Check for SD card on t_3.6 or audio-shield
C0d3man
I have a little problem with my T_3.6 + audio-shield: I want to check if a sd-card is placed into the T_3.6 and, if not, than try to check if there is one installed on the audio-shield. But if I run the following code with a sd-card inside the T_3.6, it is not found:
#define DEBUG 1
// Teensy Audio Shield
#define SDCARD_AUDIO_CS_PIN    10
#define SDCARD_AUDIO_MOSI_PIN  7
#define SDCARD_AUDIO_SCK_PIN   14
#ifndef TEENSY4
// Teensy 3.5 & 3.6 SD card
#define SDCARD_CS_PIN    4 //BUILTIN_SDCARD
#define SDCARD_MOSI_PIN  11
#define SDCARD_SCK_PIN   13
#else
#define SDCARD_CS_PIN    10
int8_t check_sd_cards(void)
  int8_t ret = -1;
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
#ifdef TEENSY4
#ifdef DEBUG
  Serial.println(F("Checking audio-board SD (T_4.0)"));
  if (SD.begin(SDCARD_CS_PIN))
#ifdef DEBUG
    Serial.println(F("Using SD-card on audio-board (T_4.0)"));
    ret = SDCARD_CS_PIN;
#else // not TEENSY4
#ifdef DEBUG
  Serial.println(F("Checking on-board SD (T_3.6)"));
#ifdef DEBUG
    Serial.print(F("Using SD-card on Teensy (T_3.6): "));
    Serial.println(SDCARD_CS_PIN, DEC);
    // SD Card from audio-board
#ifdef DEBUG
    Serial.println(F("Checking audio-board SD (T_3.6)"));
    SPI.setMOSI(SDCARD_AUDIO_MOSI_PIN);
    SPI.setSCK(SDCARD_AUDIO_SCK_PIN);
    if (SD.begin(SDCARD_AUDIO_CS_PIN))
#ifdef DEBUG
      Serial.println(F("Using SD-card on audio-board (T_3.6):"));
      Serial.println(SDCARD_AUDIO_CS_PIN, DEC);
      ret = SDCARD_AUDIO_CS_PIN;
#ifdef DEBUG
  if (ret < 0)
    Serial.println(F("Cannot find SD card!"));
  return (ret);
  delay(500); // needed for serial console
  int8_t sd = check_sd_cards();
  Serial.println(sd, DEC);
This results in:
-1
What am I doing wrong?
Regards, Holger
you didn't make BUILTI_SDCARD one of your selections? and BUILTIN_SDCARD is 254 which is a negative number for 8 bit int. here's my version of your sketch
#define DEBUG 1
#ifndef TEENSY4
#define SDCARD_CS_PIN    [B][COLOR="#FF0000"]BUILTIN_SDCARD[/COLOR][/B]
#else
[B][COLOR="#FF0000"]int16_t [/COLOR][/B]check_sd_cards(void)
 [B][COLOR="#FF0000"] int16_t [/COLOR][/B]ret = -1;
#ifdef TEENSY4
#ifdef DEBUG
#ifdef DEBUG
#ifdef DEBUG
#ifdef DEBUG
#ifdef DEBUG
#ifdef DEBUG
#ifdef DEBUG
  if (ret < 0)
  return (ret);
  [B][COLOR="#FF0000"]while(!Serial);[/COLOR][/B]
  [B][COLOR="#FF0000"]int16_t[/COLOR][/B] sd = check_sd_cards();
Ahhhh! I thought I am getting a pin number when using BUILTIN_SDCARD and havn't checked this before. Many thanks!!!!
Regards, Holger
