Page 1 of 2 1 2 LastLast
Results 1 to 25 of 30
Thread: Teensy 3.6 is very slow for some reason...
    First of all, I want to thank everyone here for their guidance. I've had a few issues with the project I'm working on and all have been resolved, EXCEPT for the new one I am encountering now.
    This is sort of related to another thread, but it's a different issue so I am creating this new post.
    Here is my last post, which seems resolved:
    https://forum.pjrc.com/threads/59554...and-Teensy-3-6
    I have a Teensy 3.6. I now have 2 PWM LED driver boards with 5 RGB LEDs connected to them (for testing, going to eventually have 17), and 3 LED displays connected to the Teensy using the SCL0 and SDA0 pins.
    When I send the LED boards messages to control the LEDs they are slow if I send a bunch of messages in fast succession, like if I send 10 messages in 30 milliseconds it might take a few seconds to display all of them. I originally guessed it was the PWM LED boards just being slow.
    But then I connected some LED displays to the SCL0 and SDA0 and sent a bunch of messages really fast and they took a few seconds to display them.
    In my previous tests, before I connected the PWM LED boards, the LED displays showed their animations pretty much instantly, no lag whatsoever. But now there is a lag.
    Maybe there is something in my code or settings that is needs to me changed? The new thing I added to the code was what was needed to communicate with the PWM LED boards.
    I added this to my void setup because it was in the example code for the PWM LED boards
     Serial.println("TLC5947 test");
      tlc.begin();
      if (oe >= 0) {
        pinMode(oe, OUTPUT);
        digitalWrite(oe, LOW);
    I ended up commenting some of it out, so like this
      //Serial.begin(9600);
     // Serial.println("TLC5947 test");
      tlc.begin();
      if (oe >= 0) {
    And it didn't seem to make a difference. I don't know if this has anything to do with it. But it might since that is what was added.
    Right now, when uploading my code to Teensy in "Tools" I select MIDI.
    Because of Serial.begin(9600)
    Should I select Serial + MIDI, or something else? I also wonder if I should change the speed in Seiral.begin to something else. But when I comment it out it doesn't seem to matter anyway.
    Is there too much PWM happening with SCL0, SDA0 and the LED boards getting sent messages on 3 digital pins, that something is getting slowed down? Any other ideas or things I can try?
    How can I get it back to being instantaneous display of messages?
    Thank you and let me know if you have any suggestions.
    10,935
    Serial.begin() is extraneous and the value always ignored on Teensy with native USB hardware.
    If Serial USB is part of the build - then it will come online as soon as the computer connects without need for the .begin().
    And entry into setup() will happen before USB can connect so to see the first messages before 50 to 500 milliseconds elapse after entry (depending on computer connection) a wait like this is required:: { while( !Serial ); } or { while( !Serial && millis()<2000 ); }
    So that should not relate to the issue. But with a wait like above the prints will show on the SerMon so you can better debug and see what is happening.
    No complete sketch showing the trouble is provided and guessing with the description isn't clear where to start, except changing the LED's every 3 ms seems fast - but not sure of the device and it's ability to respond or buffer at that rate.
    21,473
    Please follow the "Forum Rule" which appears at the top of every page on this forum. Show a *complete* program. If using libraries other than the set Teensyduino installs, please clearly state which libs you use.
    Also, please try to clearly explain what you are actually observing. When you write "now there is a lag", consider that we can not see your screen or your hardware, unless you show pictures or video. Unless you clearly describe, we do not know what action you are actually doing and then what you are actually observing which constitutes "lag". Please be specific. Avoid the common problem of saying *only* what you believe. Clearly state the things you actually do and actually observe. Ideally, your info should allow anyone with the same hardware to reproduce the same problem.
    We want to help you. Please give clearer & complete info. Helping solve problems over the internet is always challenging, but lack of complete code and clear info (and pictures or video) makes helping you much harder.
    Yes my post was pretty vague. Sorry about that. I am having a hard time articulating what's going on.
    I made a video that will help a little bit. Here is a link:
    https://www.youtube.com/watch?v=ApEM...ature=youtu.be
    I will try again to explain what is going on, because it might be hard to tell from the video.
    I am creating a MIDI controller. I have a Teensy 3.6. In the end it will have Analog sensors, Digital sensors, 4 LED displays, like the ones in the video and hopefully 17 RGB LEDs that are inside some button switches, that you can see in the video.
