Results 1 to 2 of 2
Thread: Audio board Rev D for teensy 3.6
    Feb 2020
    3
    Hi Iím new to programming I have teensy 3.6 with audio board marked Rev D for 3.6 must I rewire audio for 3.6 ? Or just solder header pins ? Any help thank you
    11,778
    The Rev D board is wired for direct connect to a Teensy 4.0 with pins moved as needed from the T_3.x locations.
    For direct solder a Rev C Audio board works on the Teensy 3.2/3.5/3.6.
    To use the Rev D board on a T_3.6 would require manually connecting those changed pins to the proper locations.
