Hey y'all
I am trying to build myself a CCD using a Teensy 3.2 and a TCD1304. I used to have a code running that would synchronize the ADC with the other pulse trains by reading out PINA (PTA13 or pin 4 on the Teensy). I upload the codes using Teensyduino and the Arduino IDE. I'm pretty sure that code worked on my previous machine, but I can't seem to get it to work now. I run into the following error message:
Any idea what might be the problem? If I can't use PINA anymore, is there an alternative way to go?
Here's the code and thanks for your time!
Arduino: 1.8.11 (Linux), TD: 1.50, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz, Faster, US English"
tcd1304_ctlr_2: In function 'void loop()':
tcd1304_ctlr_2:74: error: 'PINA' was not declared in this scope
while(PINA & (1<<13)){}//Wait for the ICG pulse to end
tcd1304_ctlr_2:75: error: 'PINA' was not declared in this scope
while(PINA & !(1<<13)){}//Wait for the next pulse
#include "ADC.h"
#include <ADC_util.h>
char dataIn[10];
char operation[5];
char quant[4];
boolean dataRdy=false;
int analogPin = A0;
ADC *adc = new ADC(); // adc object
uint16_t ccd_data[4000];
int intTime=0;
int number=0;
setReadTime(2000);
adc->adc0->setReference(ADC_REFERENCE::REF_3V3);
adc->adc0->setAveraging(1); // set number of averages
adc->adc0->setResolution(12); // set bits of resolution
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED);
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED);
adc->adc0->singleMode(); // is needed for analogReadFastADC0()
if (Serial.available()){
dataRdy=processIncomingByte(dataIn);
if(dataRdy){
//getSubset(0,4,operation,dataIn);
if(dataIn[0]=='T'){
//Serial.println("I should goto...");
getSubset(1,4,quant,dataIn);
intTime=atoi(quant);
if (intTime<20){
intTime=20;
else if(intTime>200){
intTime=200;
else{
number=ms2Number(intTime);
setReadTime(number);
//Serial.println(atoi(quant));
else if(dataIn[0]=='R'){
while(PIND & !(1<<4)){}//Wait for the next pulse
while(PIND & (1<<4)){}//Wait for the ICG pulse to end
ccd_data[1] = analogReadFastADC0(analogPin);
for (int i=0; i<3694; i++){
ccd_data[i] = analogReadFastADC0(analogPin);
// while(PINA & (1<<13)){}//Wait for the ICG pulse to end
for (int i=0;i<3694;i++){
Serial.print(i);
Serial.print('\t');
Serial.println(ccd_data[i]);
else if(dataIn[0]=='W'){
//Serial.println("I should tell what I feel...");
getSubset(1,3,quant,dataIn);
//Serial.println(quant);
else{
Serial.println("wtf...");
//Serial.println(operation);
dataRdy=false;
dataIn[0]='\0';
boolean processIncomingByte(char dataIn[]){
char endMarker='\n';
char rc;
int iter=0;
while(dataIn[iter]!='\0'){
iter++;//Finds the end of the string to append it the read character
rc=Serial.read();
dataIn[iter]=rc;
dataIn[iter+1]='\0';
if(rc==endMarker){
return true;
else{
return false;
void getSubset(int debut, int fin, char tabOut[], char tabIn[]){
int k=0;
for(int i=debut;i<=fin;i++){
tabOut[k]=tabIn[i];
k++;
tabOut[k]='\0';
void setReadTime(unsigned int number0){
// The order of setting the TPMx_SC, TPMx_CNT, and TPMx_MOD
// seems to matter. You must clear _SC, set _CNT to 0, set _MOD
// to the desired value, then you can set the bit fields in _SC.