    The RGB LEDs are connected to a PWM LED driver. It is this product:
    https://www.adafruit.com/product/1429
    Right now I have 5 RGB LEDs connected to 2 of these PWM LED boards that are chained together. Eventually I want to have 17 of them connected to 3 PWM LED boards.
    I have been selecting USB type: MIDI when uploading my code. In the beginning of the video you can see that I am sending MIDI messages that are creating random musical pitches and they are triggering animations in the LED displays. This is working perfectly, the timing is perfectly in sync as far as I can see. While I am doing this the code that controls the RGB LEDs is not uploaded to the Teensy
    These LED displays are connected to the SCL0 and the SDA0 pins on the Teensy.
    When I upload the code that sends messages to the PWM LED driver it slows down the messages going to the LED displays that worked great before. And the messages going to the RGB LEDs are really slow, you can see in the 2nd half of the video that it takes a few seconds for them to respond to all their MIDI messages they have received to change colors. The PWM LED drivers are connected to:
    #define data 28 //
    #define clock 30
    #define latch 29
    #define oe -1 // not being used.
    I don't want to upload all the code because it is so much, including all the different colors and all the LED animations. Also I don't have any analog or digital sensors connected right now. I'm just trying to get these LEDs and LED displays working, then I'll check the sensors after that.
    If you want to see other parts of the code that I didn't upload let me know
    Here are the libraries I'm using and the info for the LED driver
    #include <Bounce.h>
    #include <Adafruit_NeoPixel.h>
    #include <Wire.h> // wire library for LED matrix
    #include "Adafruit_LEDBackpack.h"
    #include "Adafruit_GFX.h"
    #include "Adafruit_TLC5947.h"  // for LED breakout board
    // How many boards do you have chained?
    #define NUM_TLC5947 2       // how many breakout boards?
    #define data   28     // digital pins on the Teensy
    #define clock   30
    #define latch   29
    #define oe  -1  // set to -1 to not use the enable pin (its optional)  // for LED boards
    Adafruit_TLC5947 tlc = Adafruit_TLC5947(NUM_TLC5947, clock, data, latch);
    Here's my setup()
     // Serial.println("TLC5947 test");     // commenting this out. Doesn't seem to matter if it's in or not.
      tlc.begin();
    //  if (oe >= 0) {
     //   pinMode(oe, OUTPUT);
      //  digitalWrite(oe, LOW);
      // wire 3.3V to AREF for 3.3V reference
      analogReference(DEFAULT);
      pinMode(0, INPUT_PULLUP);   // for button swithces
      pinMode(1, INPUT_PULLUP);
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
      pinMode(4, INPUT_PULLUP);
      pinMode(5, INPUT_PULLUP);
      pinMode(6, INPUT_PULLUP);
      pinMode(7, INPUT_PULLUP);
      pinMode(8, INPUT_PULLUP);
      pinMode(9, INPUT_PULLUP);
      pinMode(10, INPUT_PULLUP);
      pinMode(11, INPUT_PULLUP);
      pinMode(12, INPUT_PULLUP);
      pinMode(24, INPUT_PULLUP);
      pinMode(25, INPUT_PULLUP);
      pinMode(26, INPUT_PULLUP);
      pinMode(27, INPUT_PULLUP);
      // pinMode(ledPin28, OUTPUT);   // LED on digital pin 28
      // pinMode(ledPin29, OUTPUT);   // LED on digital pin 29
      // pinMode(ledPin30, OUTPUT);   // LED on digital pin 30
      // pinMode(ledPin31, OUTPUT);   // LED on digital pin 31
      // pinMode(ledPin32, OUTPUT);   // LED on digital pin 32
      // pinMode(ledPin33, OUTPUT);   // LED on digital pin 33
      usbMIDI.setHandleControlChange(myControlChange);
      setupLedDisplays();
    Here's my loop(). I noticed i have some variables in between setup() and Loop(), I included those.
