Results 1 to 9 of 9
Thread: Reboot Teensy programmatically ...
    Is there a safe way to do an intended reboot for my Teensy?
    I read a little and it sounds that all methods seem to be complicated, needing hardware changes and/or are prone to damage the Teensy even substantially.
    And - why is such a method NOT implemented so far?
    13,943
    It certainly is available and implemented and posted widely ...
    Not indicated what Teensy is in use? There was an issue at some point - now resolved - with Teensy 4.0 - but for AVR Teensy there is a documented and posted solution.
    I found this for you: pjrc.com/threads/55429-Easy-Reset-from-Software
    OKay, I am currently using a Teensy 3.6.
    I know this posting and was searching for a more straightforward method.
    13,943
    #define CPU_RESTART_ADDR (uint32_t *)0xE000ED0C
    #define CPU_RESTART_VAL 0x5FA0004
    #define CPU_RESTART (*CPU_RESTART_ADDR = CPU_RESTART_VAL);
    This is pretty easy and should work given those three lines:
          if ( 'r' == foo ) CPU_RESTART; // restart CPU
    Jan 2020
    Port Elizabeth
    71
    This is what I do on the Teensy 4.0
    void doReboot() {
      saveStatus();
      // send reboot command -----
      SCB_AIRCR = 0x05FA0004;
    saveStatus() is my routine to save the machine state in a FRAM.
    This works for me.
    13,943
    Quote Originally Posted by PDOS View Post
    void doReboot() {
      saveStatus();
    This works for me.
    That is a cleaner example - where post #4 hard codes the value to a new #define :: #define SCB_AIRCR (*(volatile uint32_t *)0xE000ED0C) // Application Interrupt and Reset Control
    ... a simple search and found that one not using the #define.
    Dec 2020
    7
    Does this also work for teensy 4.1?
    13,943
    Yes, it uses the same processor and responds the same way.
    24,111
    It works on all ARM Cortex-M processors.
