Results 1 to 4 of 4
Thread: HELP 3-Space Nano Carrier Board
    Mar 2020
    2
    Hello, I have an aeronautical project for an EFIS, I use an Arduino Mega 2560 with a 3-Space Nano Carrier Board to have Le Pitch, Roll et Yaw.
    Nothing works, can you help me and see where I was wrong?
    Regards,
    Alfred
    My Arduino code:
    #include "SPI.h"
    #include "Wire.h"
    //#include "FT_NHD_43CTP_SHIELD.h"
    #include "FT_NHD_43RTP_SHIELD.h"
    #include <Encoder.h>
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BMP280.h>
    * Cette section contient des instructions "define" qui sont utilisées pour configurer
    * unité pour votre application particulière. Sauf si vous êtes programmeur, ce
    * est la seule partie du code que vous devez modifier. Veuillez consulter le
    * manuel pour plus de détails au-delà des commentaires. Vous changez les chiffres et
    * valeurs true ou false uniquement. Ne changez rien d'autre.
    #define MaxVertSpeed 4000 // will determine the size of the VSI scale on the indicator.
    #define PrefSpeedUnits 3 //1 is kts, 2 is mph (defaut), 3 is km/h
    #define PrefPressureUnits 3 // 1 is inHG (defaut), 2 is mmHg, 3 is hPa
    #define PrefAltUnits 1 // 1 is ft (defaut), 2 is meters
    #define WAStart 45 // the low side of the airspeed indicator white arc in PrefSpeedUnits
    #define WAEnd 100 // the high side of the airspeed indicator white arc
    #define GAStart 52 // the low side of the airspeed indicator green arc
    #define GAEnd 116 // the high side of the airspeed indicator green arc
    #define BLine 0 // the airspeed indicator blue line. Use 0 if you do not need a blue line.
    #define RLine 142 // the airspeed indicator red line.
    #define MaxSpeed 250 // this is the top number on the gauge. This should be a little higher than your red line.
    #define SpeedTics 50 // this determines how many ticks will print out on the speed slider
    #define SpeedSlider false //false will give gauge like readout. True gives ticker type readout
    #define HeadingNum false // Black box with the heading on the DG strip
    #define NumAverageTrend 10 // Higher numbers are less jittery. Lower numbers are more responsive. Applies to VSI and Rate of Turn
    #define ECPD 2 // (4 defaut) number of ecoder clicks per detent. Probably 1, 2, or 4.
    #define StartMenu 6 // defines where the cursor starts. 6 is the Altimeter Adjust
    #define StartBrightness 255 // how bright the unit is on power-on. 255 is full bright. 0 is completely dark.
    #define StartHeadingBug 360 // where the heading bug shows up.
    #define StartingPressure 1013.25 // 29.92 (defaut) Put this as the pressure in your preferred unit system. 29.92, 1013.25, 760.0;
    #define StaticCalibrationOffset 3 // This is a value used to calibrate your static BMP280. Start with 0, and make tiny changes. Each 1 you add adds about 25 feet (8 meters). Calibrate this one first.
    #define AirspeedCalibrationOffset 0 // This is a value used to calibrate your airspeed. Start with 0. Calibrate this one after the Static. Each one is 1 mph.
    #define CenterDisplayType 1 // 1 is yellow line moving with the horizon. 2 Yellow lines that stay level. 3 gives yellow plane.
    #define dynamicsky true // false does not change the display color based on pitch. true does. Sky gets deeper blue as you point up.
    #define dynamicground false // false does not change the display color based on pitch. true does. Groiund gets reddish as you point down.
    #define PermRollOffset 0 // this is used to calibrate for AHRS offsets and mounting. (Not used in this version.)
    #define PermPitchOffset 0 // this is used to calibrate for AHRS offsets and mounting. (Not used in this version.) Use calibration routine instead.
    #define PermCompassOffset 0 // this is used to calibrate for AHRS offsets and mounting. (Not used in this version.)
    // Used in Serial Data Transfer. This binaryInt allows the sensor to recieve floating point numbers and automatically decode them
    typedef union {
    float floatingPoint;
    byte binary[4];
    binaryFloat;
    binaryFloat CH;
    binaryFloat CP;
    binaryFloat CR;
    byte CalibrationStatus = 0;
    // end data types and variables used in serial transfer of data .
    int BotWhA;
    int TopWhA;
    int BotGA;
    int TopGA;
    int RL;
    int BL;
    int NumTics;
    int TicMap;
    int HalfSpeedTics;
    int CurrentSpeed;
    float CurrentRoll; // angle in radians from -Pi to + Pi. - is to the left
    float CurrentPitch; // angle in radians from -Pi to + Pi. - is down
    float CurrentHeading = 0; // this will actually come from the IMU unit, but we will start with a number
    float CurrentRateOfTurn = -0.0115; // this is the number of radians per second. Number is for test purposes only, and cooresponds to a 2 minute left turn
    float CurrentRateOfClimb = 0;
    float CurrentAltitude = 400;
    float CurrentGs = 1;
    float PreviousHeading = 0;
    float PreviousAltitude = 0;
    float CurrentPressure = StartingPressure; // needed to switch on the fly.
    int HeadingBug = StartHeadingBug;
    int DispDegs;
    int brightness = StartBrightness; //Max = 255, min = 0
    int SpeedUnits = PrefSpeedUnits;
    int AltUnits = PrefAltUnits;
    int PressureUnits = PrefPressureUnits;
    int PressureDigits[] = {2,9,9,2};
    long OldEncoderPosition = -999;
    long NewEncoderPosition = -999;
    int Menu = StartMenu; // 1 is brightness, 2 is speed units, 3 is bug, 4 is trim, 5 is pressure, 6 is pressure units, 7 is alt units
    boolean MenuSelected = false;
    boolean ButtonDown = false;
    boolean ButtonReleased = false;
    int EncMove = 0;
    int EncMult = 1;
    unsigned long currentMicros; // = micros();
    unsigned long previousMicros;
    unsigned long intervalMicros;
    int eraseme = 0;
    boolean SensorError = false;
    int ErrorStreak = 0;
    float RollOffset = PermRollOffset;
    float PitchOffset = PermPitchOffset;
    float CompassOffset = PermCompassOffset;
    Encoder myEnc(19, 18); // these pins are interrupt capable. Reverse these if your encoder moves the menus the wrong way.