    // store previously sent values, to detect changes
    int previousA0 = -1;
    int previousA1 = -1;
    int previousA2 = -1;
    int previousA3 = -1;
    int previousA4 = -1;
    int previousA5 = -1;
    int previousA6 = -1;
    int previousA7 = -1;
    int previousA8 = -1;
    int previousA9 = -1;
    int previousA10 = -1;
    int previousA11 = -1;
    int previousA12 = -1;
    elapsedMillis msec = 0;
        button0.update();    //  this button code works, goes from 0 to 127 when pressed
        button1.update();
        button2.update();
        button3.update();
        button4.update();
        button5.update();
        button6.update();
        button7.update();
        button8.update();
        button9.update();
        button10.update();
        button11.update();
        button12.update();
        button24.update();
        button25.update();
        button26.update();
        button27.update();
        if (button0.fallingEdge()) {                               // this deals with reading the button swithces
          usbMIDI.sendControlChange(controllerD14, 127, channel);
        if (button0.risingEdge()) {
          usbMIDI.sendControlChange(controllerD14, 0, channel);
        if (button1.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD15, 127, channel);
        if (button1.risingEdge()) {
          usbMIDI.sendControlChange(controllerD15, 0, channel);
        if (button2.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD16, 127, channel);
        if (button2.risingEdge()) {
          usbMIDI.sendControlChange(controllerD16, 0, channel);
        if (button3.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD17, 127, channel);
        if (button3.risingEdge()) {
          usbMIDI.sendControlChange(controllerD17, 0, channel);
        if (button4.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD18, 127, channel);
        if (button4.risingEdge()) {
          usbMIDI.sendControlChange(controllerD18, 0, channel);
        if (button5.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD19, 127, channel);
        if (button5.risingEdge()) {
          usbMIDI.sendControlChange(controllerD19, 0, channel);
        if (button6.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD20, 127, channel);
        if (button6.risingEdge()) {
          usbMIDI.sendControlChange(controllerD20, 0, channel);
        if (button7.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD21, 127, channel);
        if (button7.risingEdge()) {
          usbMIDI.sendControlChange(controllerD21, 0, channel);
        if (button8.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD22, 127, channel);
        if (button8.risingEdge()) {
          usbMIDI.sendControlChange(controllerD22, 0, channel);
        if (button9.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD23, 127, channel);
        if (button9.risingEdge()) {
          usbMIDI.sendControlChange(controllerD23, 0, channel);
        if (button10.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD24, 127, channel);
        if (button10.risingEdge()) {
          usbMIDI.sendControlChange(controllerD24, 0, channel);
        if (button11.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD25, 127, channel);
        if (button11.risingEdge()) {
          usbMIDI.sendControlChange(controllerD25, 0, channel);
        if (button12.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD26, 127, channel);
        if (button12.risingEdge()) {
          usbMIDI.sendControlChange(controllerD26, 0, channel);
        if (button24.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD27, 127, channel);
        if (button24.risingEdge()) {
          usbMIDI.sendControlChange(controllerD27, 0, channel);
          if (button25.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD28, 127, channel);
          if (button25.risingEdge()) {
          usbMIDI.sendControlChange(controllerD28, 0, channel);
          if (button26.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD29, 127, channel);
          if (button26.risingEdge()) {
          usbMIDI.sendControlChange(controllerD29, 0, channel);
          if (button27.fallingEdge()) {
          usbMIDI.sendControlChange(controllerD30, 127, channel);
          if (button27.risingEdge()) {
          usbMIDI.sendControlChange(controllerD30, 0, channel);
      // only check the analog inputs 50 times per second,
      // to prevent a flood of MIDI messages
      if (msec >= 3) {               //  i changed this value to 10 from 20 for faster updates
        msec = 0;
        int n0 = map(analogRead(A0), 0, 1023, 0, 127);
        int n1 = map(analogRead(A1), 0, 1023, 0, 127);
        int n2 = map(analogRead(A2), 0, 1023, 0, 127);
        int n3 = map(analogRead(A3), 0, 1023, 0, 127);
        int n4 = map(analogRead(A4), 0, 1023, 0, 127);
        int n5 = map(analogRead(A5), 0, 1023, 0, 127);
        int n6 = map(analogRead(A6), 0, 1023, 0, 127);
        int n7 = map(analogRead(A7), 0, 1023, 0, 127);
        int n8 = map(analogRead(A8), 0, 1023, 0, 127);
