Results 1 to 3 of 3
Thread: Teensy 4.0 + Rev C Audio Shield + headphones = no audio
    Feb 2020
    4
    I'm not able to hear any audio through the headphones. I'm using the audio example sketches, such as ToneSweep and Guitar. They don't give any errors and the serial outputs seem to be what's expected. I've tested with multiple headphones. I've uploaded other sketches to the Teensy (the blinking LED one) and that worked.
    It's a Teensy 4.0 with the Rev C version of the audio shield. I'm using Mac.
    Here's my setup:
    1,245
    You need the Rev D board for a Teensy 4.0. The pinouts are a bit different and IIRC there's also an extra resistor in there too. See https://www.pjrc.com/store/teensy3_audio.html
    Pete
    21,473
    Yes, Rev C is for Teensy 3.x.
    If you use wires to route the signals to the correct pins, Rev C can work with Teensy 4.0. But it will not work when plugged in directly, because the five I2S signals are in the places for Teensy 3.x. They're on different pins for Teensy 4.0.
