)
                    label8.Text = "Connection to BT Failed. Try Again";
                while () {
                    portBTSend.Write("TEST STRING");
                    System.Threading.Thread.Sleep(1000);
    Feb 2020
    10
    bumpppppppp
    939
    • Does the code work if you connect the Teensy directly without the bluetooth?
    • Looks like you never close the port and try to reopen whenever you hit the button? The usual way to do it is to store the SerialPort variable somewhere and open/close on demand. Normally you'd open on program start and close when you leave the app. Never forget to close or dispose the port before you quit the application otherwise it will lock the port.
    • The teensy code looks weird. I have no experience with the strange arduino strings, are you sure you can assign a int to a string? Did you mean readString() instead?
    Feb 2020
    10
    @luni
    1. Yes! The board works over USB serial and it works for sending data from multiple sensors to the PC via BT serial. What is not working, is sending data from the PC to the Teensy over BT serial.
    2. I have edited the code to look similar to what you are describing, this was just a first attempt at sending out something quickly.
    3. When I use readString(), the serial monitor is blank. When i use read() I get either a -1 or a little box.
    939
    Tried this c# to send Data to the teensy (tested and works fine. I linked the PC with the Teensy via a cheap usb serial converter)
    (c# console application)
    using System;
    using System.IO.Ports;
    namespace SerialTester
        class Program
            static void Main(string[] args)
                Console.WriteLine("Enter Text, send with RETURN key, Empty line quits");
                using (var port = new SerialPort("COM13", 115200))
                    port.Open();
                    var line = Console.ReadLine();
                    while (line != "")
                        port.Write(line + '\n');
    And here the receiving code on the Teensy
    HardwareSerial hwSer = Serial1;
        hwSer.begin(115200);
        while(hwSer.available())
           char c = hwSer.read();
           Serial.write(c); // echo input on Serial to inspect on SerMon
    This code will listen on Serial1 (pin1) and echo every line you type on the USB Serial port of the Teensy. So you should be able to see it on SerMon. Hope that helps to track the error down.
    Feb 2020
    10
    @luni
    Do you have a Windows Form Version of this?
    My Visual Studio is not working Console App, I can't build or run it (see picture).
    939
    Sure, don't like this ancient thing but here you are
    using System.Windows.Forms;
    namespace WinFormTest
        public partial class Form1 : Form
            public Form1()
                InitializeComponent();
            private void button1_Click(object sender, EventArgs e)
                    port.Open();
                    port.WriteLine("Hello Teensy");
    Echos "Hello Teensy" on my SerMon when you press the button.
