Results 1 to 5 of 5
Thread: Audio Shield 4.0 + electric guitar input
    Mar 2020
    1
    Does anyone have experience or recommendations on how to interface an analog electric guitar mono signal to the Teensy 4.0 Audio Shield?
    Audio shield "Mic" input or "Line In" input or Teensy A/D input?
    Impedance matching circuit, etc?
    -Joe
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,326
    A buffer from an op amp would make sense to me before the AD pin or the line in input.
    Feb 2020
    South Africa
    9
ID:	19300Click image for larger version.
    Quote Originally Posted by JK2940 View Post
    -Joe
    Use the line in (combine the L and R)
    Then use the first stage OpAmp from either:
    https://www.electrosmash.com/pedalshield-uno
    or
    http://wiki.openmusiclabs.com/wiki/StompShield
    I attach the schematics - I have used both of these
    Would you power the OP Amp with 3.3v or 5v?
    Feb 2020
    South Africa
    9
    Quote Originally Posted by neroroxxx View Post
    I used both with an ATMega1284 with a +5v supply but the MCP6001/2/4 data indicates a power supply range of 1.8V to 6.0V, and the TL97x family operates at voltages as low as 1.35 V.
