Results 1 to 1 of 1
Thread: Audioshield stuttering playback
    Feb 2020
    3
    Audio Adaptor Board playback stuttering
    I'm trying the `Part_1_04_Blink_While_Playing` sketch on my Teensy 3.2 and Audio Adaptor Board using an SanDisk Ultra SD card and the audio starts to stutter after some time:
    https://streamable.com/jkgs6 (stuttering starts at 0:42. Serious stuttering starts at 1:00)
    Am I missing something or did I get defective hardware?
    For completeness, this is my code:
    // Advanced Microcontroller-based Audio Workshop
    // http://www.pjrc.com/store/audio_tutorial_kit.html
    // https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
    // Part 1-4: Blink LED while Playing Music
    // Do something while playing a music file.  Admittedly
    // only blink Teensy's LED and print info about the
    // playing time in the file.  The point is that Arduino
    // sketch code is free to do other work while the audio
    // library streams data from the SD card to the headphones.
    #include <SerialFlash.h>
    AudioPlaySdWav           playSdWav1;
    AudioOutputI2S           audioOutput;
    AudioConnection          patchCord1(playSdWav1, 0, audioOutput, 0);
    AudioConnection          patchCord2(playSdWav1, 1, audioOutput, 1);
    AudioControlSGTL5000     sgtl5000_1;
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    // Use these with the Teensy 3.5 & 3.6 SD card
    //#define SDCARD_CS_PIN    BUILTIN_SDCARD
    //#define SDCARD_MOSI_PIN  11  // not actually used
    //#define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
      AudioMemory(8);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.45);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
      pinMode(13, OUTPUT); // LED on pin 13
      if (playSdWav1.isPlaying() == false) {
        Serial.println("Start playing");
        playSdWav1.play("SDTEST1.WAV");
        delay(10); // wait for library to parse WAV info
      // print the play time offset
      Serial.print("Playing, now at ");
      Serial.print(playSdWav1.positionMillis());
      Serial.println(" ms");
      // blink LED and print info while playing
      digitalWrite(13, HIGH);
      delay(250);
      digitalWrite(13, LOW);
      delay(250);
      // read the knob position (analog input A2)
      int knob = analogRead(A2);
      float vol = (float)knob / 1280.0;
      sgtl5000_1.volume(vol);
      Serial.print("volume = ");
      Serial.println(vol);
