Results 1 to 2 of 2
Thread: pinMode()
    pinMode()
    Hey guys,
    which possibilities do I have in the pinMode() void?
    I know INPUT, OUTPUT, INPUT_PULL(UP/DOWN)
    Are there more possibilities / do I have to set a pinmode when i want to use it as an i2c pin (SDA/SCL)?
    The compiler didnīt print a mistake, when i coded pinMode(19,SCL) but I donīt think thatīs necessary / right ...
    Thanks,
    Ben
    10,922
    Teensy at hand not specified?
    Not sure if it makes a diff but for Teensy 3.x:
    #define INPUT		0
    #define OUTPUT		1
    #define INPUT_PULLUP	2
    #define INPUT_PULLDOWN   3
    #define OUTPUT_OPENDRAIN 4
    #define INPUT_DISABLE   5
    Typically pins used for a 'bus', i2c or SPI or Serial#, are set in the .begin() call. Any calls to pinMode() can only mess up the needed configuration.