    Adafruit_BMP280 Static; // I2C communication with the static
    Adafruit_BMP280 Pitot; // I2C communication with the static
    /* Global object for transport */
    //FT801IMPL_SPI FTImpl(FT_CS_PIN,FT_PDN_PIN,FT_INT_PIN);
    FT800IMPL_SPI FTImpl(FT_CS_PIN,FT_PDN_PIN,FT_INT_PIN);
    /* Api to bootup FT800 or FT801, verify FT800 or FT801 hardware and configure display/audio pins */
    /* Returns 0 in case of success and 1 in case of failure */
    int16_t BootupConfigure(){
    uint32_t chipid = 0;
    FTImpl.Init(FT_DISPLAY_RESOLUTION);//configure the display to the WQVGA
    delay(20);//for safer side
    chipid = FTImpl.Read32(FT_ROM_CHIPID);
    /* Identify the chip */
    // if(FT801_CHIPID != chipid)
    if(FT800_CHIPID != chipid)
    Serial.print("Error in chip id read ");
    Serial.println(chipid,HEX);
    return 1;
    /* Set the Display & audio pins */
    FTImpl.SetDisplayEnablePin(FT_DISPENABLE_PIN);
    FTImpl.SetAudioEnablePin(FT_AUDIOENABLE_PIN);
    FTImpl.DisplayOn();
    FTImpl.AudioOn();
    return 0;
    void FlipNum(int Xloc, int Yloc, int TopDigit, int BottomDigit, int Twentiethsflip)
    { // This function is called from within a drawing list, and paints a 10 by 15 block with a rolling number display
    // location is upper right referenced. The requested area of the screen is blacked and blanked. This cannot be
    // used for more than two digits at a time. Twentiethsflip is the amount that the numbers have slid - as in 5/20ths
    // 0/20ths prints just the TopDigit. 20/20ths prints just the BottomDigit
    // use for the TopDigit or the BottomDigit if you want them to show up as blank.
    int NumDigits = 1;
    if ((BottomDigit >= 10) or (TopDigit >= 10)) NumDigits = 2;
    FTImpl.ColorRGB(0,0,0); // set the color to Black
    FTImpl.ClearStencil(0); // set the stencil to blank
    FTImpl.StencilOp(FT_INCR,FT_INCR); // set the stencil operation to mask the blank
    FTImpl.Begin(FT_RECTS); // get ready to make the box
    FTImpl.Vertex2ii(Xloc,Yloc,0,0);
    FTImpl.Vertex2ii(Xloc - (10 * NumDigits),Yloc + 16,0,0); // then draw the box that blanks the space and DEFINES THE STENCIL ....
    FTImpl.StencilOp(FT_KEEP,FT_KEEP); // and we are done building the stencil. Clear the stencil creating function
    FTImpl.ColorRGB(255,255,255); // set the color to White
    FTImpl.StencilFunc(FT_GREATER, 0, 255); // and olnly draw in the stencil
    if (TopDigit != -1) FTImpl.Cmd_Number(Xloc, Yloc-Twentiethsflip-1, 27, FT_OPT_RIGHTX, TopDigit); // print the part of the numbers that shows up in the box
    if (BottomDigit != -1) FTImpl.Cmd_Number(Xloc, Yloc+19-Twentiethsflip, 27, FT_OPT_RIGHTX, BottomDigit); // print the part of the numbers that shows up in the box
    FTImpl.StencilFunc(FT_ALWAYS, 1, 255); //go back to ignoring the stencil
    void DrawScreen()
    //** FTImpl.SetCTouchMode(FT_CTOUCH_MODE_EXTENDED); //set mode to extended for FT801
    int16_t xoffset,yoffset;
    xoffset = ((FT_DISPLAYWIDTH - 480)/2);
    yoffset = ((FT_DISPLAYHEIGHT - 272)/2);
    //** Begin building angle gauge stencil
    FTImpl.DLStart();
    // this should set the screen brightness
    FTImpl.Write(REG_PWM_DUTY,map(brightness, 0, 255, 0, 100));
    FTImpl.ClearColorRGB(0,0,0);
    FTImpl.Clear(1,0,1);
    // Draw the rays
    FTImpl.LineWidth(6);
    FTImpl.Begin(FT_LINES);
    FTImpl.Vertex2ii(145,70,0,0);
    FTImpl.Vertex2ii(157,81,0,0);
    FTImpl.Vertex2ii(165,61,0,0);
    FTImpl.Vertex2ii(171,67,0,0);
    FTImpl.Vertex2ii(178,43,0,0);
    FTImpl.Vertex2ii(186,56,0,0);
    FTImpl.Vertex2ii(200,41,0,0);
    FTImpl.Vertex2ii(203,49,0,0);
    FTImpl.Vertex2ii(220,36,0,0);
    FTImpl.Vertex2ii(221,44,0,0);
    FTImpl.Vertex2ii(260,36,0,0);
    FTImpl.Vertex2ii(259,44,0,0);
    FTImpl.Vertex2ii(280,41,0,0);
    FTImpl.Vertex2ii(277,49,0,0);
    FTImpl.Vertex2ii(302,43,0,0);
    FTImpl.Vertex2ii(294,56,0,0);
    FTImpl.Vertex2ii(315,61,0,0);
    FTImpl.Vertex2ii(309,67,0,0);
    FTImpl.Vertex2ii(335,70,0,0);
    FTImpl.Vertex2ii(323,81,0,0);
    // Draw a circle centered on 240, 150.
    FTImpl.ColorRGB(255,255,255);//set the color of the string to WHITE color
    FTImpl.PointSize(110*16);//circle
    FTImpl.Begin(FT_POINTS);
    FTImpl.Vertex2ii(240,150,0,0);
    FTImpl.StencilOp(FT_ZERO,FT_ZERO);
    FTImpl.ColorRGB(0,0,0);//set the color of the string to BLACK color
    FTImpl.PointSize(107 * 16);//inner circle
    //Trim the bottom of the circle off
    FTImpl.Vertex2ii(120,82,0,0);
    FTImpl.Vertex2ii(360,270,0,0);
    //** Stencil complete. Clear Screen to Sky Color
    int darkensky = 0;
    if (dynamicsky) darkensky = (int)(70*sin(CurrentPitch)); // darkensky won't change the sky's color unless dynamicsky is chosen
    if (darkensky > 0) darkensky = 0;
    FTImpl.ClearColorRGB(150+darkensky,150+darkensky,2 55);
    FTImpl.Clear(1,0,0); // the zero leaves the stencil in place
    //** Math work in progress. Draw in a red line. First, use only shallow angles and assume rightside up
    FTImpl.LineWidth(12);
    int darkenground = 0;
    if (dynamicground) darkenground = (int)(60*sin(CurrentPitch)); // darkenground won't change the ground's color unless dynamicground is chosen
    if (darkenground < 0) darkenground = 0;
    FTImpl.ColorRGB(120+darkenground,80-(darkenground/2),20-(darkenground/6)); //);//set the color to brown, with a redish adjustment as you head down,
    int LS; // left side intersect
    int RS; // right side intersect
    int LO = 0; // Left Offset - used when the line does not extend across the screen
    int RO = 0; // Right Offset - used when the line does not extend across the screen
    float CXP; // Center X Position
    float CYP; // Center Y Pos
    float TanCurrentRoll = tan(CurrentRoll); // Do math as few times as possible
    float SinCurrentRoll = sin(CurrentRoll);
    float CosCurrentRoll = cos(CurrentRoll);
    CXP = 240-SinCurrentRoll*((CurrentPitch/.0175)*3.6);
    CYP = 150-CosCurrentRoll*((CurrentPitch/.0175)*3.6);
    if ((CXP >= 0) and (CXP <= 480)) // the center of the line is on the screen
    LS = CYP+(CXP*TanCurrentRoll);
    RS = CYP-((480-CXP)*TanCurrentRoll);
    if (LS < 0) // The line begins above the display.
    {LO = CXP-((CYP*CXP)/(CYP-LS)); LS = 0;} // similar triangles
    else if (LS > 272) // The line begins below the display.
