Hi, absolute beginner teensy user here.
Is it possible to control SK6812 LEDs with a teensy 3.5 with audio shield? I am trying to control three strings, one of 9 leds and one of 5 leds and one with 1 LED. The first LED strip is supposed to flash in a random pattern, while the other lights up with button pushes. I know there are some conflicts due to the audio shield with timing. Is there a way around this? With the code I am using, it doesnt seem to update the LEDs properly. If they do light up, its extremely slow. Here is a code sample:
#include <Adafruit_NeoPixel.h>
#include <Bounce.h>
AudioPlaySdWav playSdWav2; //xy=755,350
AudioPlaySdWav playSdWav4; //xy=756,444
AudioPlaySdWav playSdWav3; //xy=757,397
AudioPlaySdWav playSdWav1; //xy=758,302
AudioMixer4 mixer2; //xy=973,395
AudioMixer4 mixer1; //xy=975,318
AudioOutputI2S i2s1; //xy=1206,341
AudioConnection patchCord1(playSdWav2, 0, mixer1, 1);
AudioConnection patchCord2(playSdWav2, 1, mixer2, 1);
AudioConnection patchCord3(playSdWav4, 0, mixer1, 3);
AudioConnection patchCord4(playSdWav4, 1, mixer2, 3);
AudioConnection patchCord5(playSdWav3, 0, mixer1, 2);
AudioConnection patchCord6(playSdWav3, 1, mixer2, 2);
AudioConnection patchCord7(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord8(playSdWav1, 1, mixer2, 0);
AudioConnection patchCord9(mixer2, 0, i2s1, 1);
AudioConnection patchCord10(mixer1, 0, i2s1, 0);
AudioControlSGTL5000 sgtl5000_1; //xy=996,524
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
//Neopixel Chains Defined
Adafruit_NeoPixel blinkStrip(9, 30, NEO_RGBW + NEO_KHZ800);
Adafruit_NeoPixel alertStrip(5, 31, NEO_RGBW + NEO_KHZ800);
Adafruit_NeoPixel commStrip(1, 34, NEO_RGBW + NEO_KHZ800);
//Neopixel Color Variables
uint32_t white = blinkStrip.Color(0, 0, 0, 255);
uint32_t off = blinkStrip.Color(0, 0, 0, 0);
//Variables for timed actions
unsigned long startTime [9] = { 0, 0, 0, 0, 0, 0, 0, 0, 0 };
unsigned long duration [9] = { 0, 0, 0, 0, 0, 0, 0, 0, 0 } ;
unsigned long previousMillisyel = 0;
unsigned long previousMillisred = 0;
unsigned long computeStatemillis = 0;
unsigned long commStatemillis = 0;
unsigned long prevCommMillis = 0;
unsigned long notifyMillis = 0;
unsigned long currentMillis =0;
long commDelay = 0;
const byte commDelays [] = {3000, 5000, 4000, 3500, 4500};
int randNumber;
const long alertInterval = 1000;
const int computeStateWaitTime = 3000;
//Button/switch Number and Button State Variables
int lightFlashsw = 37;
int lightFlash = 0;
int ambSnd = 0;
Bounce ambientSW = Bounce(ambientSoundpin, 15);
//random blinking maximum and minimum values
const int randMax = 8000;
const int randMin = 2000;
const int commMax = 15000;
const int commMin = 8000;
//Bool Statement Variables
bool bootUp = false;
bool light1state = false;
bool light2state = false;
bool light3state = false;
bool light4state = false;
bool light5state = false;
bool light6state = false;
bool light7state = false;
bool light8state = false;
bool light9state = false;
//Audio Shield Settings
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
pinMode(13, OUTPUT); // LED on pin 13
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
mixer1.gain(2, 0.5);
mixer1.gain(3, 0.5);
mixer2.gain(0, 0.5);
mixer2.gain(1, 0.5);
mixer2.gain(2, 0.5);
mixer2.gain(3, 0.5);
//End Audio Shield Settings
//PinModes for Buttions and Switches
pinMode (lightFlashsw, INPUT);
digitalWrite (lightFlashsw, HIGH);
//initialize Neopixels
blinkStrip.begin();
blinkStrip.show(); // Initialize all pixels to 'off'
alertStrip.begin();
alertStrip.show(); // Initialize all pixels to 'off'
commStrip.begin();
commStrip.show(); // Initialize all pixels to 'off'
//Random Number Generation
randomSeed(analogRead(0));
randNumber = random(1, 10);
currentMillis = millis();
//Light Sequence for Left Panel. Also see
//if (lightFlash == HIGH) {
callLight(randNumber);
// } else {
// blinkStrip.fill (white, 0, 9);
// blinkStrip.show ();
//Bridge Ambience Audio and Control
