Results 1 to 8 of 8
Thread: teensy_loader_cli compile error using MinGW
    Dec 2019
    15
    I'm getting an error message when trying to compile the teensy_loader_cli. I've downloaded the files from https://github.com/PaulStoffregen/teensy_loader_cli and installed MinGW on a windows 10 pc. I've also edited the Makefile included in the download and edited the header as:
    #OS ?= LINUX
    OS ?= WINDOWS
    #OS ?= MACOSX
    #OS ?= BSD
    however when I run the make command I get the following error?
    C:\MinGW\teensy_loader_cli-master>mingw32-make
    rm -f teensy_loader_cli teensy_loader_cli.exe*
    process_begin: CreateProcess(NULL, rm -f teensy_loader_cli teensy_loader_cli.exe*, ...) failed.
    make (e=2): The system cannot find the file specified.
    Makefile:59: recipe for target 'clean' failed
    mingw32-make: *** [clean] Error 2
    Do I need to edit anything else ? just keen to compile the cli code.
    cheers
    25,050
    It's trying to run "rm" to delete a file.
    Either install a "rm" program, or edit the makefile to use dos "del" command.
    Feb 2020
    4
    Quote Originally Posted by jeff0778 View Post
    #OS ?= LINUX
    OS ?= WINDOWS
    #OS ?= MACOSX
    #OS ?= BSD
    cheers
    Were you successful? I'm quite new to the CLI code myself and had to make a couple of adjustments to the make file to get it to compile as well.
    Dec 2019
    15
    Thanks, it looks like I did have rm installed but needed to add a separate PATH in the windows environment variables of "C:\MinGW\msys\1.0\bin"
    It no longer throws up the original error, although it doesn't really do anything now. it just returns the last line in the make file ?
    c:\teensy_loader>mingw32-make
    if i remove the -f force and replace it with -v i get the following:
    rm -v teensy_loader_cli teensy_loader_cli.exe*
    rm: cannot lstat `teensy_loader_cli': No such file or directory
    rm: cannot lstat `teensy_loader_cli.exe*': No such file or directory
    mingw32-make: *** [clean] Error 1
    have you any pointers to how i can get this to compile ?
    Cheers
    Feb 2020
    4
    I do.
    After you installed MinGW, did you add it's main and Bin paths to your environmental variables? you can check this by going to command prompt and entering "gcc -v." this command is what should be placed in the make file for your CC value (e.g. CC = gcc)
    At the end (line 59 as noted in your last post) something about the file can't get cleaned; most likely because it doesn't exist. I changed that filename from: teensy_loader_cli teensy_loader_cli.exe* to teensy_loader_cli teensy_loader_cli.exe (no star which isn't a valid character in windows OS).
    let me know if this helps...I've recently compiled mine in the last week so it's still fresh in my memory.
    Dec 2019
    15
    Thanks,
    I've added
    C:\MinGW, C:\MinGW\bin & C:\MinGW\msys\1.0\bin to the environment variables but it still doesn't seem to compile.
    if i run gcc -v in the command prompt i get, which looks ok.
    C:\teensy_loader>gcc -v
    Using built-in specs.
    COLLECT_GCC=gcc
    COLLECT_LTO_WRAPPER=c:/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exe
    Target: mingw32
    Configured with: ../src/gcc-6.3.0/configure --build=x86_64-pc-linux-gnu --host=mingw32 --target=mingw32 --with-gmp=/mingw --with-mpfr --with-mpc=/mingw --with-isl=/mingw --prefix=/mingw --disable-win32-registry --with-arch=i586 --with-tune=generic --enable-languages=c,c++,objc,obj-c++,fortran,ada --with-pkgversion='MinGW.org GCC-6.3.0-1' --enable-static --enable-shared --enable-threads --with-dwarf2 --disable-sjlj-exceptions --enable-version-specific-runtime-libs --with-libiconv-prefix=/mingw --with-libintl-prefix=/mingw --enable-libstdcxx-debug --enable-libgomp --disable-libvtv --enable-nls
    Thread model: win32
    gcc version 6.3.0 (MinGW.org GCC-6.3.0-1)
    Is your Makefile using the uncommented OS ?= WINDOWS ??
    As this seems to use "CC ?= i586-mingw32msvc-gcc", but I've also tried it with "CC ?= gcc" and "CC ?= gcc -v" with the same out come.
    I've also tried removing the * at the end of the last line under clean as you suggested, but still the same.
    Dec 2019
    15
    I think i might have got this working now.
    I've abandoned the Makefile and just typed the following gcc command, which seems to have build and .exe file.
    C:\teensy_loader>gcc -Wall -s -DUSE_WIN32 -o teensy_loader_cli.exe teensy_loader_cli.c -lhid -lsetupapi -lwinmm
    I've removed the -O2 flag, not sure if that will be an issue ?
    I've done a small test and it looks to be working.
    Feb 2020
    4
    glad to hear it worked!
    I did a quick google search (because I wasn't too familiar with it myself) and found that although there may be some performance benefit, I am not sure if its significant; nor do I know if they apply to mingw installations; the information below seems a bit outdated.
    "We suggest that you use the '-O2' switch in all of your compilations; it increases speed and decreases the program size at the cost of compilation time."
    http://tigcc.ticalc.org/doc/comopts.html
