Results 1 to 2 of 2
Thread: Any solutions to program teensy 4.0 wirelessly?
    Exactly that:
    Are there any solutions to program the teensy 4.0 wirelessly?
    I have a battery powered prop that will be inside of a case that will be very difficult to program again and again during development phase. I have seen somewhere someone was programming an arduino board wirelessly. Is there a solution for this?
    Can I use something like a wireless usb system?"
    6,357
    As you already bumped one of the other threads, there is probably not much to add here.
    One way is to have the Teensy plugged into an RPI and then setup a wireless connection to the RPI, and either run Arduino on the RPI or simply download the executable to the RPI and use a CLI command to program the Teensy...
