Results 1 to 5 of 5
Thread: Unable to use the full range of potentiometer
    I am building a large midi board with 21 potentiometers, 28 buttons, eight encoders and two touch inputs. The potentiometers and buttons are multiplexed and everything seems to be working correctly. I can use the serial monitor and see all the buttons, and CC notes with the potentiometers.
    The problem is i can only use about 75% of the potentiometers range. I am able to see the full 0-7F midi notes come through on the serial monitor, but it just stops reading anything after 75% of the fader or pots, they all act the same.
    I was able to implement an analog map function, but that only allowed me to limit the range even further.
    I am using the same 5vdc regulator to supply 5vdc to all the pots and Vcc of the multiplexers and supply power to the teensy 3.1. I measured the voltage on the potentiometers and they all seeem to be very smooth through the whole range. 0- 4.9 ish.
    I would like to seee what the serial monitor sees as far as the value for the pot (0-1023) but at the moment am unable to implement this though my multiplexers.
    Do you guys think it may be code ( i know itís very messy at the moment) or is this more hardware related?
    I used this same, modified code, for a smaller midi controller with a Teensy LC. Those pots were run off the LCs on board 3.3 voltage reg and were all wired direct. That ones runs just fine, which leads me to believe itís more of a hardware issue, but am having a difficult time to know where to go from here.
    Any troubleshooting tips on this would be appreciated.
    #define USE_ROTARY_ENCODER
    #include <MIDI_Controller.h> // new line
    #include <WS2812Serial.h>
    #include "MIDIcontroller.h"
    byte MIDIchannel = 5;
    const int numled = 40;
    const int pin = 5;
    byte drawingMemory[numled * 3]; // 3 bytes per LED
    DMAMEM byte displayMemory[numled * 12]; // 12 bytes per LED
    WS2812Serial leds(numled, displayMemory, drawingMemory, pin, WS2812_GRB);
    #define RED 0x001600 //ADJUSTED FOR ADAFRUIT DIFFUSED NEOPIXLES (RED AND GREEN ARE SWAPPED) (night mode)
    #define GREEN 0x160000
    #define BLUE 0x000016
    #define YELLOW 0x141000
    #define PURPLE 0x001616
    #define ORANGE 0x041000
    #define WHITE 0x101010
    #define AQUA 0x160016
    //#define RED 0x00FF00 //ADJUSTED FOR ADAFRUIT DIFFUSED NEOPIXLES (RED AND GREEN ARE SWAPPED) (day mode)
    //#define GREEN 0xFF0000
    //#define BLUE 0x0000FF
    //#define YELLOW 0xFFFF00
    //#define PURPLE 0x00FFFF
    //#define ORANGE 0xE05800
    //#define WHITE 0xFFFFFF
    //#define AQUA 0xFF00FF
    int touchRead_pin_1 = 32;
    int touchRead_pin_2 = 33;
    int thresh = 2300;
    int play_flag_1 = 0;
    int play_flag_2 = 0;
    int current_1;
    int current_2;
    int delay_time =3;
    const int speedMultiply = 1; // No change in speed of the encoder (number of steps is multiplied by 1)
    // THESE WERE THE VALUES//
    const uint8_t velocity = 0b1111111; // Maximum velocity (0b1111111 = 0x7F = 127)
    const uint8_t C2 = 36; // Name Desired pitches and define with MIDI value
    const uint8_t D2 = 38;
    const uint8_t E2 = 40;
    const uint8_t f2 = 41;
    const uint8_t G2 = 43;
    const uint8_t a2 = 45;
    const uint8_t B2 = 47;
    const uint8_t C3 = 48;
    //const uint8_t C2 = 24; // Name Desired pitches and define with MIDI value
    //const uint8_t D2 = 26;
    //const uint8_t E2 = 28;
    //const uint8_t C1 = 18;
    //const uint8_t C3 = 30;
    //const uint8_t C5 = 48;
    //const uint8_t C6 = 54;
    //const uint8_t C7 = 60;
    //const uint8_t B8 = 77;
    //const uint8_t B0 = 17;
    //const uint8_t B1 = 23;
    //const uint8_t B4 = 47;
    const uint8_t B5 = 53;
    //const uint8_t D3 = 32;
    //const uint8_t D6 = 56;
    //const uint8_t E3 = 34;
    const static size_t analogAverage = 16; // Use the average of 8 samples to get smooth transitions and prevent noise
    const int minimumValue = 3; // the analog value read when the potentiometer is in the minimum position.
