Results 1 to 20 of 20
Thread: Teensy 4 and TouchScreenUSB
    Feb 2020
    8
    I'm trying to get multi touch working on a windows 10 machine, but failing miserably. The teensy crashes any time I try to call TouchScreenUSB.press
    I have a Teensy 4.0, with Arduino 1.8.12 and Teensyduino 1.51 beta.
    I have also tried with arduino 1.8.11 and Teensyduino 1.50 with the same results.
    The code below prints "press" only one time then stops executing.
    Any ideas?!
    int yoffset = 8000;
      TouchscreenUSB.begin();
    void drawcircle(int x, int y) {
      float arc = 2.0 * PI / 10.0;
      float r = 3000.0;
      for (float angle=0; angle < arc; angle += 0.01) {
        for (int i=0; i < 10; i++) {
          float ph = arc * (float)i;
          TouchscreenUSB.press(i, r * cosf(angle+ph) + x, r * sinf(angle+ph) + y);
        delay(10);
        TouchscreenUSB.release(i);
        delay(2000);
        Serial.println("press");
        drawcircle(16000, yoffset);
        yoffset += 4200;
        if (yoffset > 24000) yoffset = 8000;
    Nov 2017
    Belgium
    215
    MacOS 10.13.6, Arduino 1.8.12, TD1.51beta1
    Tried both the touchscreen examples on T4 and indeed the T4 crashes after executing the TouchScreenUSB.press commands, so I suspect there might a problem with the TouchscreenUSB.release command.
    After the crash T4 is unresponsive and needs to be put in program mode to upload new code.
    Both examples were tested to work fine with TLC, T3.2 & T3.6
    Feb 2020
    8
    I now tried it also with the latest TD 1.51 release, and still experience the same issue.
    12,736
    That agrees with results by @neurofun as well. First indication of usage and wasn't changed since enabled on T_4 IIRC.
    Will have to be on Paul's list to resolve.
    Feb 2020
    8
    How do we make sure it is on his list? Is this forum post sufficient?
    12,736
    Generally yes, and as done posting it on the change request post for TD 1.52 gets it on the list.
    23,075
    I've been investigating this problem for the last couple days. There seems to be a subtle bug somewhere in the HID-based serial emulation. I still haven't found actual root cause of the problem. Very frustrating!
    But I do have a workaround for crashing. Here it is:
    https://github.com/PaulStoffregen/co...421fac0ac0b20b
    Next week we'll begin beta testing 1.52. The easiest thing is to just wait for a 1.52-beta1 installer, which should be available in a matter of days.
    If you want to fix sooner, you can try to manually edit {Arduino}/hardware/teensy/avr/cores/teensy4/usb.c. But quite a large number of changes have gone into other parts of the USB code, so simply pulling some files off github and putting them into a 1.51 install may or may not work.
    FWIW, here is a program which reproduces the remaining bug. It should print the 4 words press, begin, release, done as it runs. It does indeed, but occasionally some of the words appear twice in the serial monitor. It's definitely a bug in the HID-based serial emulation code. This will remain on my list of known bugs, but at a lower priority (unless anyone can reproduce a more severe problem like crashing... which will prompt me to raise it back up to high priority).
    int yoffset = 7000;
      Serial.println("begin");
      Serial.send_now();
      float r = 300.0;
      for (float angle = 0; angle < arc; angle += 0.1) {
        for (int i = 0; i < 10; i++) {
          TouchscreenUSB.press(i, r * cosf(angle + ph) + x, r * sinf(angle + ph) + y);
        delay(10);
      Serial.println("release");
      Serial.send_now();
      Serial.println("done");
      Serial.send_now();
      delay(2000);
      //Serial.send_now();
      drawcircle(30000, yoffset);
      //yoffset += 4200;
      //if (yoffset > 24000) yoffset = 8000;
    Feb 2020
    8
    This is great!
    I have resorted to a 3.2 for the HID part of my project for the time being, but am keen to try it on the 4.
    On a related note, I did notice on the 3.2 that multitouch was not actually working correctly. In that touches were being registered individually in quick succession, which meant that gestures and such were not working (pinch to zoom for instance).
    It was because the HID report was not including the Contact Count (0x54).
