Results 1 to 2 of 2
Thread: Press Brake Controller
    Hi
    I started a project using the Teensy 3.6 to control a Press Brake machine. The design can however be used for many applications as I designed it as generic as possible.
    The Controller has the following functions:
    1) Teensy 3.6
    2) 4D systems 7.0" display (could be any serial display)
    3) 24v Input voltage.
    4) 1 x Rs485 channel
    5) 3 x 0 to 10V PWM analog signals ( galvanic isolated) used to drive VFD's
    6) 3 x Step/Dir channels for stepper drives
    7) 3 x Encoder / glass scale input channels (TTL and differential)
    8) 8 x Open Collector output drivers specifically for operating automotive or relay loads
    9) 8 x optically isolated inputs
    I just received the PCB's so once they have been built up and tested I will report back.
    I forgot, it also has an I2C expansion port for another 16 I/O's