        int n9 = map(analogRead(A9), 0, 1023, 0, 127);
        int n10 = map(analogRead(A14), 0, 1023, 0, 127);
        int n11 = map(analogRead(A15), 0, 1023, 0, 127);
        int n12 = map(analogRead(A16), 0, 1023, 0, 127);
        // only transmit MIDI messages if analog input changed
        if (n0 != previousA0) {
          previousA0 = n0;
          if (n0 < 2) n0 = 0;
          usbMIDI.sendControlChange(controllerA0, n0, channel);
        if (n1 != previousA1) {
          previousA1 = n1;
          if (n1 < 2) n1 = 0;
          usbMIDI.sendControlChange(controllerA1, n1, channel);
        if (n2 != previousA2) {
          previousA2 = n2;
          if (n2 < 2) n2 = 0;
          usbMIDI.sendControlChange(controllerA2, n2, channel);
        if (n3 != previousA3) {
          previousA3 = n3;
          if (n3 < 2) n3 = 0;
          usbMIDI.sendControlChange(controllerA3, n3, channel);
        if (n4 != previousA4) {
          previousA4 = n4;
          if (n4 < 2) n4 = 0;
          usbMIDI.sendControlChange(controllerA4, n4, channel);
        if (n5 != previousA5) {
          previousA5 = n5;
          if (n5 < 2) n5 = 0;
          usbMIDI.sendControlChange(controllerA5, n5, channel);
        if (n6 != previousA6) {
          previousA6 = n6;
          if (n6 < 2) n6 = 0;
          usbMIDI.sendControlChange(controllerA6, n6, channel);
        if (n7 != previousA7) {
          previousA7 = n7;
          if (n7 < 2) n7 = 0;
          usbMIDI.sendControlChange(controllerA7, n7, channel);
        if (n8 != previousA8) {
          previousA8 = n8;
          if (n8 < 2) n8 = 0;
          usbMIDI.sendControlChange(controllerA8, n8, channel);
        if (n9 != previousA9) {
          previousA9 = n9;
          if (n9 < 3) n9 = 0;
          usbMIDI.sendControlChange(controllerA9, n9, channel);
        if (n10 != previousA10) {
          previousA10 = n10;
          if (n10 < 3) n10 = 0;
          usbMIDI.sendControlChange(controllerA10, n10, channel);
        if (n11 != previousA11) {
          previousA11 = n11;
          if (n11 < 3) n11 = 0;
          usbMIDI.sendControlChange(controllerA11, n11, channel);
        if (n12 != previousA12) {
          previousA12 = n12;
          if (n12 < 3) n12 = 0;
          usbMIDI.sendControlChange(controllerA12, n12, channel);
      // MIDI Controllers should discard incoming MIDI messages.
      // http://forum.pjrc.com/threads/24179-Teensy-3-Ableton-Analog-CC-causes-midi-crash
      while (usbMIDI.read()) {
        // ignore incoming messages
    Here's part of the code that controls or sends messages to change the RGB LED colors. I'm not going to include all of it, but you should get the idea.
    void myControlChange(byte channel, byte control, byte value) // for LEDs, MIDI output
      if (channel == MIDIchannel                 // going to try eliminating 2nd write
          && control == ledcontroller15
          && value == 0)
        tlc.setLED(0, 0, 0, 0);    //off
      tlc.write();
    //  tlc.write();
          && value == 10)
        tlc.setLED(0, 246, 84, 106);  //light pink
      tlc.write();
     // tlc.write();
          && value == 20)
        tlc.setLED(0, 0, 0, 255);        //blue
      tlc.write();
     // tlc.write();
          && value == 30)
        tlc.setLED(0, 90, 0, 255);        //lavender
      tlc.write();
     // tlc.write();
    If you want to see other parts of the code let me know.
    I'm still trying to figure out what's going on with this code issue (hopefully that's what it is)
    Because I am using SCL0 and SDA0 for the LED displays, and that happens on the same pins that are A5 and A4, I commented out the code pertaining to A4 and A5 in my loop()
    So my loop() now has
      //  int n4 = map(analogRead(A4), 0, 1023, 0, 127);   //commented this out for SCL0 and SDA0
      //  int n5 = map(analogRead(A5), 0, 1023, 0, 127);
    It didn't seem to change anything relating to my timing issue. But I think I needed to fix that anyway.
    If anyone has any suggestions or things I should try please let me know. I think I am pretty much out of ideas.
    Thanks, Nick.
    Hi all,
    I am just updating you all to something else that I tried. It didn't work, but I am adding it here to document it and in case it inspires someone to think of something else I should try.
    The LED displays I have connected (that you can see in the video) are connected to SCL0 and SDA0 on the Teensy, which is digital pins 19 and 18 respectively.
    I figured I should have the LED drivers connected to the same Data and Clock pins. It made sense to me.
    So I changed my code to be like this:
    #define data   18     // digital pins on the Teensy, SDA0 and SCL0
    #define clock   19
    #define latch   29
    I tried that and it didn't work
    Actually, now when I send the LED displays a message I see the RGB LEDs changing colors so it is not at all a good idea.
    If anyone else has an idea I should try to resolve this let me know. I hope I can somehow work this out.
