I'm trying to enable the RxD Input Active Edge Interrupt on the UART0 module. The idea is that after an active edge interrupt is triggered, the Teensy should read the data that is being received and then do nothing until more data arrives. Later on I want to set up the Teensy to sleep while no data is being received, the interrupt will be responsible for waking the teensy up. Here is my code so far:
My problem with this code is that after the ISR has been executed and the code in the (isFlagSet){...} never returns the data that is being received. Serial1.available() seems to always return 0. It would be nice if someone can give me some tips to solve the problem. I'm using a Teensy 3.2.
#include <Arduino.h>
#include "kinetis.h"
volatile uint8_t incomingByte; //variable used to save the value of the incomig byte
volatile bool isFlagSet = false;
void blink();
void isr();
int main() {
pinMode(13, OUTPUT); //LED pin
Serial.begin(9600); //start USB serial interface
Serial1.begin(9600); //start UART0 module
//wait for the module to start
while(!Serial){
blink();
uint8_t temp = UART0_BDL;
//Disable the transmitter and the receiver before changing the configuration
UART0_C2 &= ~(1<<3);
UART0_C2 &= ~(1<<2);
UART0_BDH |= (1<<6); //Input Active Edge Interrupt Enable
UART0_BDL |= temp; //write the same value again to apply changes to UART0_BDH
UART0_C2 &= ~UART_C2_ILIE; //deactivate Idle Line Interrupt Enable, receiver full
UART0_C2 &= ~(1<<5); //RDRF interrupt and DMA transfer requests disabled.
//Enable the receiver and transmitter again
UART0_C2 |= (1<<3);
UART0_C2 |= (1<<2);
NVIC_SET_PRIORITY(IRQ_UART0_STATUS, 64);
NVIC_ENABLE_IRQ(IRQ_UART0_STATUS); //enable interrupt in the NVIC, might be unnecessary
attachInterruptVector(IRQ_UART0_STATUS, isr); //attach custom ISR
uint16_t reps = 0;
while(1){
if(isFlagSet){
if(Serial1.available() > 0){
incomingByte = Serial1.read();
Serial.print("\nReceiving data: ");
Serial.println(incomingByte);
Serial.print("\rNo data is being received ");
Serial.println(Serial1.available());
reps++;
Serial.println(reps);
isFlagSet = false;
//reenable the interrupt
UART0_BDL |= UART0_BDL;
void blink(){
digitalWrite(13, HIGH);
delay(200);
digitalWrite(13, LOW);
delay(200);
void isr(){
__disable_irq();
NVIC_DISABLE_IRQ(IRQ_UART0_STATUS);
//disable RXEDGIE
UART0_BDH &= ~(1<<6);
// Clear interrupt flag
UART0_S2 |= (1<<6);
isFlagSet = true;
__enable_irq();
