Results 1 to 4 of 4
Thread: Pins teensy 3.6 to Audio board Rev B
    Feb 2020
    3
    Hi Iím newbie here, I have teensy 3.6 want to connect audio board Rev B together . The correct way to mount together Iím very confused using 14 pin header pin do I skip one not used ? Or must be hard wired in ? Which pins match up with teensy 3.6 to audio board rev B ? Can someone show me me pin for pin thank you
    Germany NRW
    6,906
    This way:
    Note, the headphone-connector and USB are on the same side. The 3.6 is longer than the audio shield - ignore that
    Don't use wires - if you don't do it right they can be very unreliable, and soon we will read "Audio shield does not work" from you...
    More information: https://www.pjrc.com/store/teensy3_audio.html
    22,083
    Quote Originally Posted by Eester View Post
    Connect it like this:
    DO NOT use wires. It must be mounted close to the audio shield, because rev B does not have the extra 100 ohm resistor on MCLK.
    Feb 2020
    3
    Thank you, now working on simple blinking 73