    209
    I watched the video and read the posts... I think I understand what he's asking. The problem has nothing to do with the teensy, it's related to the driver code: https://github.com/adafruit/Adafruit...it_TLC5947.cpp
    The driver code uses software SPI (to make it compatible with as many different microcontrollers as possible) rather than hardware SPI. Software SPI is slow enough that it just takes a while to clock all the data out. If you are really set on using the TLC5947 chips, you'll need to either find a driver library that uses hardware SPI, or write it yourself. Alternatively, if you could switch to using WS2812 RGB LEDs, you could use Paul's driver library: https://www.pjrc.com/non-blocking-ws2812-led-library/ Which should be much higher performance, and it's non-blocking as well so it will stay responsive to incoming MIDI messages.
    Anyway... hope that helps.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,325
    Nice answer....
    I suspect the midi code is a problem too.
    Have you checked how much midi noise it's generating?
    I suspect there will be a lot of alternating and adjacent CC messages.
    This won't slow your Teensy down much but it might make it feel less responsive as the master stuggles to process the midi queue.
    And turning down the time limit between messages, which code comments imply you have, could make it worse not better.
    Potentiometer noise is a rich subject for DIY midi but theResponsiveAnalogRead library is the easy answer for taming voltage readings for MIDI on Teensy.
    Hi wcalvert
    Thank you for the reply. Yes, the problem is not with the Teensy, as when i delete the code related to the Adafruit LED driver everything works fine. I should change the name of this thread.
    OK I am so happy that there is a Teensy library to deal with this problem! amazing.
    So if I can't use the TLC5947 chips do you have a suggestion of how to connect my RGB LEDs? This project is based around a Teensy 3.6, but there's not enough pins to do everything with one of those. Can I connect another Teensy to the 3.6? I'm planning on 17 RGB LEDs so that's 51 LED pins I will need.
    Thank you for your input, I had a feeling it had something to do with that Adafruit board.
    EDIT:
    Ok, I read through this page:
    https://github.com/PaulStoffregen/WS.../BasicTest.ino
    I think if I understand this correctly I don't need any extra hardware, I just connect my LEDs to one pin. then connect them together in a chain.
    But I am not using Neopixels, or any kind of LED with a chip in it. I have a button switch that has RGB LEDs in it. Each one of these has 2 pins for the button switch part (which I am guessing I won't use for this) and 3 pins for R G and B and one pin for power, connected to Vin.
    Will this still work? or do I need to try and find a different button switch with a Neopixel type LED in it?
    thanks again.
    Hi Oddson.
    Thanks for the input. Right now the midi code and sensors work fine. You are probably right in that it can be optimized to work better/faster. But in my previous version of this code the midi input and output is fine. For what I'm doing I only read MIDI data at one control change controller number at a time so the noise is ignored or filtered out in the music software I use (Max).
    I'm going to focus on this LED issue for now. Then revisit the MIDI messages. I'll look at the ResponsiveAnalogRead library again.
    Thank you for taking a look at this.
    Feb 2013
    1,325
    Arrays make multi channel things much easier.
    Your code does check-for-change after rounding 3 bits so it's likely stable unless the voltage is very near a rounding threshold at 7 bits.
    It should improve with more permanent wiring
    209
    I was googling and found this library which does use hardware SPI: https://github.com/ramonaoptics/TLC5947
    You might give it a try. He has tested it with a Teensy 3.2 at least.
    Hey wcalvert,
    Wow this library you found is nice. And in the example he's using the same chip in the LED driver I have, TLC5947.
    I will give this a try and let you know how it works out.
    I was worried that I would have to re-envision this thing i'm making because I can't find a button switch that has RGB LEDs AND a Neopixel type LED in it after googleing around for an hour.
    Anyway I really appreciate the input from everyone chiming in.
    Thank you and I'll report back once I integrate this library into my code.
    Hey everyone,
    I am running into an issue that I can't really figure out. It seems simple though.
    I downloaded this TLC5947 Library from here:
    I tried to verify the example code in Arduino software v. 1.8.8 and I got error messages. Having something to do with the line describing how many chips are being used:
    const uint8_t TLC5947::_tlc_count = 1;          // Change to reflect number of TLC chips
    I integrated this example code into my project code and was getting the same errors. I can't quite figure this out
    Here is the example code:
       TLC5947 Control Library
       Used to control the TI TLC5947 LED driver chip
       Zack Phillips - zkphil@berkeley.edu
       Product Page: http://www.ti.com/product/tlc5947
       Copyright (c) 2018, Zachary F. Phillips
       All rights reserved.
