09:26:26.802 (post_compile 1): Begin, version=1.51
09:26:26.883 (loader): Teensy Loader 1.51, begin program
09:26:26.892 (loader): Listening for remote control on port 3149
09:26:26.892 (loader): initialized, showing main window
09:26:26.904 (loader): remote connection 10 opened
09:26:26.904 (post_compile 1): Sending command: comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)
09:26:26.904 (loader): remote cmd from 10: "comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)"
09:26:26.905 (loader): remote cmd from 10: "status"
09:26:26.998 (post_compile 1): Status: 0, 0, 0, 0, 0, 0, /tmp/arduino_build_205249/, test_serial.ino.hex
09:26:26.998 (post_compile 1): Sending command: dir:/tmp/arduino_build_274178/
09:26:26.998 (loader): remote cmd from 10: "dir:/tmp/arduino_build_274178/"
09:26:26.998 (post_compile 1): Sending command: file:test_serial.ino.hex
09:26:26.998 (loader): remote cmd from 10: "file:test_serial.ino.hex"
09:26:27.023 (loader): File "test_serial.ino.hex". 3200 bytes, 10% used
09:26:27.031 (loader): remote cmd from 10: "status"
09:26:27.125 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, /tmp/arduino_build_274178/, test_serial.ino.hex
09:26:27.125 (post_compile 1): Sending command: auto:on
09:26:27.126 (loader): remote cmd from 10: "auto:on"
09:26:27.126 (post_compile 1): Disconnect
09:26:27.136 (loader): remote connection 10 closed
09:26:31.112 (post_compile 2): Begin, version=1.51
09:26:31.112 (loader): remote connection 10 opened
09:26:31.112 (post_compile 2): Sending command: comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)
09:26:31.112 (loader): remote cmd from 10: "comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)"
09:26:31.112 (loader): remote cmd from 10: "status"
09:26:31.112 (loader): file changed
09:26:31.122 (loader): File "test_serial.ino.hex". 3200 bytes, 10% used
09:26:31.217 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_274178/, test_serial.ino.hex
09:26:31.217 (post_compile 2): Disconnect
09:26:31.228 (loader): remote connection 10 closed
09:26:31.255 (post_compile 3): Begin, version=1.51
09:26:31.255 (loader): remote connection 10 opened
09:26:31.255 (post_compile 3): Sending command: comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)
09:26:31.255 (loader): remote cmd from 10: "comment: Teensyduino 1.51 - LINUX64 (teensy_post_compile)"
09:26:31.255 (loader): remote cmd from 10: "status"
09:26:31.350 (post_compile 3): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_274178/, test_serial.ino.hex
09:26:31.350 (post_compile 3): Disconnect
09:26:31.360 (post_compile 4): Running teensy_reboot: /home/ryan/ryan_stuff/projects/microprocessing/arduino-1.8.12/hardware/teensy/../tools/teensy_reboot
09:26:31.361 (loader): remote connection 10 closed
09:26:31.361 (loader): remote connection 10 opened
09:26:31.365 (reboot 5): Begin, version=1.51
09:26:31.365 (reboot 5): location = /dev/ttyS4
09:26:31.365 (reboot 5): portlabel = /dev/ttyS4
09:26:31.365 (reboot 5): portprotocol = serial
09:26:31.365 (reboot 5): Serial device /dev/ttyS4 will be tried first
09:26:31.392 (loader): remote connection 10 opened
09:26:31.393 (reboot 5): add device: subsys=usb, type=usb_device, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:31.393 (reboot 5): devnode=/dev/bus/usb/001/011, subsystem=usb, ifacenum=-1
09:26:31.393 (reboot 5): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0
09:26:31.393 (reboot 5): parent location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:31.393 (reboot 5): model=27 (Teensy 2.0)
09:26:31.394 (reboot 5): add child: subsys=tty, type=(null), location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/tty/ttyACM0
09:26:31.394 (reboot 5): parent location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:31.394 (reboot 5): devnode=/dev/ttyACM0, subsystem=tty, ifacenum=0
09:26:31.395 (reboot 5): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1
09:26:31.395 (reboot 5): parent location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:31.473 (loader): remote cmd from 10: "show:arduino_attempt_reboot"
09:26:31.473 (loader): got request to show arduino rebooting message
09:26:31.481 (loader): remote cmd from 10: "comment: Teensyduino 1.51 - LINUX64 (teensy_reboot)"
09:26:31.482 (loader): remote cmd from 10: "status"
09:26:31.596 (loader): remote cmd from 10: "status"
09:26:31.600 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/tty/ttyACM0
09:26:31.600 (ports 6): devnode=/dev/bus/usb/001/011, subsystem=usb, ifacenum=-1
09:26:31.664 (loader): remote connection 10 opened
09:26:31.664 (loader): remote connection 10 closed
09:26:31.666 (ports 6): unknown action: unbind
09:26:31.666 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0
09:26:31.666 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1
09:26:31.666 (ports 6): del device: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:32.063 (ports 6): add device: subsys=usb, type=usb_device, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:32.063 (ports 6): devnode=/dev/bus/usb/001/012, subsystem=usb, ifacenum=-1
09:26:32.063 (ports 6): usb_add: /dev/bus/usb/001/012 (Teensy 2.0) Bootloader