    Anyway, I updated the Teensy3 core and now it works great.
    This is the post I made about that issue, with a link to the PR
    https://forum.pjrc.com/threads/59812...ort-descriptor
    Thanks!!
    23,075
    I've merged your pull request. Thanks!
    Also ported it to Teensy 4.
    https://github.com/PaulStoffregen/co...06a38bd29f428d
    But I don't have any tests or examples for these gestures.
    Apr 2020
    Heidelberg, Germany
    17
    Hi, I am interested to use touchscreen HID functionality for input into Windows10.
    I have a seperate thread which I realise I should have put into the bu report section. I am using the latest versions but not seeing any touchscreen functionality when doing the demo code.
    See the link below as this may be related, I also had the crash occuring until i used the beta version.
    https://forum.pjrc.com/threads/60574...-on-Windows-10
    Apr 2020
    Heidelberg, Germany
    17
    Tested with 1.52beta3 and still no working touchscreen emulation.
    May 2020
    4
    I am also encountering this issue. Teensy 4, Windows 10, Arduino 1.8.12, Teensyduino 1.51 stable. I may try 1.52 beta at some point I guess.
    before finding this thread i modified the sample SingleFingerLine to also use the LED. What I have seen is that the first button press works, the second button press the LED stays on.
    #include <Bounce.h>
    int led = 13;
    Bounce mybutton = Bounce(14, 10);
    int yoffset = 1000;
      pinMode(14, INPUT_PULLUP);
      pinMode(led, OUTPUT);
    void drawline(int x, int y) {
      digitalWrite(led, HIGH);
     for (int i=0; i < 6000; i += 100) {
       TouchscreenUSB.press(0, x + i, y + i/13);
       delay(10);
     TouchscreenUSB.release(0);
      digitalWrite(led, LOW);
      mybutton.update();
      if (mybutton.fallingEdge()) {
        drawline(16000, yoffset);
        yoffset += 1200;
        if (yoffset > 24000) yoffset = 4000;
    Apr 2020
    Heidelberg, Germany
    17
    Some further information which may be useful (or not).
    I have compared the HID report descriptor from USBlyzer for the Teensy4.0 and a working external touchscreen (Asus Zenscreen Touch)
    Teensy 4.0 HID Report Descriptor
    Interface 3 HID Report Descriptor Touch Screen
    Item Tag (Value) Raw Data
    Usage Page (Digitizer) 05 0D
    Usage (Touch Screen) 09 04
    Collection (Application) A1 01
        Usage (Finger) 09 22
        Collection (Logical) A1 02
            Usage (Tip Switch) 09 42
            Logical Minimum (0) 15 00
            Logical Maximum (1) 25 01
            Report Size (1) 75 01
            Report Count (1) 95 01
            Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
            Usage (Contact Identifier) 09 51
            Logical Maximum (127) 25 7F
            Report Size (7) 75 07
            Usage (Tip Pressure) 09 30
            Logical Maximum (255) 26 FF 00
            Report Size (8) 75 08
            Usage Page (Generic Desktop) 05 01
            Usage (X) 09 30
            Usage (Y) 09 31
            Logical Maximum (32767) 26 FF 7F
            Unit (None) 65 00
            Report Size (16) 75 10
            Report Count (2) 95 02
        End Collection C0
        Logical Maximum (65535) 27 FF FF 00 00
        Usage (Scan Time) 09 56
        Usage (Contact Count) 09 54
        Usage (Contact Count Maximum) 09 55
        Logical Maximum (10) 25 0A
        Feature (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) B1 02
    End Collection C0
    And the ASUS Zenscreen Touch
    Interface 0 HID Report Descriptor Touch Screen
        Report ID (6) 85 06
        Logical Maximum (12) 25 0C
            Report Count (7) 95 07
            Input (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 03
            Logical Maximum (31) 25 1F
            Logical Maximum (4095) 26 FF 0F
            Unit Exponent (-2) 55 0E
            Unit (SI Lin: Length (cm)) 65 11
            Usage (X) 09 30
            Physical Minimum (0) 35 00
            Physical Maximum (3465) 46 89 0D
            Physical Maximum (1945) 46 99 07
            Usage (Y) 09 31
        End Collection C0
            Usage (X) 09 30
            Usage (Y) 09 31