       Redistribution and use in source and binary forms, with or without
       modification, are permitted provided that the following conditions are met:
       Redistributions of source code must retain the above copyright
          notice, this list of conditions and the following disclaimer.
       Redistributions in binary form must reproduce the above copyright
          notice, this list of conditions and the following disclaimer in the
          documentation and/or other materials provided with the distribution.
       Neither the name of the <organization> nor the
          names of its contributors may be used to endorse or promote products
          derived from this software without specific prior written permission.
       THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
       ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
       DISCLAIMED. IN NO EVENT SHALL Z. PHILLIPS BE LIABLE FOR ANY
       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "TLC5947.h"
    #include "SPI.h"
    // Pin set-up
    #define GSCLK 6
    #define LAT 2
    #define SPI_MOSI 11
    #define SPI_CLK 13
    float TLC5947::max_current_amps = 10;      // Maximum current output, amps
    bool TLC5947::enforce_max_current = false;   // Whether to enforce max current limit
    // Define dot correction, pin rgb order, and grayscale data arrays in program memory
    uint8_t TLC5947::_dc_data[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
    uint8_t TLC5947::_rgb_order[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
    uint16_t TLC5947::_grayscale_data[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
    // Create TLC5947 object
    TLC5947 tlc;
      // Set pins (non-serial) to output mode
      pinMode(GSCLK, OUTPUT);
      pinMode(LAT, OUTPUT);
      // Adjust PWM timer for maximum GSCLK frequency
      analogWrite(GSCLK, 127);
      // The library does not ininiate SPI for you, so as to prevent issues with other SPI libraries
      SPI.begin();
      tlc.init(LAT, SPI_MOSI, SPI_CLK);
      // We must set dot correction values, so set them all to the brightest adjustment
      tlc.setAllDcData(127);
      // Set Max Current Values (see TLC5947 datasheet)
      tlc.setMaxCurrent(3, 3, 3); // Go up to 7
      // Set Function Control Data Latch values. See the TLC5947 Datasheet for the purpose of this latch.
      // Order: DSPRPT, TMGRST, RFRESH, ESPWM, LSDVLT
      tlc.setFunctionData(true, true, true, true, true);
      // set all brightness levels to max (127)
      int currentR = 127;
      int currentB = 127;
      int currentG = 127;
      tlc.setBrightnessCurrent(currentR, currentB, currentG);
      // Update Control Register
      tlc.updateControl();
      // Provide LED pin order (R,G,B)
      tlc.setRgbPinOrder(0, 1, 2);
    Also, I might as well ask this since I am making this post. From the Adafruit board you have these pins:
    LAT
    OE
    CLK
    DIN
    In this library it is asking for
    GSCLK
    LAT
    SPI_MOSI
    SPI_CLK
    I am thinking LAT = LAT, SPI_CLK = CLK, SPI_MOSI = DIN and GSCLK = OE
    Does that seem right? Also does it matter what pins I use on the Teensy 3.6? On the diagram of pins I see a couple labeled as MOSI.
    Thanks again.
    Nick
    10,935
    These two pin values match standard Teensy SPI so start with them:
    #define SPI_MOSI 11
    #define SPI_CLK 13
    Assuming it is write only there is likely no need for MISO pin.
    But for SPI bus there should be a CS pin to chip select that device to respond - given this:: tlc.init(LAT, SPI_MOSI, SPI_CLK);
    > That would appear to be LAT for CS and that shouldn't require a special pin in this case - but aiming for a CS0 pin can't hurt.
    Prior posts IIRC mention OE as perhaps output enable to enable/disable output power to LEDs?
    With one board this should be easy. If you have more than 1 for _tlc_count = 1; - start with one - then figure out how that applies tp connections needed.
    Aug 2018
    Brisbane, Australia
    13
    static const int _tlc_count; //
    The type of _tlc_count in the header file is int, not uint8_t
    Hi thebigg
    Ok I changed the line you specified to
     const int TLC5947::_tlc_count = 1;          // Change to reflect number of TLC chips
    But now I'm getting errors further down in the code. I tried, int, const int, etc.
    What do you think I should declare these other variables as? The float and the bool are fine. I'm just getting errors after that, with what I declared as const int, which isn't working.
    const int TLC5947::_dc_data[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
     const int TLC5947::_rgb_order[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
     const int TLC5947::_grayscale_data[TLC5947::_tlc_count][TLC5947::LEDS_PER_CHIP][TLC5947::COLOR_CHANNEL_COUNT];
    thanks, Nick
    10,935
    @nicnut - posting the error text presented can help a great deal - not seeing that in post #14 above didn't explain the problem or show there was one.