    const int maximumValue = 1023; // the analog value read when the potentiometer is in the maximum position.
    int mapCalibrated(int value) {
    value = constrain(value, minimumValue, maximumValue); // make sure that the analog value is between the minimum and maximum value
    return map(value, minimumValue, maximumValue, 0, 1023); // map the value from [minimumValue, maximumValue] to [0, 1023]
    USBDebugMIDI_Interface midiInterface(115200);
    // Create an instance of 'AnalogMultiplex' with the output pin of the multiplexer connected to
    // analog input pin A0 and the address pins connected to pins 2, 3 and 4.
    AnalogMultiplex multiplexer1(24, { 2, 3, 4 } );
    AnalogMultiplex multiplexer2(25, { 2, 3, 4 } );
    AnalogMultiplex multiplexer3(26, { 2, 3, 4 } );
    AnalogMultiplex multiplexer4(27, { 2, 3, 4 } );
    AnalogMultiplex multiplexer5(28, { 2, 3, 4 } );
    AnalogMultiplex multiplexer6(A18, { 2, 3, 4 } );
    AnalogMultiplex multiplexer7(A19, { 2, 3, 4 } );
    AnalogMultiplex multiplexer8(A20, { 2, 3, 4 } );
    //AnalogMultiplex multiplexer9(A12, { 2, 3, 4 } );
    //AnalogMultiplex multiplexer10(A13, { 2, 3, 4 } );
    Bank bank(4);
    Bank bank2(4);
    Bank bank3(8);
    Bank bank4(8);
    BankSelector bankSelector(bank, { multiplexer4.pin(7) }, 4);
    BankSelector bankSelector2(bank2, { multiplexer1.pin(0) }, 4);
    BankSelector bankSelector3(bank3, { multiplexer2.pin(2) }, 8);
    BankSelector bankSelector4(bank4, { multiplexer2.pin(2) }, 8);
    //Channel_Volume, Pan, Foot_Controller, Balance, can all have 16 inputs each for future reference.
    Analog potentiometers1[] = {
    {multiplexer6.pin(0), MIDI_CC::Channel_Volume, 1}, //RIGHT PITCH
    {multiplexer6.pin(1), MIDI_CC::Channel_Volume, 2}, //FX 2 A GAIN
    {multiplexer6.pin(2), MIDI_CC::Channel_Volume, 3}, //FX 1 MIX
    //{multiplexer6.pin(3), MIDI_CC::Channel_Volume, 4}, //BAD CHANNEL ?
