Results 1 to 1 of 1
Thread: Credentials/WiFiManager for Teensy, SAM DUE, SAMD, STM32 running ESP8266 AT shield
    Jan 2020
    Toronto, Canada
    25
    https://github.com/khoih-prog/ESP_AT_WiFiManager
    How To Install Using Arduino Library Manager
    This library is a Credentials / WiFi Connection Manager with fallback web configuration portal similar to other WiFiManagers
    1. Tzapu WiFiManager
    2. Ken Taylor WiFiManager
    3. ESP_WiFiManager
    This library supports Teensy, SAM DUE, SAMD, STM32, etc. boards running ESP8266 AT-command shields.
    The web configuration portal, served from the ESP8266 AT-command shields is operating as an access point (AP) with configurable static IP address or use default IP Address of 192.168.4.1
    Sample Code
    #define _ESP_AT_LOGLEVEL_   0
    #define DEBUG_WIFIMGR       true  //false
    #if ( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3)  ||defined(STM32F4) || defined(STM32F7) )
      #if defined(ESP8266_AT_USE_STM32)
      #undef ESP8266_AT_USE_STM32
      #define ESP8266_AT_USE_STM32      true
    #if ( defined(ARDUINO_SAM_DUE) || defined(__SAM3X8E__) )
      #if defined(ESP8266_AT_USE_SAM_DUE)
      #undef ESP8266_AT_USE_SAM_DUE
      #define ESP8266_AT_USE_SAM_DUE      true
    #if ( defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
       || defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
       || defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(__SAMD21G18A__) \
       || defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) )
      #if defined(ESP8266_AT_USE_SAMD)
        #undef ESP8266_AT_USE_SAMD
      #define ESP8266_AT_USE_SAMD      true
    #ifdef CORE_TEENSY
      // For Teensy 4.0
      #define EspSerial Serial2   //Serial2, Pin RX2 : 7, TX2 : 8
      #if defined(__IMXRT1062__)
      #define BOARD_TYPE      "TEENSY 4.0"
      #elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
      #define BOARD_TYPE      "TEENSY LC or 2.0"
      #else
      #define BOARD_TYPE      "TEENSY 3.X"
    #elif (ESP8266_AT_USE_SAMD)
    // For SAMD
      #define EspSerial Serial1
      #if defined(ARDUINO_SAMD_ZERO)
        #define BOARD_TYPE      "SAMD Zero"
      #elif defined(ARDUINO_SAMD_MKR1000)
        #define BOARD_TYPE      "SAMD MKR1000"
      #elif defined(ARDUINO_SAMD_MKRWIFI1010)
        #define BOARD_TYPE      "SAMD MKRWIFI1010"
      #elif defined(ARDUINO_SAMD_NANO_33_IOT)
        #define BOARD_TYPE      "SAMD NANO_33_IOT"
      #elif defined(ARDUINO_SAMD_MKRFox1200)
        #define BOARD_TYPE      "SAMD MKRFox1200"
      #elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
        #define BOARD_TYPE      "SAMD MKRWAN13X0"
      #elif defined(ARDUINO_SAMD_MKRGSM1400)
        #define BOARD_TYPE      "SAMD MKRGSM1400"
      #elif defined(ARDUINO_SAMD_MKRNB1500)
        #define BOARD_TYPE      "SAMD MKRNB1500"
      #elif defined(ARDUINO_SAMD_MKRVIDOR4000)
        #define BOARD_TYPE      "SAMD MKRVIDOR4000"
      #elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
        #define BOARD_TYPE      "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
      #elif ( defined(__SAM3X8E__) || (__SAM3X8E__) || (__CPU_ARC__) )
        #define BOARD_TYPE      "SAMD Board"
      #else
        #define BOARD_TYPE      "SAMD Unknown"
    #elif (ESP8266_AT_USE_SAM_DUE)
    // For SAM DUE
      #define BOARD_TYPE      "SAM DUE"
    #elif (ESP8266_AT_USE_STM32)
    // For STM32F
      #define BOARD_TYPE      "STM32F"
    #else
    // For other boards. Change Serial as necessary
    #define EspSerial Serial3
    #define BOARD_TYPE      "Unknown"
    // Must be before #include <ESP_AT_WiFiManager.h>
    #define EEPROM_START        0
    #include <ESP_AT_WiFiManager.h>              //https://github.com/khoih-prog/ESP_AT_WiFiManager
    // Your Mega <-> ESP8266 baud rate:
    #define ESP8266_BAUD 115200
    // SSID and PW for Config Portal
    #ifdef CORE_TEENSY
    String ssid = "ESP_AT_" + String(0x1ABCDEF, HEX);
    #else
    String ssid = "ESP_AT_" + String(0xABCDEF, HEX);
    const char* password = "ESP_AT_PW";
    IPAddress staticAP_IP = IPAddress(192,168,100,1);
    // SSID and PW for your Router
    String Router_SSID;
    String Router_Pass;
    // Onboard LED I/O pin on board
    const int LOCAL_PIN_LED = 13; // Pin 13, Controls the onboard LED.
