Hi there,
I would like to use the "normal" USB function of Teensy 4.0 for serial communication.
The integrated micro USB female connector works fine if I connect a standard cable. Unfortunately, the available USB micro plugs take too much space and collide with other electronics.
My question: Is it possible to solder an own USB cable to D-, D+, GND and VIN and use the regular Serial.print by that line? This would save a lot of space, and is clearly the better option than trying to manually remove the existing micro USB female connector...
Thank you in advance!
Frederic
Frederic