    {LO = CXP-((CXP*(272-CYP))/(LS-CYP)); LS = 272;} // similar triangles
    if (RS < 0) // The line ends above the display
    {RO = (480-CXP)-(((480-CXP)*CYP)/(CYP-RS)); RS = 0;} // similar triangles
    else if (RS > 272) // The line ends below the display
    {RO = (480-CXP)-(((480-CXP)*(270-CYP))/(RS-CYP)); RS = 272;} // similar triangles
    FTImpl.Begin(FT_EDGE_STRIP_B); // the use of 4 points ensures complete usability
    FTImpl.Vertex2ii(0,LS,0,0);
    FTImpl.Vertex2ii(0+LO,LS,0,0);
    FTImpl.Vertex2ii(480-RO,RS,0,0);
    FTImpl.Vertex2ii(480,RS,0,0);
    // VERY IMPORTANT. The ground should not show up if the sensor is offline.
    if (ErrorStreak > 16) // set to about the number of frames per second...
    FTImpl.LineWidth(24);
    FTImpl.ClearColorRGB(0,0,0); // set the color to black
    FTImpl.Clear(1,0,0); // the zero leaves the stencil in place, but clears the screen to black
    FTImpl.ClearColorRGB(255,0,0); // set the color to red
    FTImpl.Vertex2ii(140,20,0,0);
    FTImpl.Vertex2ii(340,252,0,0); // Draw the gigantic red x that says not to navigate...
    FTImpl.Vertex2ii(140,252,0,0);
    FTImpl.Vertex2ii(340,20,0,0);
    //** Reprint Angle Gauge from Stencil
    FTImpl.StencilFunc(FT_NOTEQUAL, 0, 255); //only operate on the stencil
    FTImpl.ColorRGB(255,255,255);//set the color to White
    FTImpl.PointSize(126*16);//circle
    FTImpl.StencilFunc(FT_ALWAYS, 1, 255); //clear the stencil function
    //** Add angle numbers to the stencil gauge
    FTImpl.Cmd_Number(140 , 62, 26, FT_OPT_CENTER, 50);
    FTImpl.Cmd_Text(160 , 36, 26, FT_OPT_CENTER, "2 Min (30)");
    FTImpl.Cmd_Number(305 , 36, 26, FT_OPT_CENTER, 30);
    FTImpl.Cmd_Number(340 , 62, 26, FT_OPT_CENTER, 50);
    // FTImpl.ColorRGB(255,255,255);//set the color of the string back to WHITE color
    FTImpl.LineWidth(16);
    //** Given CurrentHeading (float), overlay the DG Strip
    // Display is 480 pixels wide, so the center is at 240. 5 pixels is one degree
    // Draw the line strip line
    FTImpl.Vertex2ii(75,22,0,0);
    FTImpl.Vertex2ii(405,22,0,0);
    int Nearest5 = round(CurrentHeading/5) * 5;
    int Nearest10 = round(CurrentHeading/10) * 10;
    boolean NumTic = false;
    if (Nearest5 == Nearest10) NumTic = true;
    for (int degs = Nearest5 - 30; degs <= (Nearest5 + 30); degs = degs + 5)
    DispDegs = degs;
    if (DispDegs > 360) DispDegs = DispDegs - 360;
    if (DispDegs < 1) DispDegs = DispDegs + 360;
    if (NumTic) // This one is divisible by 10, and gets a number and a tic
    NumTic = false;
    FTImpl.Vertex2ii((degs-(CurrentHeading-40))*5+40,25,0,0);
    FTImpl.Vertex2ii((degs-(CurrentHeading-40))*5+40,22,0,0);
    FTImpl.Cmd_Number( (degs-(CurrentHeading-40))*5+40, 13, 26, FT_OPT_CENTER, DispDegs);
    else // This one is between numbers, and gets a tic only
    FTImpl.Vertex2ii((degs-(CurrentHeading-40))*5+40,15,0,0);
    NumTic = true;
    // Now draw the white arrow for no rate of turn
    FTImpl.Begin(FT_LINE_STRIP);
    FTImpl.Vertex2ii(240,0,0,0);
    FTImpl.Vertex2ii(240,41,0,0);
    FTImpl.Vertex2ii(238,29,0,0);
    FTImpl.Vertex2ii(242,29,0,0);
    FTImpl.Vertex2ii(236,27,0,0);
    FTImpl.Vertex2ii(240,31,0,0);
    FTImpl.Vertex2ii(244,27,0,0);
    // if option is selected, draw the Heading Number
    if (HeadingNum)
    FTImpl.ColorRGB(160,160,160);//set the color to White
    FTImpl.Vertex2ii(240-18, 0);
    FTImpl.Vertex2ii(240+18,15);
    FTImpl.ColorRGB(0,0,0);//set the color to Black
    FTImpl.Vertex2ii(240-16, 0);
    FTImpl.Vertex2ii(240+16,13);
    FTImpl.Cmd_Number(240, 6, 27, FT_OPT_CENTER, CurrentHeading);
    // Draw heading Bug if it shows up, and the Bug setting Regardless
    FTImpl.Cmd_Text(43, 260, 27, FT_OPT_CENTER, "* Bug:");
    FTImpl.Cmd_Number(87, 260, 27, FT_OPT_CENTER, HeadingBug);
    FTImpl.ColorRGB(255,165,4);//set the color to Orange
    //FTImpl.Cmd_Number(159, 260, 27, FT_OPT_CENTER, difference);
    int BugCalc = HeadingBug;
    if ((CurrentHeading < 41) and (HeadingBug > 319)) BugCalc = BugCalc - 360;
    if ((CurrentHeading > 319) and (HeadingBug < 41)) BugCalc = BugCalc + 360;
    if (abs(CurrentHeading-BugCalc) < 33) // it should be on the strip, so lets draw this sucker! - was 41
    FTImpl.LineWidth(32);
    FTImpl.Vertex2ii(240-((CurrentHeading-BugCalc)*5),23,0,0);
    FTImpl.Vertex2ii(240-((CurrentHeading-BugCalc)*5),2,0,0);
    //** End overlay the DG Strip
    //** Overlay Brightness Slider
    // remember brightness is 0-255
    FTImpl.ColorRGB(128,128,128);//set the color of the string to GREY color
    FTImpl.LineWidth(48);
    FTImpl.Vertex2ii(20,235,0,0);
    FTImpl.Vertex2ii(20,235-(255*.76),0,0); //255 scaled by 76%
    FTImpl.PointSize(10*16);//circle
    FTImpl.Vertex2ii(20,235-(brightness*.76),0,0); // this is the actual dot
    FTImpl.PointSize(8*16);//circle
    // include the Empty Battery Icon. This is greyed out in this version, but in the next version with the board, it will
    // be a live icon showing charging and discharging...
    FTImpl.ColorRGB(170,170,170);//set the color to GREY
    FTImpl.Vertex2ii(9,8,0,0);
    FTImpl.Vertex2ii(32,17,0,0);
    FTImpl.Vertex2ii(30,11,0,0);
    FTImpl.Vertex2ii(35,14,0,0);
    //FTImpl.ColorRGB(150,150,255);//set the color to SKY
    FTImpl.Vertex2ii(11,10,0,0);
    FTImpl.Vertex2ii(30,15,0,0);
    // WILL NEED to read battery info on pin A2, charge status on pin ?, and charging status on pin ? These are provided on the future board.