if (playSdWav1.isPlaying() == false) {
if (ambientSoundcounter == 0) {
playSdWav1.play("BRGBK1.WAV");
Serial.println("Start playing 1");
delay(10);
if (ambientSoundcounter == 1) {
playSdWav1.play("BRGBK2.WAV");
Serial.println("Start playing 2");
delay(10);
if (ambientSoundcounter == 2) {
playSdWav1.play("BRGBK3.WAV");
Serial.println("Start playing 3");
delay(10);
while (playSdWav1.isPlaying()) {
ambientSW.update();
if (ambientSW.fallingEdge()) {
playSdWav1.stop();
ambientSoundcounter ++;
if (ambientSW.risingEdge()) {
playSdWav1.stop();
if (ambientSoundcounter > 2) {
ambientSoundcounter = 0;
Serial.println("Back to 0");
//Generate random function calls for random lights
void callLight(int randNumber) {
if (randNumber == 1) {
light1();
if (randNumber == 2) {
light2();
if (randNumber == 3) {
light3();
if (randNumber == 4) {
light4();
if (randNumber == 5) {
light5();
if (randNumber == 6) {
light6();
if (randNumber == 7) {
light7();
if (randNumber == 8) {
light8();
if (randNumber == 9) {
light9();
// Functions to control random flashing lights, using led matrix and flashing groups of three together
void light1() {
if (currentMillis - startTime[1] >= duration[1])
{ startTime[1] = currentMillis;
duration[1] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light1state == true) {
blinkStrip.setPixelColor(0, white);
blinkStrip.setPixelColor(0, off);
light1state = true;
blinkStrip.show();
void light2() {
if (currentMillis - startTime[2] >= duration[2])
{ startTime[2] = currentMillis;
duration[2] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
Serial.println("Light 3");
if (light2state == true) {
blinkStrip.setPixelColor(1, white);
blinkStrip.setPixelColor(1, off);
light2state = true;
blinkStrip.show();
void light3() {
if (currentMillis - startTime[3] >= duration[3])
{ startTime[3] = currentMillis;
duration[3] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
Serial.println("Light 4");
if (light3state == true) {
blinkStrip.setPixelColor(2, white);
blinkStrip.setPixelColor(2, off);
light3state = true;
blinkStrip.show();
void light4() {
if (currentMillis - startTime[4] >= duration[4])
{ startTime[4] = currentMillis;
duration[4] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light4state == true) {
blinkStrip.setPixelColor(3, white);
blinkStrip.setPixelColor(3, off);
light4state = true;
blinkStrip.show();
void light5() {
if (currentMillis - startTime[5] >= duration[5])
{ startTime[5] = currentMillis;
duration[5] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light5state == true) {
blinkStrip.setPixelColor(4, white);
blinkStrip.setPixelColor(4, off);
light5state = true;
blinkStrip.show();
void light6() {
if (currentMillis - startTime[6] >= duration[6])
{ startTime[6] = currentMillis;
duration[6] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light6state == true) {
blinkStrip.setPixelColor(5, white);
blinkStrip.setPixelColor(5, off);
light6state = true;
blinkStrip.show();
void light7() {
if (currentMillis - startTime[7] >= duration[7])
{ startTime[7] = currentMillis;
duration[7] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light7state == true) {
blinkStrip.setPixelColor(6, white);
blinkStrip.setPixelColor(6, off);
light7state = true;
blinkStrip.show();
void light8() {
if (currentMillis - startTime[8] >= duration[8])
{ startTime[8] = currentMillis;
duration[8] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light8state == true) {
blinkStrip.setPixelColor(7, white);
blinkStrip.setPixelColor(7, off);
light8state = true;
blinkStrip.show();
void light9() {
if (currentMillis - startTime[0] >= duration[0]) //using zero because numbering system is 0-8 rather than 1-9
{ startTime[0] = currentMillis;
duration[0] = random(randMin, randMax); //smallest and longest ON/OFF times for reandom blinking
if (light9state == true) {
blinkStrip.setPixelColor(8, white);
blinkStrip.setPixelColor(8, off);
light9state = true;
blinkStrip.show();