    #define LED_ON    HIGH
    #define LED_OFF   LOW
    void heartBeatPrint(void)
      static int num = 1;
      if (WiFi.status() == WL_CONNECTED)
        Serial.print("H");        // H means connected to WiFi
        Serial.print("F");        // F means not connected to WiFi
      if (num == 80)
        num = 1;
      else if (num++ % 10 == 0)
        Serial.print(" ");
    void check_status()
      static unsigned long checkstatus_timeout = 0;
      //KH
      #define HEARTBEAT_INTERVAL    10000L
      // Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
      if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
        heartBeatPrint();
        checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
    void enterConfigPortal(void)
      //Local intialization. Once its business is done, there is no need to keep it around
      ESP_AT_WiFiManager ESP_AT_wiFiManager;
      ESP_AT_wiFiManager.setDebugOutput(true);
      ESP_AT_wiFiManager.setMinimumSignalQuality(-1);
      ESP_AT_wiFiManager.setAPChannel(1);
      // Default AP IP is 192.168.4.1. Uncomment to use different AP IP
      ESP_AT_wiFiManager.setAPStaticIPConfig(staticAP_IP);
      // Set static STA IP
      ESP_AT_wiFiManager.setSTAStaticIPConfig(IPAddress(192,168,2,114));
      //Check if there is stored WiFi router/password credentials.
      //If not found, device will remain in configuration mode until switched off via webserver.
      Serial.print("Opening Config Portal. ");
      Router_SSID = ESP_AT_wiFiManager.WiFi_SSID();
      Router_Pass = ESP_AT_wiFiManager.WiFi_Pass();
      if (Router_SSID != "")
        ESP_AT_wiFiManager.setConfigPortalTimeout(60); //If no access point name has been previously entered disable timeout.
        Serial.println(F("Got stored Credentials. Timeout 60s"));
        Serial.println(F("No stored Credentials. No timeout"));
      // SSID to uppercase
      ssid.toUpperCase();
      //Starts an AP and goes into a blocking loop awaiting configuration
      Serial.println("Start Config Portal, SSID = " + ssid + ", Pass = " + password);
      digitalWrite(LOCAL_PIN_LED, LED_ON); // Turn led on as we enter Config Portal
      if (!ESP_AT_wiFiManager.startConfigPortal((const char *) ssid.c_str(), password))
        Serial.println(F("Not connected to WiFi but continuing anyway."));
        Serial.println(F("WiFi connected...yeey"));
      digitalWrite(LOCAL_PIN_LED, LED_OFF); // Turn led off as we exit Config Portal
      // initialize the LED digital pin as an output.
      pinMode(LOCAL_PIN_LED, OUTPUT);
      digitalWrite(LOCAL_PIN_LED, LED_ON); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
      unsigned long startedAt = millis();
      delay(200);
      Serial.println("\nStart ConfigOnStartup on " + String(BOARD_TYPE));
      // initialize serial for ESP module
      EspSerial.begin(115200);
      // initialize ESP module
      WiFi.init(&EspSerial);
      // check for the presence of the shield
      if (WiFi.status() == WL_NO_SHIELD)
        Serial.println(F("WiFi shield not present"));
        // don't continue
        while (true);
      enterConfigPortal();
      // For some unknown reason webserver can only be started once per boot up
      // so webserver can not be used again in the sketch.
      #define WIFI_CONNECT_TIMEOUT        30000L
      #define WHILE_LOOP_DELAY            200L
      #define WHILE_LOOP_STEPS            (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
      while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
        int i = 0;
        while((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
          delay(WHILE_LOOP_DELAY);
      Serial.print(F("After waiting "));
      Serial.print((millis()- startedAt) / 1000);
      Serial.print(F(" secs in setup(), connect result is "));
        Serial.print(F("connected. Local IP: "));
        Serial.println(WiFi.localIP());
      // put your main code here, to run repeatedly
      check_status();
    This is the terminal output when running Teensy 4,0 board with ESP8266 AT shield
    Start ConfigOnSwitch on TEENSY 4.0
    Opening Config Portal. *WM: Header = ESP_AT, SSID = ****, PW = ****
    *WM: Host Name = nothing
    Start Config Portal, SSID = ESP_AT_1ABCDEF, Pass = ESP_AT_PW
    *WM: Configure AP: ESP_AT_1ABCDEF
    *WM: AP PW: ESP_AT_PW
    *WM: Custom AP IP: 192.168.100.1
    *WM: AP IP: 192.168.100.1
    *WM: HTTP server on channel 1
    *WM: Handle root
    *WM: Info
    *WM: Sent info page
    *WM: Handle root
    *WM: Handle WiFi
    *WM: Scan Network
    *WM: HueNet / -28
    *WM: HueNet1 / -41
    *WM: HueNet2 / -59
    *WM: Sent config page
    *WM: WiFi save
    *WM: Sent wifisave page
    *WM: Connect to new AP
    *WM: Connect wifi with new params
    *WM: Data cleared
    *WM: Static IP : 192.168.2.114
    *WM: Connect result: WL_CONNECTED
    After waiting 0 secs in setup(), connect result is connected. Local IP: 192.168.2.114
    HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH
    And the Config Portal screens:
