Results 1 to 3 of 3
Thread: Teensy 3.2 using internal RTC adding crystal
    In the Time library page is mentioned to ad a crystal and a coincell battery to the Teensy 3.2 to use the internal RTC.
    What does “12.5 pF” mean?
    Do I also need to add a capacitor?
    https://www.pjrc.com/teensy/td_libs_Time.html
    Quote :
    “TimeTeensy3 Example Program
    TimeTeensy3 demonstrates synchronizing Time to the Real Time Clock in Teensy 3.0, 3.1, 3.2, 3.5 & 3.6.
    To use the Teensy 3.0, 3.1 & 3.2 RTC, you must add a 32.768 kHz, 12.5 pF crystal to the bottom side of the board.
    Nov 2015
    Cold hollow VT
    188
    The 12.5pf is a specification of the crystal to buy. You do not have to add 12.5pf capacitor to the Teensy board. Just get the crystal indicated a few words later, solder it to the Teensy, connect a 3v coin cell and you're goo to go.
    answered. Teensy 3.2 using internal RTC adding crystal
    All clear now. Thanks for the info.
    Quote Originally Posted by grease_lighting View Post
Tags for this Thread