09:26:32.065 (ports 6): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0
09:26:32.065 (ports 6): parent location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:32.065 (ports 6): usb_add: /dev/bus/usb/001/012 (Teensy 2.0) Bootloader
09:26:32.069 (ports 6): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:16C0:0478.0004
09:26:32.069 (ports 6): parent location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:32.069 (ports 6): model=27 (Teensy 2.0)
09:26:32.069 (ports 6): usb_add: /dev/bus/usb/001/012 (Teensy 2.0) Bootloader
09:26:32.069 (ports 6): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:16C0:0478.0004/hidraw/hidraw0
09:26:32.070 (ports 6): unknown action: bind
09:26:32.071 (ports 6): unknown action: bind
09:26:32.072 (ports 6): unknown action: bind
09:26:32.251 (loader): Device came online, code_size = 32256
09:26:32.251 (loader): Board is: Teensy 2.0 (ATMEGA32U4)
09:26:32.252 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:16C0:0478.0004/hidraw/hidraw0
09:26:32.253 (ports 6): unknown action: unbind
09:26:32.254 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:16C0:0478.0004
09:26:32.254 (ports 6): unknown action: unbind
09:26:32.260 (loader): File "test_serial.ino.hex". 3200 bytes, 10% used
09:26:32.266 (loader): set background IMG_ONLINE
09:26:32.278 (loader): File "test_serial.ino.hex". 3200 bytes, 10% used
09:26:32.285 (loader): elf appears to be for Teensy 2.0 (ATMEGA32U4) (32256 bytes)
09:26:32.285 (loader): elf binary data matches hex file
09:26:32.285 (loader): elf file is for Teensy 2.0 (ATMEGA32U4)
09:26:32.291 (loader): begin operation
09:26:32.294 (loader): flash, block=0, bs=128, auto=1
09:26:32.450 (loader): gauge old value = 0
09:26:32.453 (loader): flash, block=1, bs=128, auto=1
09:26:32.458 (loader): gauge old value = 1
09:26:32.459 (loader): flash, block=2, bs=128, auto=1
09:26:32.464 (loader): gauge old value = 2
09:26:32.465 (loader): flash, block=3, bs=128, auto=1
09:26:32.470 (loader): gauge old value = 3
09:26:32.471 (loader): flash, block=4, bs=128, auto=1
09:26:32.476 (loader): gauge old value = 4
09:26:32.479 (loader): flash, block=5, bs=128, auto=1
09:26:32.484 (loader): gauge old value = 5
09:26:32.486 (loader): flash, block=6, bs=128, auto=1
09:26:32.491 (loader): gauge old value = 6
09:26:32.493 (loader): flash, block=7, bs=128, auto=1
09:26:32.498 (loader): gauge old value = 7
09:26:32.499 (loader): flash, block=8, bs=128, auto=1
09:26:32.504 (loader): gauge old value = 8
09:26:32.505 (loader): flash, block=9, bs=128, auto=1
09:26:32.510 (loader): gauge old value = 9
09:26:32.511 (loader): flash, block=10, bs=128, auto=1
09:26:32.516 (loader): gauge old value = 10
09:26:32.517 (loader): flash, block=11, bs=128, auto=1
09:26:32.522 (loader): gauge old value = 11
09:26:32.524 (loader): flash, block=12, bs=128, auto=1
09:26:32.529 (loader): gauge old value = 12
09:26:32.530 (loader): flash, block=13, bs=128, auto=1
09:26:32.534 (loader): gauge old value = 13
09:26:32.536 (loader): flash, block=14, bs=128, auto=1
09:26:32.540 (loader): gauge old value = 14
09:26:32.541 (loader): flash, block=15, bs=128, auto=1
09:26:32.546 (loader): gauge old value = 15
09:26:32.547 (loader): flash, block=16, bs=128, auto=1
09:26:32.552 (loader): gauge old value = 16
09:26:32.553 (loader): flash, block=17, bs=128, auto=1
09:26:32.559 (loader): gauge old value = 17
09:26:32.560 (loader): flash, block=18, bs=128, auto=1
09:26:32.565 (loader): gauge old value = 18
09:26:32.566 (loader): flash, block=19, bs=128, auto=1
09:26:32.571 (loader): gauge old value = 19
09:26:32.572 (loader): flash, block=20, bs=128, auto=1
09:26:32.577 (loader): gauge old value = 20
09:26:32.578 (loader): flash, block=21, bs=128, auto=1
09:26:32.583 (loader): gauge old value = 21
09:26:32.584 (loader): flash, block=22, bs=128, auto=1
09:26:32.589 (loader): gauge old value = 22
09:26:32.590 (loader): flash, block=23, bs=128, auto=1
09:26:32.595 (loader): gauge old value = 23
09:26:32.596 (loader): flash, block=24, bs=128, auto=1
09:26:32.601 (loader): gauge old value = 24
09:26:32.603 (loader): sending reboot
09:26:32.603 (loader): begin wait_until_offline
09:26:32.606 (ports 6): unknown action: unbind
09:26:32.607 (ports 6): del child: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0
09:26:32.610 (ports 6): unknown action: unbind
09:26:32.619 (ports 6): del device: location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:32.653 (loader): HID/linux: something changed, try reading a descriptor
09:26:32.653 (loader): HID/linux: Device was just disconnected
09:26:32.653 (loader): offline, waited 1
09:26:32.653 (loader): end operation, total time = 0.363 seconds
09:26:32.654 (loader): set background IMG_REBOOT_OK
09:26:32.662 (loader): redraw timer set, image 14 to show for 1200 ms
09:26:33.082 (ports 6): add device: subsys=usb, type=usb_device, location=/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
09:26:33.082 (ports 6): devnode=/dev/bus/usb/001/013, subsystem=usb, ifacenum=-1
09:26:33.082 (ports 6): usb_add: /dev/bus/usb/001/013 (Teensy 2.0) Serial
09:26:33.864 (loader): redraw, image 9
09:26:35.387 (loader): Verbose Info event
