mpasternacki
I'm designing a battery-powered Teensy 4 project. It will run off 18650 Li-Ion and I hope to get away with using a single cell and not having to worry as much about battery management and all the "don't let the batteries explode" that goes with multiple cells.
If I cut the VUSB/+5V trace, is +5V used anywhere except LDO input? The info card says that it accepts as low as 3.6V , which means I can feed it directly from the cell (and avoid discharging it below 3.6V, which should improve battery life), but will the voltage be used anywhere else?
I will need +5V for powering WS28xx LEDs, so I'll need a boost converter anyway, but boosting voltage just to feed it back to LDO seems like a waste of watts. If the Vin voltage is used only to feed LDO, my plan would be:
- Use boost converter to power 5V section (WS28xx and a few other pieces that prefer higher voltage)
- Feed cell voltage directly to Teensy as Vin; use Teensy's 3.3V pins to power other 3.3V chips (staying within the 150mA limit)
- Use boosted 5V to check 3.3V voltage, alert and/or shutdown when it gets below 3.3V (or use 5V to check battery voltage directly and provide early warning and monitor 3.3V as another safety layer)
Does that make sense?
Another option would be a boost converter for 5V, a buck converter for 3.3V, and powering Teensy via 3.3V pins, monitoring the 3.3V regulator (difference between input and output; if the buck converter goes 100% duty, battery's dead). This would be more complex (and I'd need to make sure the 3.3V is stable enough), but then I could get more than 150mA of 3.3V for my elements, extra 0.3V worth of cell capacity, and it seems like monitoring would be simpler (just check 3.3V regulator's dropoff). Not sure how hard would it be to make it stable enough to power Teensy, though.
If the LDO is necessary to stabilize 3.3V and I want to utilize battery capacity below 3.6V, I'd either need a buck/boost 3.6V converter (maybe gain a few mAh from the conversion, but lose on complexity), or just a boost 3.6V converter that would kick in once battery gets below that 3.6.
Actually, if I feed cell voltage directly to Teensy's LDO, maybe it's worth it to add a boost converter (+ warning signal when it kicks in) as a "fuel reserve"?
What are your thoughts?
Thanks,
-- M
Thanks,
-- M
