Title says it all.
manitou Senior Member+ Mar 18, 2020 #2 yeahtuna said: Title says it all. Click to expand... No. look at pin info card: https://www.pjrc.com/teensy/pinout.html If there are gray pin numbers associated with pin, then it can can do "digital things" like pullups/pulldowns. A10, A11 A21, A22 are analog only. you can also also study the T3.6 ref manual, https://www.pjrc.com/teensy/datasheets.html
Y yeahtuna Well-known member Mar 18, 2020 #3 manitou said: No. look at pin info card: https://www.pjrc.com/teensy/pinout.html If there are gray pin numbers associated with pin, then it can can do "digital things" like pullups/pulldowns. A10, A11 A21, A22 are analog only. you can also also study the T3.6 ref manual, https://www.pjrc.com/teensy/datasheets.html Click to expand... Actually I did reference the datasheet. They don't come right out and say, 'BTW, there are not pull-ups on those ports'. I kinda knew the answer as my prototype was not.playing nicely. It's not the end of the world, but it's good to have it properly documented now. Cheers