    {multiplexer6.pin(4), MIDI_CC::Channel_Volume, 5}, //FX 1 B GAIN
    //{multiplexer6.pin(5), MIDI_CC::Channel_Volume, 6}, //OPEN
    {multiplexer6.pin(6), MIDI_CC::Channel_Volume, 7}, //LEFT MID
    //{multiplexer6.pin(7), MIDI_CC::Channel_Volume, 8}, //OPEN
    Analog potentiometers2[] = {
    {multiplexer7.pin(0), MIDI_CC::Foot_Controller, 1}, //LEFT HIGH
    {multiplexer7.pin(1), MIDI_CC::Foot_Controller, 2}, // FX 2 B GAIN
    {multiplexer7.pin(2), MIDI_CC::Foot_Controller, 3}, //LEFT PITCH
    {multiplexer7.pin(3), MIDI_CC::Foot_Controller, 4}, //X FADER
    {multiplexer7.pin(4), MIDI_CC::Foot_Controller, 5}, //LEFT FADER
    {multiplexer7.pin(5), MIDI_CC::Foot_Controller, 6}, // FX 2 MIX
    {multiplexer7.pin(6), MIDI_CC::Foot_Controller, 7}, //LEFT GAIN
    {multiplexer7.pin(7), MIDI_CC::Foot_Controller, 8}, //LEFT LOW
    Analog potentiometers3[] = {
    {multiplexer8.pin(0), MIDI_CC::Pan, 1}, //PHONE VOLUME
    {multiplexer8.pin(1), MIDI_CC::Pan, 2}, //PHONE MIX
    {multiplexer8.pin(2), MIDI_CC::Pan, 3}, // RIGHT HIGH
    {multiplexer8.pin(3), MIDI_CC::Pan, 4}, //RIGHT LOW
    {multiplexer8.pin(4), MIDI_CC::Pan, 5}, //RIGHT GAIN
    {multiplexer8.pin(5), MIDI_CC::Pan, 6}, //RIGHT MID
    {multiplexer8.pin(6), MIDI_CC::Pan, 7}, // FX 1 A GAIN
    {multiplexer8.pin(7), MIDI_CC::Pan, 8}, //RIGHT FADER
    Digital Buttonslarge[] = {
    {multiplexer1.pin(0), C2, 1, velocity}, //L MODE SELECT
    {multiplexer1.pin(1), D2, 1, velocity}, //BUTTON 34
    {multiplexer1.pin(2), E2, 1, velocity}, //FX 1 B SELECT
    //{multiplexer1.pin(3), f2, 1, velocity}, //BUTTON 37
    //{multiplexer1.pin(4), G2, 1, velocity}, // BUTTON 39
    //{multiplexer1.pin(5), a2, 1, velocity}, OPEN
    //{multiplexer1.pin(6), B2, 1, velocity}, // BUTTON 35
    {multiplexer1.pin(7), C3, 1, velocity}, //BUTTON 36
    {multiplexer2.pin(0), C2, 2, velocity}, // L KEY LOCK
    {multiplexer2.pin(1), D2, 2, velocity}, // FX 1 A SELECT
    {multiplexer2.pin(2), E2, 2, velocity}, //SAMPLER SELECT
    {multiplexer2.pin(3), f2, 2, velocity}, //RIGHT PFL
    {multiplexer2.pin(4), G2, 2, velocity}, // FX 2 A SELECT
    {multiplexer2.pin(5), a2, 2, velocity}, // BUTTON 32
    {multiplexer2.pin(6), B2, 2, velocity}, // R KEY LOCK
    {multiplexer2.pin(7), C3, 2, velocity}, // FX 2 B SELECT
    //{multiplexer3.pin(0), C2, 3, velocity}, //SAMPLER L,R, BOTH SELECT shorted with LIB PREV
    {multiplexer3.pin(1), D2, 3, velocity}, //BUTTON 2
    //{multiplexer3.pin(2), E2, 3, velocity}, //BUTTON 33
    {multiplexer3.pin(3), f2, 3, velocity}, //BUTTON 4
    {multiplexer3.pin(4), B5, 3, velocity}, // LIBRABRY PREVIEW
    {multiplexer3.pin(5), a2, 3, velocity}, //BUTTON 38
    {multiplexer3.pin(6), B2, 3, velocity}, // LIBRABRY STOP
    {multiplexer3.pin(7), C3, 3, velocity}, // LIBRABRY BACK
    //{multiplexer4.pin(0), C2, 4, velocity}, //BUTTON 7
    // {multiplexer4.pin(1), D2, 4, velocity}, //BUTTON 3
    {multiplexer4.pin(2), E2, 4, velocity}, //BUTTON 0