SIM_SCGC6|=0x03000000; //enable FTM0 and FTM0 module clock
SIM_SCGC5=SIM_SCGC5|0x3E00; //enable port A/B/C/D/E clock
// Clear TPM0_SC register (p. 572)
FTM0_SC = 0;
FTM1_SC = 0;
// Reset the TPM0_CNT counter (p. 574)
FTM0_CNT = 0;
FTM1_CNT = 0;
// Set overflow value (modulo) (p.574)
//FTM0_MOD = 0xFFFF;
//double number0=65;
double number1=40;
FTM0_FMS=0x00; //clear the WPEN so that WPDIS is set in FTM0_MODE reg
FTM0_MODE|=0x05; //enable write the FTM CnV register
//FTM0_MOD=1000;
// Set TPM0_C4SC register (Teensy LC - pin 6) (p. 575)
// As per the note on p. 575, we must disable the channel
// first before switching channel modes. We also introduce
// a magical 1 us delay to allow the new value to take.
// Bits | Va1ue | Description
// 7 | 1 | CHF: Clear Channel Flag
// 6 | 1 | CHIE: Enable Channel Interrupt
// 5-4 | 10 | MS: Edge-aligned PWM
// 3-2 | 10 | ELS: Set on reload, clear on match
// 1 | 0 | Reserved
// 0 | 0 | DMA: Disable DMA
FTM0_C4SC = 0;
FTM0_C3SC = 0;
FTM0_C2SC = 0;
delayMicroseconds(1);
FTM1_C1SC = 0;
FTM0_C4SC = 0b101000;
// FTM0_C2SC = 0b101000;
// FTM0_C3SC = 0b101000;
// FTM0_COMBINE=0b1100000000;
FTM0_C6SC = 0b101000;
FTM0_C7SC = 0b101000;
FTM0_COMBINE=0b11000000000000000000000000;
FTM0_CNTIN=0x00;
FTM1_C1SC = 0b11101000;
//FTM0_COMBINE=0x0303;
//FTM0_MOD=0b1000;
//Set Duty cycle to 0.5
FTM0_C4V = 4;
//FTM0_C6V = 2;
FTM0_C7V = 2;
FTM1_C1V = number1/2;
FTM0_MOD=number0;
FTM1_MOD=number1;
//Setting SC registers
// 8 | 0 | DMA: Disable DMA
// 7 | 1 | TOF: Clear Timer Overflow Flag
// 6 | 1 | TOIE: Enable Timer Overflow Interrupt
// 5 | 0 | CPWMS: TPM in up counting mode
// 4-3 | 01 | CMOD: Counter incrememnts every TPM clock
// 2-0 | 000 | PS: Prescale = 1
FTM0_SC = 0b011001111;
FTM1_SC = 0b011001000;
// Set PORTD_PCR4 register
// Bits | Value | Description
// 10-8 | 100 | MUX: Alt 4 attach to FTM0_CH4
// 7 | 0 | Reserved
// 6 | 0 | DSE: Low drive strength
// 5 | 0 | Reserved
// 4 | 0 | PFE: Disable input filter
// 3 | 0 | Reserved
// 2 | 1 | SRE: Slow output slew rate
// 1 | 0 | PE: Disable pull-up/down
// 0 | 0 | PS: Internal pull-down
PORTD_PCR4 = 0b10000000100;//PIN 6
// PORTC_PCR4 = 0b10000000100;// PIN 10
//PORTD_PCR6 = 0b10000000100;//PIN 21
PORTD_PCR7 = 0b10000000100;//PIN 5
// Set PORTA_PCR13 register
// 10-8 | 100 | MUX: Alt 3 attach to FTM1_CH1
// 7 | 0 | Reserved
// 5 | 0 | Reserved
// 3 | 0 | Reserved
PORTA_PCR13 = 0b01100000100; //PIN 4
unsigned int ms2Number(unsigned int intTime){
int number=0;
number=36000*intTime/128;
return number;
uint16_t analogReadFastADC0(uint8_t pin){
uint16_t result;
adc->adc0->startReadFast(pin); // start single read (with adc->adc0->singleMode(); in setup() )
while(adc->adc0->isConverting()) {} // wait for the ADC to finish
// __disable_irq();
result = (uint16_t)ADC0_RA;
// __enable_irq();
return result;
