Results 1 to 3 of 3
Thread: Teensy 4.0 Audio Shield; 344Hz buzz when using line-in
    Dec 2019
    8
    Hi all,
    I have an odd problem regarding a strange 344Hz buzz which I'm hearing from the teensy audio shield. My setup is as follows:
    electret mic (biased w/ 3.3V and 4.7k resistor)-->100uF cap --> LM386 amplifier --> Audio Shield Line-in L
    The strange thing is that I only hear this buzzing when I'm adjusting volume each time a 128-sample block is available (see code below). If I comment out the lines
    int knob2 = analogRead(A2);
    float vol = knob2 / 1023.0;
    if(vol<0.01) vol=0.0; //threshold filtering out the noise floor of potentiometer measurement
    sgtl5000.volume(vol);
    Then the buzzing goes away. My hunch is that this buzzing is caused by some kind "blip" every time the sgtl5000.volume() command is called (1/44100*128=2.9us --> 1/2.9us=344Hz).
    What's even stranger is I don't have any of these issues when I use the teensy mic-input.
    In my larger project I use audioRecordQueue and audioPlayQueue to do some other effects that I won't get into here.
    Has anyone run into an issue like this before? I can't figure out the relationship between headphone volume adjustments and line-in buzzing.
    #include <SerialFlash.h>
    #include <Bounce.h>
    const int baudRate = 115200;
    const uint32_t blockSize=AUDIO_BLOCK_SAMPLES;
    //Create pointers to be assigned to input and output buffers, create input/output arrays for LMS filter
    //Teensy audio library works on int16_t (equivalent in size with q15 data), the LMS filter is running on f32 data
    int16_t * ptr_in;
    int16_t * ptr_out;
    //Instantiate audio library objects, make connections
    AudioInputI2S i2s_in; //Audio input
    AudioOutputI2S i2s_out; //Audio output
    AudioRecordQueue Q_1_rec; //Object for storing audio blocks and accessing as arrays
    AudioPlayQueue Q_1_play;  //object to write array to for output
    AudioConnection patchcord1(i2s_in,0,Q_1_rec,0);
    AudioConnection patchcord2(Q_1_play,0,i2s_out,0);
    AudioConnection patchcord3(Q_1_play,0,i2s_out,1);
    AudioControlSGTL5000 sgtl5000;
    //Define input to system. Uncomment the input you want to use
    //const int input = AUDIO_INPUT_MIC;
    const int input = AUDIO_INPUT_LINEIN;
      pinMode(13,OUTPUT); //for onboard indicator LED
      Serial.begin(baudRate);
      AudioMemory(10);
      //enable audio shield, select input/mic gain, and initialize output level
      sgtl5000.enable();
      if(input == AUDIO_INPUT_MIC){
        sgtl5000.inputSelect(AUDIO_INPUT_MIC);
        sgtl5000.micGain(30);
        sgtl5000.volume(0.2);
        Serial.print("Teensy Audio Shield mic input selected \n");
      else{
        sgtl5000.inputSelect(AUDIO_INPUT_LINEIN);
        sgtl5000.lineInLevel(7);
        sgtl5000.volume(0.5);
        Serial.print("Teensy Audio Shield line-in input selected \n");
      //Begin the record audio queue
      Q_1_rec.begin();
      Serial.print("AUDIO_BLOCK_SAMPLES = ");
      Serial.print(AUDIO_BLOCK_SAMPLES);
      Serial.print("\n");
      Serial.print("Setup Complete \n");
      digitalWrite(13,HIGH);  //onboard LED indicator to show setup sucessful
      //check to see if there is a queue block available
      if(Q_1_rec.available()){
        //Set the output volume level by reading potentiometer
        //copy addresses of 128 samples in queue block to ptr_1
        ptr_in = Q_1_rec.readBuffer();
        //get pointer to output buffer "empty" array
        ptr_out = Q_1_play.getBuffer();
        for(uint8_t i=0;i<blockSize;i++){
          ptr_out[i]=ptr_in[i];
        //Output the buffer to be played
        Q_1_rec.freeBuffer();
        Q_1_play.playBuffer();
    1,252
    Your problem might be that you are updating the volume thousands of times a second. Updating it only when the volume pot has changed should fix it.
    Replace this:
    with this:
        static int vol = 0;
        if (knob2 != vol) {
          vol = knob2;
          sgtl5000_1.volume(knob2 / 1023.);
    Pete
    Dec 2019
    8
    Replace this:
    with this:
        static int vol = 0;
        if (knob2 != vol) {
          vol = knob2;
    Pete
    Thanks Pete, I'll experiment with changing the volume less frequently. What confuses me is how this buzzing is only happening when I use the line-in. When I switch to the mic-in it goes away. The volume change I'm enacting should only be affecting the headphone output level so it seems strange to me that changing the volume only makes buzzing when I'm using a line-input.