    {multiplexer4.pin(3), f2, 4, velocity}, // R CH LOAD
    {multiplexer4.pin(4), G2, 4, velocity}, // LEFT PFL
    //{multiplexer4.pin(5), a2, 4, velocity}, //BUTTON 5
    //{multiplexer4.pin(6), B2, 4, velocity}, // SAMPLER LOAD, effecting button 0 :( was f2
    {multiplexer4.pin(7), C3, 4, velocity}, //RIGHT MODE SELECT
    {multiplexer5.pin(0), C2, 5, velocity}, //BUTTON 6
    {multiplexer5.pin(1), D2, 5, velocity}, // L CH LOAD
    //{multiplexer5.pin(2), E2, 5, velocity}, // SAMPLER PFL
    {multiplexer5.pin(3), f2, 5, velocity}, //LIBRBARY FWD
    //{multiplexer5.pin(4), G2, 5, velocity}, //OPEM
    //{multiplexer5.pin(5), a2, 5, velocity}, //BUTTON 1
    // {multiplexer5.pin(6), B2, 5, velocity}, //OPEN
    //{multiplexer5.pin(7), C3, 5, velocity}, //OPEN
    Digital Buttonsright[] = {
    Digital Buttonsleft[] = {
    Digital Buttonssampler[] = {
    RotaryEncoder enc = {0, 1, 0x2F, 17, speedMultiply, NORMAL_ENCODER}; //R JOG
    RotaryEncoder enc1 = {6, 7, 0x3F, 18, speedMultiply, NORMAL_ENCODER}; //L JOG
    RotaryEncoder enc2 = {9, 10, 0x4F, 19, speedMultiply, NORMAL_ENCODER}; // LIBRARY SCROLL
    RotaryEncoder enc3 = {11, 12, 0x5F, 20, speedMultiply, NORMAL_ENCODER}; //FX 1 B SELECT
    RotaryEncoder enc4 = {14, 15, 0x6F, 21, speedMultiply, NORMAL_ENCODER}; // SAMPLER VOL
    RotaryEncoder enc5 = {16, 17, 0x7F, 22, speedMultiply, NORMAL_ENCODER}; //FX 2 A SELECT
    RotaryEncoder enc6 = {18, 19, 0x8F, 23, speedMultiply, NORMAL_ENCODER}; //FX 2 B SELECT
    RotaryEncoder enc7 = {20, 21, 0x9F, 24, speedMultiply, NORMAL_ENCODER}; //FX 1 A SELECT
    int counter = 0;
    int counter1 = 0;
    bank.add(Buttonsright);
    bank2.add(Buttonsleft);
    bank3.add(Buttonssampler);
    bank4.add(enc4);
    leds.begin();
    leds.setPixel(0, RED);
    leds.setPixel(2, AQUA);
    leds.setPixel(4, YELLOW);
    leds.setPixel(6, GREEN);
    leds.setPixel(32, RED);
    leds.setPixel(34, AQUA);
    leds.setPixel(36, YELLOW);
    leds.setPixel(38, GREEN);
    leds.show();
    potentiometers1[0].map(mapCalibrated); // apply the 'mapCalibrated' function on the analog input of 'potentiometer'
    potentiometers2[0].map(mapCalibrated);
    MIDI_Controller.refresh();
    int buttonState;
    buttonState = digitalRead(multiplexer4.pin(7));
    if (buttonState == LOW) {
    counter++;
    delay(300);
    else if (counter == 0) {
    leds.setPixel(1, BLUE);
    leds.setPixel(3, BLUE);
    leds.setPixel(5, BLUE);
    leds.setPixel(7, BLUE);
    leds.show();
    else if (counter == 1) {
    leds.setPixel(1, ORANGE);
    leds.setPixel(3, ORANGE);
    leds.setPixel(5, ORANGE);
    leds.setPixel(7, ORANGE);
    leds.show();
    else if (counter == 2) {
    leds.setPixel(1, GREEN);
    leds.setPixel(3, GREEN);
    leds.setPixel(5, GREEN);
    leds.setPixel(7, GREEN);
    leds.show();
    else if (counter == 3) {
    leds.setPixel(1, PURPLE);
    leds.setPixel(3, PURPLE);
    leds.setPixel(5, PURPLE);
    leds.setPixel(7, PURPLE);
    leds.show();
    else {
    counter = 0;
    int buttonState1;