        End Collection C0
            Usage (X) 09 30
            Usage (Y) 09 31
        End Collection C0
            Usage (X) 09 30
            Usage (Y) 09 31
        End Collection C0
            Usage (X) 09 30
            Usage (Y) 09 31
        End Collection C0
        Logical Minimum (0) 17 00 00 00 00
        Logical Maximum (2147483647) 27 FF FF FF 7F
        Report Size (32) 75 20
        Unit Exponent (0) 55 00
        Unit (None) 65 00
        Report ID (14) 85 0E
        Usage (Device Identifier) 09 53
        Logical Maximum (128) 26 80 00
        Usage Page (Vendor-Defined 1) 06 00 FF
        Usage (Vendor-Defined 197) 09 C5
        Report ID (7) 85 07
        Report Count (256) 96 00 01
    End Collection C0
    Usage (Vendor-Defined 1) 09 01
        Report ID (3) 85 03
        Report Count (63) 95 3F
        Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
    End Collection C0
    Usage (Configuration) 09 0E
        Report ID (5) 85 05
            Usage (Device Mode) 09 52
        End Collection C0
    End Collection C0
    Usage (Mouse) 09 02
        Report ID (1) 85 01
        Usage (Pointer) 09 01
            Usage Page (Button) 05 09
            Usage Minimum (Button 1) 19 01
            Usage Maximum (Button 2) 29 02
            Report Size (6) 75 06
            Input (Cnst,Ary,Abs) 81 01
            Usage (X) 09 30
            Usage (Y) 09 31
            Logical Minimum (0) 16 00 00
            Physical Minimum (0) 36 00 00
            Unit (None) 66 00 00
        End Collection C0
    End Collection C0
    Also when the ZenscreenTouch is used I get Pen & Touch and Tablet PC Settings become available in Control Panel\Hardware and Sound
    I'm still learning on the USB front but am getting more knowledgeable every day
    Apr 2020
    Heidelberg, Germany
    17
    Tested with the released Teensyduino 1.52 and still no touchscreen or multitouch emulation functionality.
    The teensy4.0 does not seem to properly be recognised as a touchscreen by Windows 10 as the Pen & Touch and Tablet PC Settings do NOT become available in Control Panel\Hardware and Sound.
    Is this being looked at by anyone that knows the usb code more intimately?
    Apr 2020
    Heidelberg, Germany
    17
    Anyone else replicating this? Does touchscreen emulation work on other Teensy?
    Apr 2020
    Heidelberg, Germany
    17
    Latest update.
    Now tried running with 1.53-beta3 Arduino 1.8.13 on Windows 10.
    Have tried Pauls sketch from message #7. The touchscreen still does not work and also I am seeing some corruption on the serial monitor.
    Also tried Sinsids sketch from message #12 but still nothing.
    I think the that although the device is listed as hid-touchscreen in device manager the fact that there is no real recognition as a touchscreen by Windows 10 as the Pen & Touch and Tablet PC Settings do NOT become available in Control Panel\Hardware and Sound.
    This means that it isn't really working as it should and I was really wanting this functionality with the Teensy.
    Will this be looked at by the development team? Otherwise it looks like I will have to use another platform for this development as the Teensy documentation is too difficult for me to trace through especially the USB stack.
    I am wanting to use the Teensy to send touchscreen controlling info to Windows 10 using HID so don't need to write or install a separate driver.
    Apr 2020
    Heidelberg, Germany
    17
    Updated to 1.53 release, still no change. Touchscreen emulation is still non-functional.
    Guess I will give up trying with the Teensy platform
    May 2020
    4
    Go to Teensy 3.6 device. It works there.
    Apr 2020
    Heidelberg, Germany
    17
    @sinsid does the Teensy 3.6 get properly recognised as a touchscreen by Windows 10 as the Pen & Touch and Tablet PC Settings do NOT become available in Control Panel\Hardware and Sound. So when you select the screen associated with the touch input it then is visible on that screen when doing the touch emulation?
    Quote Originally Posted by Sinsid View Post
    Advice not very much, as if you are forced to switch to a push-button phone)