    With error text in #17 it might be possible to provide help without having the library at hand.
    Aug 2018
    Brisbane, Australia
    13
    Open TLC5947.h in your favourite editor and have a look...
    static uint8_t _rgb_order[][LEDS_PER_CHIP][COLOR_CHANNEL_COUNT];
    static uint16_t _grayscale_data[][LEDS_PER_CHIP][COLOR_CHANNEL_COUNT];
    There is no _dc_data though. Seems the example is out of step with the library
    Hi defragster,
    Ok I'm going to post the original example code and the error test as well.
    example:
    #include "SPI.h"
    // Pin set-up
    #define GSCLK 6
    #define LAT 2
    #define SPI_MOSI 11
    #define SPI_CLK 13
    TLC5947 tlc;
      SPI.begin();
      int currentR = 127;
      int currentB = 127;
      int currentG = 127;
    Error Messages:
    Arduino: 1.8.8 (Mac OS X), TD: 1.45, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz (overclock), Faster, US English"
    TLC5947:39: error: conflicting declaration 'const uint8_t TLC5947::_tlc_count'
    In file included from /sequences/Arduino/libraries/TLC5947-master/examples/TLC5947/TLC5947.ino:30:0:
    /sequences/Arduino/libraries/TLC5947-master/TLC5947.h:94:18: note: previous declaration as 'const int TLC5947::_tlc_count'
    TLC5947:39: error: declaration of 'const int TLC5947::_tlc_count' outside of class is not definition [-fpermissive]
    TLC5947:44: error: 'uint8_t TLC5947::_dc_data [1][8][3]' is not a static data member of 'class TLC5947'
    TLC5947: In function 'void setup()':
    TLC5947:62: error: no matching function for call to 'TLC5947::init(int, int, int)'
    /sequences/Arduino/libraries/TLC5947-master/TLC5947.h:56:6: note: candidate: void TLC5947::init(int8_t, int8_t, uint8_t, uint8_t, uint8_t)
    void init(int8_t num_latches, int8_t num_tlc_one_row, uint8_t spi_mosi, uint8_t spi_clk, uint8_t blank);
    /sequences/Arduino/libraries/TLC5947-master/TLC5947.h:56:6: note: candidate expects 5 arguments, 3 provided
    TLC5947:65: error: 'class TLC5947' has no member named 'setAllDcData'
    TLC5947:68: error: 'class TLC5947' has no member named 'setMaxCurrent'
    TLC5947:72: error: 'class TLC5947' has no member named 'setFunctionData'
    TLC5947:81: error: 'class TLC5947' has no member named 'updateControl'
    To thebigg: Yes I tried every different combination of variables and nothing seemed to work. Something is off or missing.
    Thank you everyone for taking a look.
    Nick
    EDIT:
    I posted about this error on the github. I got this message from someone on there:
    "Yeah... This library isn't exactly stable.
    Trust us that it works, just that the example was not kept up to date.
    We made some bad decisions in terms of the hardware design that cause this code to be more complicated than it should be."
    Hey everyone,
    I'm still working on this issue. I am giving up on that library above for now because I can't get it the example code to compile.
    I did find a thread on this forum which is giving me hope, and is basically the exact same problem I am facing:
    https://forum.pjrc.com/threads/42214...ng-SPI-library
    This person altered the library from Adafruit and is able to use it with SPIwrite()
    I uploaded their altered library and tried running their test code but it's not working for me.
    Here is their version of the library with the alterations. You need the #include <Adafruit_TLC5947.h> file.
    https://forum.pjrc.com/attachment.ph...1&d=1488089542
    I did alter their test code so that it reflects what is suggested in the thread. Namely:
      pinMode(latch, OUTPUT);
      digitalWrite(latch, LOW);
      pinMode(clock, OUTPUT);
      digitalWrite(clock, LOW);
      pinMode(data, OUTPUT);
      digitalWrite(data, LOW);
        SPI.setCS(10);
        SPI.setMOSI(11);
        SPI.setSCK(13);*/
      SPI.begin();
      //tlc.begin();
     Serial.begin(38400);
     Serial.println("TLC5974_SPI test");
    I am wondering if it is because I need to use different pins for latch, clock, data and oe.
    I am using a Teensy 3.6 with these pins:
    const int slaveSelectPin = 29;
    #define clock 30 // 10
    #define data 28
    #define oe  27  //  12
    #define latch  29 // 11
    #define NUM_TLC5974 10
    Here is all the test code I am using. Nothing is happening when I run it. I know everything is connected correctly because the tlc.write() version of this code is working.
