Results 1 to 5 of 5
Thread: using teensy as a pattern generator
    Feb 2020
    3
    I am trying to use Teensy as a very fast pattern generator. The pattern should be like ~us of pattern data and repetition rate of let say 50us.
    In the past I used Arduino with the code something like this:
    TIMSK0 = 0; // no interrupts
    OCR0A = 0; // count to 2
    DDRB = B00011100;
    } // end of setup
    // trigger 1 (port 11)
    // pulse bit 2 (port 12)
    // blanking 3 (port 13)
    double a;
    PORTB = B00000000; // important to keep here
    PORTB = B00010000;
    PORTB = B00010100; // ____||______
    PORTB = B00010100; // __|------|___
    PORTB = B00010100; // ________|---|_
    PORTB = B00010000;
    PORTB = B00011000; // pulse + protection
    PORTB = B00010000;
    PORTB = B00010000;
    PORTB = B00010000;
    PORTB = B00010000;
    for(int i = 0; i <80; i++) // 50 us per 100 reps
    PORTB = B00000000;
    this worked fine, for the purpose, at the clock rate of imho 16MHz
    Question - will I have any lack using this on Teensy architecture ? Can I reach clock rate of the chip with this approach ?
    Thanks!!!
    Boris
    7,658
    No, on ARM, the GPIOs are connected on a internal BUS.With which speed it runs, depends on the Teensy-model and its settings. With Teensy 4 it's 150MHz.
    So you can toggle a tight loop with while(1) {digitalWriteFast(0,1);digitalWriteFast(0,0);} at 150MHz / 2
    No, the CPU worked at the clockrate of 16MHZ. Your loop is much much much slower.
    Feb 2020
    3
    Thanks Frank! I made a quick test on TEENSY 3.2 and things look a bit iffy. The test is a two 'pulse' sequence:
    //set pins to output
    pinMode(13, OUTPUT);
    int c = 1, r=0;
    void loop(void) {
    switch(c) {
    case 1:
    noInterrupts();
    digitalWriteFast(13, LOW);
    digitalWriteFast(13, HIGH);
    interrupts();
    case 2:
    .... the same like 1 but more LOW writes in the middle
    case 3:
    .... the same like 2 but more LOW writes in the middle
    if(r > 1000) {
    if(c==3) c=1;
    else c++;
    r = 0;
    else r++;
    delay(5);
    the result of the test - the first 'pulse' of HIGH's is different between cases (case 1: 72ns, case 2: 164ns, case 3: 72ns, very reproducibly, second pulse is ~40ns). So overall it is hard to predict what exactly will be generated.
    any advise ?
    Thanks again!
    7,658
    Not really Just guessing.. the flash access might influence things.
    Maybe try to make a function with "fastrun" for every pattern:
    FASTRUN void pattern1(void) {
      noInterrupts();
      do {
         digitalWriteFast(....
      } while (r<1000);
      interrupts();
    ...sorry, a blind guess, not sure if it is better.
    Or (and) save the pattern in a array:
    uint8_t pat1[200] = {0,0,1,1,1,1,0,.... <-don't use const here to make sure data are in RAM
    FASTRUN pattern
    do...
    .. digitalWriteFast(13, pat1[i++]);
    while ...
    Feb 2020
    3
    FASTRUN seems working - need more testing
    running through the array is stable but slow (80ns per array element)