    buttonState1 = digitalRead(multiplexer1.pin(0));
    if (buttonState1 == LOW) {
    counter1++;
    delay(300);
    else if (counter1 == 0) {
    leds.setPixel(33, BLUE);
    leds.setPixel(35, BLUE);
    leds.setPixel(37, BLUE);
    leds.setPixel(39, BLUE);
    leds.show();
    else if (counter1 == 1) {
    leds.setPixel(33, ORANGE);
    leds.setPixel(35, ORANGE);
    leds.setPixel(37, ORANGE);
    leds.setPixel(39, ORANGE);
    leds.show();
    else if (counter1 == 2) {
    leds.setPixel(33, GREEN);
    leds.setPixel(35, GREEN);
    leds.setPixel(37, GREEN);
    leds.setPixel(39, GREEN);
    leds.show();
    else if (counter1 == 3) {
    leds.setPixel(33, PURPLE);
    leds.setPixel(35, PURPLE);
    leds.setPixel(37, PURPLE);
    leds.setPixel(39, PURPLE);
    leds.show();
    else {
    counter1 = 0;
    current_1 = touchRead(touchRead_pin_1);
    if(current_1 > thresh && play_flag_1 == 0) {
    play_flag_1 = 1;
    usbMIDI.sendNoteOn(60, 127, 1);
    delay(delay_time);
    if(current_1 < thresh && play_flag_1 == 1) {
    play_flag_1 = 0;
    usbMIDI.sendNoteOff(60, 0, 1);
    delay(delay_time);
    current_2 = touchRead(touchRead_pin_2);
    if(current_2 > thresh && play_flag_2 == 0) {
    play_flag_2 = 1;
    usbMIDI.sendNoteOn(62, 127, 1);
    delay(delay_time);
    if(current_2 < thresh && play_flag_2 == 1) {
    play_flag_2 = 0;
    usbMIDI.sendNoteOff(62, 0, 1);
    delay(delay_time);
    //int buttonState;
    //buttonState = digitalRead(multiplexer4.pin(7));
    //switch (buttonState) {
    // delay (100);
    // case 0:
    // leds.setPixel(0, RED);
    //leds.setPixel(1, RED);
    //leds.setPixel(2, RED);
    //leds.setPixel(3, RED);
    //leds.show();
    // break;
    //case 1:
    // leds.setPixel(0, GREEN);
    //leds.setPixel(1, GREEN);
    // leds.setPixel(2, GREEN);
    //leds.setPixel(3, GREEN);
    //leds.show();
    // break;
    //case 2:
    //leds.setPixel(0, PURPLE);
    // leds.setPixel(1, PURPLE);
    // leds.setPixel(2, PURPLE);
    // leds.setPixel(3, PURPLE);
    // leds.show();
    // break;
    //default :
    // leds.setPixel(0, BLUE);
    //leds.setPixel(1, BLUE);
    // leds.setPixel(2, BLUE);
    // leds.setPixel(3, BLUE);
    // leds.show();
    // break;
    213
    ADC max input voltage is 3.3V. It seems based on your description that you're powering the pots with a 5V supply, which could explain the apparent loss of range. I guess the ADC has an overvoltage protection? Otherwise I'd imagine it would damage the ADC.
    I have it wired based on this description of lots of potentiometers and multiplexing :
    https://www.pjrc.com/teensy/td_midi.html
    There he shows the pots being run off of the 5v bus .
    But it’s not difficult to switch them to the 3.3v bus on my board, i could try that later tonight
    213
    Teensy 2.0 had 5V ADC max input. Teensy 3.x and 4.x are 3.3V max input.
    Fixed!
    Moved all potentiometers to the 3.3v bus, everything works properly now.
    Thank you!