    Any suggestions on what I can try to make this work with SPIwrite() ?
    #define data 28
    #define oe  27  //  12
    unsigned long frame;
    Adafruit_TLC5947 tlc = Adafruit_TLC5947(NUM_TLC5974, clock, data, latch,  oe);
    unsigned long tick, dur;
        SPI.setCS(10);
        SPI.setMOSI(11);
        SPI.setSCK(13);*/
      SPI.begin();
      //tlc.begin();
      tick = micros();
      colorWipe(100, 0, 0); // "Red" (depending on your LED wiring);
      Serial.print((micros() - tick));
      Serial.print("  red used");
      Serial.println("  us");
      delay(300);
      tick = micros();
      colorWipe(0, 100, 0); // "Green" (depending on your LED wiring);
      Serial.print("  green used");
      delay(300);
      tick = micros();
      colorWipe(0, 0, 100); // "Blue" (depending on your LED wiring);
      Serial.print("  blue used");
      delay(300);
      tick = micros();
      colorWipe(5, 5, 5); // "Blue" (depending on your LED wiring);
      Serial.print("  white used");
    void colorWipe(uint16_t r, uint16_t g, uint16_t b) {
      for (uint16_t i = 0; i < 8 * NUM_TLC5974; i++) {
        tlc.setLED(i, r, g, b);
      SPIwrite();
    void SPIwrite() {
    #define TSPEED 1000000 //1Mhz
      unsigned int chan1 = 0;
      unsigned int chan2 = 0;
      byte address1 = 0;
      byte address2 = 0;
      byte address3 = 0;
      SPISettings TLC5947(TSPEED , MSBFIRST, SPI_MODE0);
      // packing each 2 channel (12bit*2) to 3 byte (8bit*3) for transfering
      SPI.beginTransaction(TLC5947);
      // digitalWriteFast(latch, HIGH);
      digitalWriteFast(latch, LOW);
      for (unsigned int ledpos = 24  * NUM_TLC5974 ; ledpos > 0; ledpos = ledpos - 2) {
        chan1 = tlc.getCHAN(ledpos - 1);
        chan2 = tlc.getCHAN(ledpos - 2);
        address1 = (byte)(chan1 >> 4) ;
        address2 = (byte)((chan1 << 4) & (B11110000)) + (byte)((chan2 >> 8) & (B00001111));
        address3 = (byte)chan2;
        /* address1 = B00000000;
          address2 = B00000000;
          address3 = B00000000;*/
        SPI.transfer(address1);
        SPI.transfer(address2);
        SPI.transfer(address3);
      SPI.endTransaction();
      //  digitalWriteFast(latch, LOW);
      digitalWriteFast(clock, LOW);
    10,935
    Looking at a Teensy Card it indicates the hardware pins for the busses - for SPI hardware usage the appropriate pins or alternates need to be used. As shown in post #15
    These are specified for a reason, not sure if they are not available? But if not those pins then acceptable alternates must be selected for function:
    SPI.setCS(10);
    SPI.setMOSI(11);
    SPI.setSCK(13);*/
    209
    I just bought a TLC5947 board, I will get it working when I have time, unless someone beats me to it. Maybe this weekend?
    defragster,
    thank you for your help. I changed the pins and tried the test patch again. No luck
    I tried it with
    const int slaveSelectPin = 10;
    #define clock 13 // 10
    #define data 11
    #define oe  12  //  12
    #define latch  10 // 11
    #define NUM_TLC5974 5
    and
    const int slaveSelectPin = 11;
    #define clock 10 // 10
    #define data 13
    #define oe  12  //  12
    #define latch  11 // 11
    I put the full example code below. Hm, I don't know what else to try. I'm pretty sure the hardware is set up correctly..
    #define data 11
    #define oe  12  //  12
        SPI.setCS(10);
        SPI.setMOSI(11);
        SPI.setSCK(13);*/
      SPI.begin();
      //tlc.begin();
      tick = micros();
      delay(300);
      tick = micros();
      delay(300);
      tick = micros();
      delay(300);
      tick = micros();
      SPIwrite();
    void SPIwrite() {
      byte address1 = 0;
      byte address2 = 0;
      byte address3 = 0;
    @wcalvert it works easily with the Adafruit example code and software SPI. It's just slower.
    I hope I beat you to it, I've been at this for weeks now! lol