    FTImpl.Vertex2ii(13,12,0,0);
    FTImpl.Vertex2ii(28,13,0,0); // for now, just put a greyed out spot in the icon.
    //** Overlay Speed Strip - this will likely change to a software selectable optional slider and ticker
    // print out units...
    switch (SpeedUnits) { // overlay the Speed Units. These can change on the fly...
    case 1: FTImpl.Cmd_Text(55, 17, 27, FT_OPT_CENTER, "kts"); break;
    case 2: FTImpl.Cmd_Text(55, 17, 27, FT_OPT_CENTER, "mph"); break;
    case 3: FTImpl.Cmd_Text(55, 17, 27, FT_OPT_CENTER, "km/h"); break; }
    if (!SpeedSlider)
    {// this is the gauge type speed readout
    // lay out the speed line
    FTImpl.Vertex2ii(80,235,0,0);
    FTImpl.Vertex2ii(80,40,0,0);
    // lay out the color bands
    // White Arc
    FTImpl.LineWidth(40);
    FTImpl.Vertex2ii(78,235-BotWhA,0,0);
    FTImpl.Vertex2ii(78,235-TopWhA,0,0);
    // Yellow Line
    FTImpl.ColorRGB(255,232,0);//set the color of the string to YELLOW color
    FTImpl.Vertex2ii(82,235-TopGA,0,0);
    FTImpl.Vertex2ii(82,235-RL,0,0);
    // Green Line
    FTImpl.ColorRGB(0,185,0);//set the color of the string to Green color
    FTImpl.Vertex2ii(82,235-BotGA,0,0);
    // Red Line
    FTImpl.ColorRGB(185,0,0);//set the color of the string to Red color
    FTImpl.Vertex2ii(84,235-RL,0,0);
    FTImpl.Vertex2ii(76,235-RL,0,0);
    // Blue Line
    if (BL > 5)
    { // only draw it if we need it
    FTImpl.ColorRGB(32,32,185);//set the color of the string to Blue color
    FTImpl.Vertex2ii(84,235-BL,0,0);
    FTImpl.Vertex2ii(76,235-BL,0,0);
    // lay out the tic marks and scale text
    int count = 0;
    FTImpl.ColorRGB(255,255,255);//set the color of the string to White color
    for (int tics = 0; tics <= NumTics; tics++)
    TicMap = map(tics*SpeedTics,0,MaxSpeed,0,195); // 195 is the number of pixels it displays
    FTImpl.Vertex2ii(81, 235-TicMap);
    FTImpl.Vertex2ii(74,235-TicMap);
    FTImpl.Cmd_Number(71, 227-TicMap, 26, FT_OPT_RIGHTX, tics*SpeedTics);
    if (tics != 0)
    FTImpl.Vertex2ii(80, 235-TicMap+HalfSpeedTics);
    FTImpl.Vertex2ii(70,235-TicMap+HalfSpeedTics);
    // lay out the current speed tic and number
    TicMap = map(CurrentSpeed,0,MaxSpeed,0,195); // 195 is the number of pixels it displays
    FTImpl.Vertex2ii(89, 235-TicMap);
    FTImpl.Vertex2ii(78,235-TicMap);
    if (CurrentSpeed > 99)
    FTImpl.Vertex2ii(90, 226-TicMap);
    FTImpl.Vertex2ii(125,243-TicMap);
    FTImpl.Vertex2ii(92, 228-TicMap);
    FTImpl.Vertex2ii(123,241-TicMap);
    else if (CurrentSpeed > 9)
    FTImpl.Vertex2ii(113,243-TicMap);
    FTImpl.Vertex2ii(111,241-TicMap);
    FTImpl.Vertex2ii(102,243-TicMap);
    FTImpl.Vertex2ii(100,241-TicMap);
    FTImpl.Cmd_Number(92, 225-TicMap, 27, 0, CurrentSpeed);
    // this routine still needs to be written, but I am not in a hurry for it!
    //** Overlay the Angle Gauge, based on CurrentRoll
    // this will involve angle calculations.
    // the Center Strips, which can be one of three styles.
    int XOffset1 = 0; int YOffset1 = 0; int XOffset2 = 0; int YOffset2 = 0; int XOffset3 = 0; int YOffset3 = 0;
    if (CenterDisplayType == 1) // this is the standard yellow lines move with the horizon
    FTImpl.ColorRGB(255,255,0);//set the color to Yellow
    XOffset2 = 15*sin(CurrentRoll+(-1.5708));
    YOffset2 = 15*cos(CurrentRoll+(-1.5708));
    XOffset3 = 45*sin(CurrentRoll+(-1.5708));
    YOffset3 = 45*cos(CurrentRoll+(-1.5708));
    FTImpl.Vertex2ii(240,150,0,0); // center dot
    FTImpl.Vertex2ii(240-XOffset2,150-YOffset2,0,0);
    FTImpl.Vertex2ii(240-XOffset3,150-YOffset3,0,0); // left
    FTImpl.Vertex2ii(240+XOffset2,150+YOffset2,0,0);
    FTImpl.Vertex2ii(240+XOffset3,150+YOffset3,0,0); // right
    else if (CenterDisplayType == 2) // the yellow lines stay straight
    FTImpl.ColorRGB(0,0,0);//set the color to black
    FTImpl.LineWidth(80);
    FTImpl.Vertex2ii(225,150,0,0);
    FTImpl.Vertex2ii(195,150,0,0); // left
    FTImpl.Vertex2ii(255,150,0,0);
    FTImpl.Vertex2ii(285,150,0,0); // left
    FTImpl.Vertex2ii(225,157,0,0); // right
    FTImpl.Vertex2ii(255,157,0,0); // right
    FTImpl.LineWidth(64);
    else // CenterDisplayType == 3 - basically does both
    FTImpl.ColorRGB(255,255,255);//set the color to white
    FTImpl.Vertex2ii(240,140,0,0); // tail
    //20 degree marks
    XOffset1 = 80.5*sin(CurrentRoll+(0.4794));
    YOffset1 = 80.5*cos(CurrentRoll+(0.4794));
    XOffset2 = 80.5*sin(CurrentRoll+(-0.4794));
    YOffset2 = 80.5*cos(CurrentRoll+(-0.4794));
    FTImpl.Vertex2ii(240+XOffset1,150+YOffset1,0,0);
    FTImpl.Vertex2ii(240+XOffset2,150+YOffset2,0,0); // 20 deg down
    FTImpl.Vertex2ii(240-XOffset1,150-YOffset1,0,0);
    FTImpl.Vertex2ii(240-XOffset2,150-YOffset2,0,0); // 20 deg up
    //10 degree marks
    XOffset1 = 51*sin(CurrentRoll+(0.8415));
    YOffset1 = 51*cos(CurrentRoll+(0.84154));
    XOffset2 = 51*sin(CurrentRoll+(-0.8415));
    YOffset2 = 51*cos(CurrentRoll+(-0.8415));
    FTImpl.Vertex2ii(240+XOffset2,150+YOffset2,0,0); // 10 deg down
    FTImpl.Vertex2ii(240-XOffset2,150-YOffset2,0,0); // 10 deg up
    // 5 degree marks. These work out as half the offsetts of the 10, so less math!
