Hi there!
I'm pretty new here and want to build a midi controller using Teensy microcontroller and i have got some questions. My main goal is too build a midi controller in a box with illiminated arcade button that will have 2 USB output (for redundancy) (from what i saw i can simply mount 2 teensy that will be triggered by the same switch)
First is the controller can only produce midi note or it can emulate keyboard key too (If i want to emulate spacebar, or letter of the keyboard) If you can emulater keyboard key how you program them?
Wich controller i need? Is the Teensy LC is ok for my need? Does it will have enough power to drive the switch LED? (I plan to put approx 5-6 switch) I saw a lot of generation of teensy micro controller!! Is the LC is about to be discontinued?
How i can program the micro controller? Is it a hard procedure? Can we have some template??
i was looking for an alternative for being able to screw the board. Waht do you use? I found this on the internet do you have other option?
https://www.tindie.com/products/loglow/teensy-32-breakout-revision-d/
Other more generic option exist?
Thanks a lot for your advice!
Fred
Fred
