Audio Adaptor Board playback stuttering
I'm trying the `Part_1_04_Blink_While_Playing` sketch on my Teensy 3.2 and Audio Adaptor Board using an SanDisk Ultra SD card and the audio starts to stutter after some time:
https://streamable.com/jkgs6 (stuttering starts at 0:42. Serious stuttering starts at 1:00)
Am I missing something or did I get defective hardware?
For completeness, this is my code:
// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 1-4: Blink LED while Playing Music
// Do something while playing a music file. Admittedly
// only blink Teensy's LED and print info about the
// playing time in the file. The point is that Arduino
// sketch code is free to do other work while the audio
// library streams data from the SD card to the headphones.
AudioPlaySdWav playSdWav1;
AudioOutputI2S audioOutput;
AudioConnection patchCord1(playSdWav1, 0, audioOutput, 0);
AudioConnection patchCord2(playSdWav1, 1, audioOutput, 1);
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.45);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
pinMode(13, OUTPUT); // LED on pin 13
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
playSdWav1.play("SDTEST1.WAV");
delay(10); // wait for library to parse WAV info
// print the play time offset
Serial.print("Playing, now at ");
Serial.print(playSdWav1.positionMillis());
Serial.println(" ms");
// blink LED and print info while playing
digitalWrite(13, HIGH);
delay(250);
digitalWrite(13, LOW);
delay(250);
// read the knob position (analog input A2)
int knob = analogRead(A2);
float vol = (float)knob / 1280.0;
sgtl5000_1.volume(vol);
Serial.print("volume = ");
Serial.println(vol);