    FTImpl.Vertex2ii(240+XOffset1/2,150+YOffset1/2,0,0);
    FTImpl.Vertex2ii(240+XOffset2/2,150+YOffset2/2,0,0); // 20 deg down
    FTImpl.Vertex2ii(240-XOffset1/2,150-YOffset1/2,0,0);
    FTImpl.Vertex2ii(240-XOffset2/2,150-YOffset2/2,0,0); // 20 deg up
    // 15 degree marks
    XOffset1 = 56*sin(CurrentRoll+(0.3272));
    YOffset1 = 56*cos(CurrentRoll+(0.3272));
    XOffset2 = 56*sin(CurrentRoll+(-0.3272));
    YOffset2 = 56*cos(CurrentRoll+(-0.3272));
    // the 20 degree numbers. These will always show up upright.
    XOffset1 = 87.7*sin(CurrentRoll+(-0.6400));
    YOffset1 = 87.7*cos(CurrentRoll+(-0.6400));
    XOffset2 = 87.7*sin(CurrentRoll+(-2.5));
    YOffset2 = 87.7*cos(CurrentRoll+(-2.5));
    FTImpl.Cmd_Number(240-XOffset1, 150-YOffset1, 26, FT_OPT_CENTER, 20);
    FTImpl.Cmd_Number(240-XOffset2, 150-YOffset2, 26, FT_OPT_CENTER, 20);
    // the 10 degree numbers. These will always show up upright.
    XOffset1 = 61.6*sin(CurrentRoll+(-0.9835));
    YOffset1 = 61.6*cos(CurrentRoll+(-0.9835));
    XOffset2 = 61.6*sin(CurrentRoll+(-2.15));
    YOffset2 = 61.6*cos(CurrentRoll+(-2.15));
    FTImpl.Cmd_Number(240-XOffset1, 150-YOffset1, 26, FT_OPT_CENTER, 10);
    FTImpl.Cmd_Number(240-XOffset2, 150-YOffset2, 26, FT_OPT_CENTER, 10);
    // The Arrow...
    XOffset1 = 90*sin(CurrentRoll);
    YOffset1 = 90*cos(CurrentRoll);
    XOffset2 = 107*sin(CurrentRoll);
    YOffset2 = 107*cos(CurrentRoll);
    XOffset3 = XOffset2;
    YOffset3 = YOffset2;
    XOffset1 = 100*sin(CurrentRoll+(-0.040));
    YOffset1 = 100*cos(CurrentRoll+(-0.040));
    XOffset2 = 100*sin(CurrentRoll+( 0.040));
    YOffset2 = 100*cos(CurrentRoll+( 0.040));
    // The Rate of Turn Arrow
    // CurrentRateOfTurn is the rate of turn in Radians/Sec. -(neg) is to the left
    // It must be scaled to indicate rate of turn in 2 minutes, so
    float TwoMinAngle = -1*(CurrentRateOfTurn * 45.7);
    FTImpl.ColorRGB(255,128,0);//set the color to Orange
    if (TwoMinAngle > 0.9) {TwoMinAngle = 0.9;
    FTImpl.ColorRGB(255,0,0);
    else if (TwoMinAngle < -0.9)
    TwoMinAngle = -0.9;
    XOffset1 = 130*sin(TwoMinAngle);
    YOffset1 = 130*cos(TwoMinAngle);
    XOffset2 = 115*sin(TwoMinAngle);
    YOffset2 = 115*cos(TwoMinAngle);
    XOffset1 = 120*sin(TwoMinAngle+(-0.0250));
    YOffset1 = 120*cos(TwoMinAngle+(-0.0250));
    XOffset2 = 120*sin(TwoMinAngle+( 0.0250));
    YOffset2 = 120*cos(TwoMinAngle+( 0.0250));
    //** Overlay the Altitude Strip
    // Print out the Labels, Kohlsman Window, and Units
    FTImpl.Cmd_Text(332, 260, 27, FT_OPT_CENTER, "Altimeter:");
    switch (PressureUnits) { // overlay the Pressure Units. These can change on the fly...
    case 1: {
    if (CurrentPressure > 31.0) CurrentPressure = 31.0;
    if (CurrentPressure < 28.1) CurrentPressure = 28.1;
    FTImpl.Cmd_Text(450, 260, 27, FT_OPT_CENTER, "inHg"); // inHg
    FTImpl.Cmd_Number(397, 260, 27, FT_OPT_CENTER, (int)(CurrentPressure*100)); // Garder 2 chiffres après le nombre
    FTImpl.Vertex2ii(397,266,0,0); FTImpl.Vertex2ii(397,266,0,0);
    break;}
    case 2: {
    if (CurrentPressure > 787.5) CurrentPressure = 787.5;
    if (CurrentPressure < 713.5) CurrentPressure = 713.5;
    FTImpl.Cmd_Text(450, 260, 27, FT_OPT_CENTER, "mmHg"); // mmHg
    FTImpl.Cmd_Number(397, 260, 27, FT_OPT_CENTER, (int)(CurrentPressure*10)); // Garder 1 chiffre après le nombre
    FTImpl.Vertex2ii(407,266,0,0); FTImpl.Vertex2ii(407,266,0,0);
    break; }
    case 3: {
    if (CurrentPressure > 1050.0) CurrentPressure = 1050.0;
    if (CurrentPressure < 951.5) CurrentPressure = 951.5;
    FTImpl.Cmd_Text(450, 260, 27, FT_OPT_CENTER, "hPa"); // hPa
    FTImpl.Cmd_Number(420, 260, 27, FT_OPT_CENTERY | FT_OPT_RIGHTX, (int)(CurrentPressure*10)); // Garder 1 chiffre après le nombre
    FTImpl.Vertex2ii(410,266,0,0);
    break; }}
    // BESOIN DE VÉRIFIER ET DE FIXER LES CAS 2, 3 - RÉGLAGES SUR LES LIAISONS VERTICALES
    //** Overlay the VSI Strip
    FTImpl.BlendFunc(FT_SRC_ALPHA,FT_ONE); // set for a blend instead of a paint
    FTImpl.ColorRGB(15,15,15); //set the color to a slightly lighter hue
    FTImpl.Vertex2ii(429, 60);
    FTImpl.Vertex2ii(480,240);
    FTImpl.BlendFunc(FT_SRC_ALPHA, FT_ONE_MINUS_SRC_ALPHA); // set back to paint
    FTImpl.Vertex2ii(435,230,0,0);
    FTImpl.Vertex2ii(435,70,0,0);
    boolean ticker = true;
    for (int tics = 0; tics < 9; tics ++)
    FTImpl.Vertex2ii(433,70+(tics*20),0,0);
    FTImpl.Vertex2ii(439,70+(tics*20),0,0);
    if (ticker)FTImpl.Cmd_Number(442, 62+(tics*20), 26, 0, abs(MaxVertSpeed-(tics*MaxVertSpeed/4)));
    ticker = !ticker;
    // now the value of CurrentRateOfClimb in a nice little box
    TicMap = map(CurrentRateOfClimb, MaxVertSpeed*-1, MaxVertSpeed, 230, 70); // maps into display units
    FTImpl.Vertex2ii(435, TicMap);
    FTImpl.Vertex2ii(445,TicMap);
    FTImpl.ColorRGB(128,128,128);//set the color to Grey
    FTImpl.Vertex2ii(442, TicMap+9);
    FTImpl.Vertex2ii(480,TicMap-9);
    FTImpl.Vertex2ii(444, TicMap+7);
    FTImpl.Vertex2ii(480,TicMap-7);
    if ((CurrentRateOfClimb < 0) and (CurrentRateOfClimb > -1000)) // include the sign only for less than 1000 in the negative scale
    FTImpl.Cmd_Number(462, TicMap, 26, FT_OPT_CENTER | FT_OPT_SIGNED, (CurrentRateOfClimb));
    else FTImpl.Cmd_Number(462, TicMap, 26, FT_OPT_CENTER | FT_OPT_SIGNED, abs(CurrentRateOfClimb));
    switch (AltUnits) { // overlay the Speed Units. These can change on the fly...
    case 1: FTImpl.Cmd_Text(440, 43, 27, FT_OPT_CENTER, "ft, ft/s"); break;
    case 2: FTImpl.Cmd_Text(440, 43, 27, FT_OPT_CENTER, "m, m/s"); break; }
    //** Overlay the Altimeter.
