// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 1-5: Respond to Pushbuttons & Volume Knob
// Modified for teensy 4.0 and audio shield
// Do more while playing. Monitor pushbuttons and adjust
// the volume. Whe the buttons are pressed, stop playing
// the current file and skip to the next or previous.
#include <SerialFlash.h>
#include <Bounce.h>
AudioPlaySdWav playSdWav1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s1, 1);
Bounce button0 = Bounce(0, 15);
Bounce button2 = Bounce(2, 15); // 15 = 15 ms debounce time
// Use these with the Teensy Audio Shield rev D (I think! RR)
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11
#define SDCARD_SCK_PIN 13
#define ledPin 3
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
pinMode(ledPin, OUTPUT);
pinMode(0, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
int filenumber = 0; // while file to play
const char * filelist[4] = {
"SDTEST1.WAV", "SDTEST2.WAV", "SDTEST3.WAV", "SDTEST4.WAV"
elapsedMillis blinkTime;
if (playSdWav1.isPlaying() == false) {
const char *filename = filelist[filenumber];
filenumber = filenumber + 1;
if (filenumber >= 4) filenumber = 0;
Serial.print("Start playing ");
Serial.println(filename);
playSdWav1.play(filename);
delay(10); // wait for library to parse WAV info
// blink the LED without delays
if (blinkTime < 250) {
digitalWrite(ledPin, LOW);
} else if (blinkTime < 500) {
digitalWrite(ledPin, HIGH);
blinkTime = 0; // start blink cycle over again
// read pushbuttons
button0.update();
if (button0.fallingEdge()) {
Serial.println("Button (pin 0) Press");
playSdWav1.stop();
button2.update();
if (button2.fallingEdge()) {
Serial.println("Button (pin 2) Press");
playSdWav1.stop();
filenumber = filenumber - 2;
if (filenumber < 0) filenumber = filenumber + 4;
// read the knob position (analog input A2)
int knob = analogRead(A2);
float vol = (float)knob / 1280.0;
sgtl5000_1.volume(vol);
//Serial.print("volume = ");
//Serial.println(vol);
