Ws2811 pixels occasional flashing when white - even when brightness turned right down
I'm wondering if anyone can help me get to the bottom of this issue.
I've got a pixel matrix controlled by a Teensy 3 with OctoWs2811 shield, 138 x 22 using 6 of the outputs. Software is currently Jinx!
I'm getting occasional flashes when I set the pixels to white or near white. The brightness is set to half in my Teensy sketch and usually half again in software.
Even if I turn the brightness down very low I get the flashes but with other colours and patterns it seems fine.
here's a link to a video
I don't get it! Anyone got any ideas?
Thanks.
Edit*** It just occurred to me that it might be a voltage issue as lighting pixels white uses the most voltage.....I think? I will check the voltage tomorrow. I thought I had sufficient gauge wires and power injection (every 184 pixels) but I should check.
They are 12V Pixels. I've never really understood how the conversion from 12>5V is done with pixels. But I guess if you have <12V it get's converted to <5V?
Can you post the code you're running on the Teensy 3? Your video looks similar to an issue I'm seeing with my ws2811 setup.
- You may not post replies
- You may not edit your posts
Forum Rules