    FTImpl.Vertex2ii(365,38,0,0);
    FTImpl.Vertex2ii(365,238,0,0); // this is a 200 pixel long line, with a 2000 foot range, so we will get 10 feet per pixel...
    //now lay out the tics
    int Nearestth = 500*(round(CurrentAltitude/500)); //This finds the nearest 500 unit mark.
    int altoffset = (CurrentAltitude - Nearestth)/10; // this is in pixel units
    int bottomshow = -1; int topshow = 3;
    if (altoffset < -12) {topshow = 2; bottomshow = -2;};
    for (int i = bottomshow; i < topshow; i++) //higher number shows on top
    FTImpl.Vertex2ii(362,150+altoffset-(50*i),0,0);
    FTImpl.Vertex2ii(367,150+altoffset-(50*i),0,0); // 10 tics
    FTImpl.Cmd_Number(368, 150+altoffset-(50*i), 26, FT_OPT_CENTERY | FT_OPT_SIGNED, ((Nearestth)+(i*500)));
    FTImpl.Vertex2ii(362,150,0,0);
    FTImpl.Vertex2ii(380,150,0,0); // black tic
    FTImpl.Vertex2ii(362,151,0,0);
    FTImpl.Vertex2ii(380,151,0,0); // black tic
    FTImpl.Vertex2ii(376,142,0,0);
    FTImpl.Vertex2ii(408,159,0,0); // first the box for the hundreds and up
    FTImpl.Vertex2ii(409,107,0,0);
    FTImpl.Vertex2ii(427,194,0,0); // then the box for the cool number slider for the 20's...
    FTImpl.Vertex2ii(411,108,0,0);
    FTImpl.Vertex2ii(427,193,0,0); // then the box THAT DEFINES THE STENCIL ....
    if (CurrentAltitude >= 0)
    FTImpl.ColorRGB(200,200,140); //set the color to Creamy White
    int twenties = (CurrentAltitude - (100 * (int)(CurrentAltitude/100)))/20; // everything but the last 2 digits off/then divide by 20. the fact that it is an int does the rest
    int teens = (CurrentAltitude - (100 * (int)(CurrentAltitude/100))); // everything but the last two digits are gone.
    while (abs(teens) >= 20) teens = teens - 20; //Should knock us down to the number of feet less then 20. THis will be the numerical offset for the scroll
    FTImpl.StencilFunc(FT_GREATER, 0, 255); //only operate on the stencil we just set up
    for (int i = -1; i < 7; i++) // we are going to "print" 9 numbers onto the stencil
    FTImpl.Cmd_Number(414, 190-(i*20)+(teens), 26, FT_OPT_CENTER | FT_OPT_SIGNED, 260+((i+twenties)*20)); // print the 20's, adjusted for height and for number
    FTImpl.ColorRGB(255,255,255); // white me up
    // now we do the other numbers as slow flipping sliders
    // start with the hundreds. This will be the one to determine how all the numbers flip IF they do flip, so twentieths only need be calculated once.
    int twentieths = 0; int tenthousands = 0; int thousands = 0; int hundreds = 0; int hundredsdigit = 0; int thousandsdigit = 0; int tenthousandsdigit = 0;
    int Destructor = abs(CurrentAltitude); // we are going to take this sucker apart. get rid of the minus sign if needed
    if (Destructor >= 10000) {tenthousandsdigit = Destructor/10000; Destructor = Destructor - (tenthousandsdigit * 10000);} // int gets rid of any extra. then we trim
    if (Destructor >= 1000) {thousandsdigit = Destructor/1000; Destructor = Destructor - (thousandsdigit * 1000);} // int gets rid of any extra. then we trim
    if (Destructor >= 100) hundredsdigit = Destructor/100; // int gets rid of any extra. no need to trim, as we dont care
    Destructor = abs(CurrentAltitude); // reset the sucker. get rid of the minu sign if needed
    tenthousands = Destructor - tenthousandsdigit*10000; Destructor = tenthousands;
    thousands = Destructor - thousandsdigit*1000; Destructor = thousands;
    hundreds = Destructor - hundredsdigit*100; // and I no longer give a rip about Destructor!
    int topdigit = -1; int bottomdigit = -1;
    if (abs(CurrentAltitude) > 80) // we have to put numbers in the left box
    // we will start out with the hunderedsdigit
    if (hundreds > 82) // we are flipping to the higher number
    twentieths = hundreds - 82;
    topdigit = hundredsdigit + 1;
    bottomdigit = hundredsdigit;
    if (CurrentAltitude < 100) bottomdigit = -1;
    //if ((CurrentAltitude > 1050) and (topdigit == 10)) topdigit = 0;
    FlipNum(409, 143, topdigit, bottomdigit, 20-twentieths);
    } // 0-10 as we approach the number
    { FTImpl.Cmd_Number(400, 141, 27, 0, hundredsdigit); }; // we get to just print it out.
    // now we do the thousands digit
    if (abs(CurrentAltitude) > 982) // we have to put numbers in the left box
    if (thousands > 982) // we are flipping to the higher number
    topdigit = thousandsdigit + 1;
    bottomdigit = thousandsdigit;
    if (CurrentAltitude < 1000) bottomdigit = -1;
    if ((CurrentAltitude > 9900) and (bottomdigit == 9)) topdigit = 10;
    FlipNum(400, 143, topdigit, bottomdigit, 20-twentieths);
    { FTImpl.Cmd_Number(391, 141, 27, 0, thousandsdigit); }; // we get to just print it out.
    // now we do the ten thousands digit
    if (abs(CurrentAltitude) > 9982) // we have to put numbers in the left box
    if (tenthousands > 9982) // we are flipping to the higher number
    topdigit = tenthousandsdigit + 1;
    bottomdigit = tenthousandsdigit;
    if (bottomdigit == 0) bottomdigit = -1;
    if (topdigit == 0) topdigit = -1;
    FlipNum(391, 143, topdigit, bottomdigit, 20-twentieths);
    { FTImpl.Cmd_Number(382, 141, 27, 0, tenthousandsdigit); }; // we get to just print it out.
    else // CurrentAltitude est negative !
