Results 1 to 2 of 2
Thread: IOT Automotive Fuse Box Indicator
    Jun 2018
    10
    good day
    I am trying to use the teensy 3.5 or 3.6 to create an Automotive/machine fuse box monitor. All it must do is to read the status of 12 fuses and signal what fuse is blown. how would i accomplish this with a teensy board? they are 12/24v fuses. I know its an open-closed circuit but i am stuped on how to accomplish this in real life.
    I also need to read the values of a VDO oil pressure MEter and VDO water Temp Meter, both are analog.
    As always your assistace is valued.
    Thank you Gary
    Jun 2018
    10
    Quote Originally Posted by gary01 View Post
    good day
    Thank you Gary
    Just for any one else, I managed to solve the fuse box issue by using a 2k resistor and a 3.3v Zener Diode. wired after the fuse to a digital pin. If pin High. Fuse is ok, if low then fuse is blown.
    I am still trying to figure out the VDO oil pressure sensor and Temp Sensor. any help would be appreciated.