    FTImpl.Cmd_Text(386, 144, 27, FT_OPT_CENTER , "_");
    int twenties = 20 - (CurrentAltitude - (100 * (int)(CurrentAltitude/100)))/20; // everything but the last 2 digits off/then divide by 20. the fact that it is an int does the rest
    int teens = -1 * (CurrentAltitude - (100 * (int)(CurrentAltitude/100))); // everything but the last two digits are gone.
    for (int i = -4; i < 3; i++) // we are going to "print" 7 numbers onto the stencil
    FTImpl.Cmd_Number(414, 190+(i*20)-(teens), 26, FT_OPT_CENTER | FT_OPT_SIGNED, 240+((i+twenties)*20)); // print the 20's, adjusted for height and for number
    if (CurrentAltitude < -80) // we have to put numbers in the left box
    if (hundreds > 80) // we are flipping to the higher number
    twentieths = (-1*hundreds) + 80;
    topdigit = hundredsdigit;
    bottomdigit = hundredsdigit + 1;
    if (CurrentAltitude > -100) topdigit = -1;
    FlipNum(409, 143, topdigit, bottomdigit, (-1*twentieths)+1);
    if (CurrentAltitude < -980) // we have to put numbers in the left box
    if (thousands > 980) // we are flipping to the higher number
    topdigit = thousandsdigit;
    bottomdigit = thousandsdigit + 1;
    if (CurrentAltitude > -1000) topdigit = -1;
    FlipNum(400, 143, topdigit, bottomdigit, (-1*twentieths)+1);
    // there is no tenthousands digit in the negative range...
    //** Overlay the Control Knob Functions
    // trim gyro buttons
    FTImpl.Cmd_Text(201, 260, 27, FT_OPT_CENTER, "Compass Roll Pitch");
    // Sensor Error Flag
    if (SensorError)
    FTImpl.ColorRGB(200,0,0);//set the color to RED because we have a sensor error.
    FTImpl.ColorRGB(170,170,170);//set the color to grey becuase our last sensor read was successful.
    FTImpl.Cmd_Text(455, 12, 18, FT_OPT_CENTER, "Snsr");
    FTImpl.Cmd_Text(455, 25, 18, FT_OPT_CENTER, "Err");
    //** DRAW THIS LAST - The Menu items on the bottom of the screen.
    if (Menu == 1)
    FTImpl.ColorRGB(210,180,40);
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // brightness box color
    FTImpl.Begin(FT_LINE_STRIP); // *
    FTImpl.Vertex2ii(3,250,0,0);
    FTImpl.Vertex2ii(27,250,0,0);
    FTImpl.Vertex2ii(27,269,0,0);
    FTImpl.Vertex2ii(3,269,0,0);
    if (Menu == 2)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // speedunits box color
    FTImpl.Begin(FT_LINE_STRIP); // BUG
    FTImpl.Vertex2ii(31,250,0,0);
    FTImpl.Vertex2ii(108,250,0,0);
    FTImpl.Vertex2ii(108,269,0,0);
    FTImpl.Vertex2ii(31,269,0,0);
    if (Menu == 3)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // bug box color
    FTImpl.Begin(FT_LINE_STRIP); // Compass
    FTImpl.Vertex2ii(112,250,0,0);
    FTImpl.Vertex2ii(196,250,0,0);
    FTImpl.Vertex2ii(196,269,0,0);
    FTImpl.Vertex2ii(112,269,0,0);
    if (Menu == 4)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // trim box color
    FTImpl.Begin(FT_LINE_STRIP); // Roll - where I was working
    FTImpl.Vertex2ii(200,250,0,0);
    FTImpl.Vertex2ii(238,250,0,0);
    FTImpl.Vertex2ii(238,269,0,0);
    FTImpl.Vertex2ii(200,269,0,0);
    if (Menu == 5)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // altimeter setting box color
    FTImpl.Vertex2ii(242,250,0,0);
    FTImpl.Vertex2ii(291,250,0,0);
    FTImpl.Vertex2ii(291,269,0,0);
    FTImpl.Vertex2ii(242,269,0,0);
    if (Menu == 6)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // pressure units box color
    FTImpl.Vertex2ii(423,250,0,0);
    FTImpl.Vertex2ii(295,250,0,0);
    FTImpl.Vertex2ii(295,269,0,0);
    FTImpl.Vertex2ii(423,269,0,0);
    if (Menu == 7)
    if (MenuSelected)
    FTImpl.ColorRGB(180,120,30); // altitude units box color
    FTImpl.Vertex2ii(427,250,0,0);
    FTImpl.Vertex2ii(475,250,0,0);
    FTImpl.Vertex2ii(475,269,0,0);
    FTImpl.Vertex2ii(427,269,0,0);
    // ****************************** End My Routine *******************************
    FTImpl.DLEnd();//end the display list
    FTImpl.Finish();//render the display list and wait for the completion of the DL
    void Calibrate_AHRS() // A la mise sous tension, le bouton a été enfoncé.
    boolean LiftButton = false;
    boolean PressButton = false;
    boolean DoZero = false;
    while (!PressButton) // this is the menu we will draw for the calibration screen
    FTImpl.DLStart(); // begin a new drawing list
    FTImpl.Write(REG_PWM_DUTY,map(brightness, 0, 255, 0, 100)); // go maximum brightness
    FTImpl.ClearColorRGB(255,255,255); // set the background color to white
    FTImpl.Clear(1,1,1); // clear the screen
    FTImpl.ColorRGB(0,0,0); //set the color to Black.
    FTImpl.Cmd_Text(240, 24, 28, FT_OPT_CENTER, "Zero the AHRS screen. Do not zero");
    FTImpl.Cmd_Text(240, 46, 28, FT_OPT_CENTER, "the AHRS unless it is in level flight");
    FTImpl.Cmd_Text(240, 68, 28, FT_OPT_CENTER, "attitude and facing 0 degrees due North.");
    FTImpl.Cmd_Text(240, 90, 28, FT_OPT_CENTER, "It may be easier to zero the AHRS when");
    FTImpl.Cmd_Text(240, 112, 28, FT_OPT_CENTER, "it is not mounted in the aircraft. In any");
    FTImpl.Cmd_Text(240, 134, 28, FT_OPT_CENTER, "case, twist the knob to the right several");
    FTImpl.Cmd_Text(240, 156, 28, FT_OPT_CENTER, "times until the ZERO option is selected");
    FTImpl.Cmd_Text(240, 178, 28, FT_OPT_CENTER, "to perform a calibration.");
    FTImpl.Cmd_Text(240, 250, 28, FT_OPT_CENTER, "Exit without saving. Zero AHRS and Save.");
    // and now highlight the choice we have made
    FTImpl.ColorRGB(0,0,0); //set the color to black.
    FTImpl.Begin(FT_LINE_STRIP); // and get ready to draw a box
    if (DoZero)
    { // draw a box around "Zero
    FTImpl.Vertex2ii(232,239,0,0);
    FTImpl.Vertex2ii(460,239,0,0);
    FTImpl.Vertex2ii(460,261,0,0);
    FTImpl.Vertex2ii(232,261,0,0);
    { // draw a box around "Don't Zero
    FTImpl.Vertex2ii(15,239,0);
    FTImpl.Vertex2ii(230,239,0);
    FTImpl.Vertex2ii(230,261,0,0);
    FTImpl.Vertex2ii(15,261,0,0);
    FTImpl.Vertex2ii(15,239,0,0);
    // close out the screen
    if (digitalRead(A15) == HIGH) LiftButton = true; // we won't sense the button press until this is so
    if (((digitalRead(A15) == LOW) and (LiftButton))) PressButton = true; // we have lifted the button and pressed it again
    NewEncoderPosition = myEnc.read(); // read the encoder
    if (OldEncoderPosition - 50 < NewEncoderPosition) DoZero = false; else DoZero = true;
    if (DoZero) // we need to tare the sensor and save the results
    // Tare the Sensor
    Serial2.write(247);// "Start of Packet Byte"
    Serial2.write(96); // "Set Compass Range"
    Serial2.write(96); // "Checksum" of the one byte we just sent.
    // Save the new Zero
    // Serial2.write(247); // "Start of Packet Byte"
    // Serial2.write(105); // "Set Reference Vector Mode"
    // Serial2.write(3); // "Range set to "Single Auto Continual" (2) Other possibilites include "Single Auto" (1) and "Multiple" (3)
    // Serial2.write(107); // "Checksum" - sum of the last two bytes mod 256.
    String AHRS_Version = "N"; // Ceci est utilisé plus tard pour voir si nous sommes connectés à la puce AHRS
    // set up the pins we will need to be using...
    pinMode(A15,INPUT_PULLUP); // A 15 is the select button on the encoder
    pinMode(19, INPUT_PULLUP); // 19 is an interrupt pin, and is used as the encoder quadrature signal A
    pinMode(18, INPUT_PULLUP); // 18 is an interrupt pin, and is used as the encoder quadrature signal B
    // start tracking the encoder knob
    OldEncoderPosition = myEnc.read();
    boolean agree = false;
    boolean Iagree = false;
    // enable the display
    BootupConfigure();
    //SPI.begin();
    // Serial2 is the Remote AHRS sensor.
    Serial2.begin(115200); // begin serial communications with Yost Labs 3-Space Nano AHRS Chip
    // AHRS chip can be made to change speeds, but defaults to 115200. Mode is 8N1 (8 data, no parity, 1 stop) This is the arduino default.
    delay(500); // give a bit of time to ensure everything is good.
    while (Serial2.available()) Serial2.read(); // empty the receive serial port
    // write a "get version" request to the AHRS chip
    Serial2.write(230); // "Get Version"
    Serial2.write(230); // "Checksum" - in this case the exact same as the message, because it only sums the message byte.
    if (!digitalRead(A15)) Calibrate_AHRS(); // this is the calibration routine
    // begin a while loop here that draws the startup screen over and over until you select "I agree"
    while (!Iagree)
    if ((digitalRead(A15) == LOW) and (agree)) Iagree = true;
    // start drawing the startup screen
    FTImpl.ClearColorRGB(0,0,0); // set the background color to black
    FTImpl.ColorRGB(255,255,255); //set the color to white.
    FTImpl.Cmd_Text(240, 24, 28, FT_OPT_CENTER, "TheOpenCockpit Airduino 4.3 version 1.0 Beta");
    FTImpl.Cmd_Text(240, 46, 28, FT_OPT_CENTER, "Power-Up Report and Legal Disclaimer");
    if (!Static.begin()) { // initialize the Static Port // BMP280 setup
    FTImpl.ColorRGB(255,0,0); //set the color to red.
    FTImpl.Cmd_Text(240, 78, 26, FT_OPT_CENTER, "Static Port BMP 280 Sensor ......... NOT FOUND @ 0x77");
    else {
    FTImpl.ColorRGB(255,255,0); //set the color to yellow.
    FTImpl.Cmd_Text(240, 78, 26, FT_OPT_CENTER, "Static Port BMP 280 Sensor ......... FOUND & 0x77");
    if (!Pitot.begin(0x76)) { // initialize the Pitot Port // BMP280 setup
    FTImpl.Cmd_Text(240, 96, 26, FT_OPT_CENTER, "Pitot Port BMP 280 Sensor ......... NOT FOUND @ 0x76");
    else {
    FTImpl.Cmd_Text(240, 96, 26, FT_OPT_CENTER, "Pitot Port BMP 280 Sensor ......... FOUND & 0x76");
    if (Serial2.available() > 11) // it is time to read the AHRS response
    AHRS_Version = "";
    while (Serial2.available()) AHRS_Version = AHRS_Version + Serial2.read();
    if (AHRS_Version == "N") {// we have not heard from the AHRS sensor
    FTImpl.Cmd_Text(240, 118, 26, FT_OPT_CENTER, "Searching for AHRS Sensor on UART2");
    else {
    FTImpl.Cmd_Text(240, 118, 26, FT_OPT_CENTER, "Yost Labs AHRS Sensor .......... FOUND on UART2");
    // Disclaimer
    FTImpl.Cmd_Text(240, 145, 27, FT_OPT_CENTER, "This instrument is experimental in nature, and should");
    FTImpl.Cmd_Text(240, 165, 27, FT_OPT_CENTER, "be used to enhance situational awareness only. Any");
    FTImpl.Cmd_Text(240, 185, 27, FT_OPT_CENTER, "and all use is at the operator's discretion and risk.");
    // choices
    FTImpl.Cmd_Text(240, 217, 27, FT_OPT_CENTER, "I do not agree. I agree.");
    // more info
    FTImpl.Cmd_Text(132, 250, 26, FT_OPT_CENTER, "For more information, please visit");
    FTImpl.ColorRGB(100,100,255); //set the color to light blue.
    FTImpl.Cmd_Text(348, 250, 26, FT_OPT_CENTER, "http://www.etna-soft.com");
    if (agree)
    { // draw a box around "agree"
    FTImpl.Vertex2ii(278,206,0,0);
    FTImpl.Vertex2ii(358,206,0,0);
    FTImpl.Vertex2ii(358,229,0,0);
    FTImpl.Vertex2ii(278,229,0,0);
    { // draw a box around "I do not agree"
    FTImpl.Vertex2ii(120,206,0,0);
    FTImpl.Vertex2ii(252,206,0,0);
    FTImpl.Vertex2ii(252,229,0,0);
    FTImpl.Vertex2ii(120,229,0,0);
    // close out the startup screen
    if (OldEncoderPosition != NewEncoderPosition) // the knob has moved
    if (agree) agree = false; else agree = true; // so we need to change our choice
    OldEncoderPosition = NewEncoderPosition;
    // end the while loop here, so that you cannot move on without selecting "I Agree"
    // now set up the AHRS chip
    // Set Accelerometer range
    Serial2.write(121); // "Set Accelerometer Range"
    Serial2.write(16); // "Range set to +- 4G" Could be 2G (0) 4G (16) and 8G (32)
    Serial2.write(137); // "Checksum" - sum of the last two bytes mod 256.
    // Set Gyroscope range
    Serial2.write(125); // "Set Gyroscope Range"
    Serial2.write(1); // "Range set to +- 500dps" Could also be 250 (0) and 2000 (2)
    Serial2.write(126); // "Checksum" - sum of the last two bytes mod 256.
    // Set Compass range
    Serial2.write(126); // "Set Compass Range"
    Serial2.write(1); // "Range set to +- 1.33Ga" Could also be +-.88 Ga (0) and many more
    Serial2.write(127); // "Checksum" - sum of the last two bytes mod 256.
    // Set Reference Vector Mode
    // setup variables from defined values so that this doesn't have to be done over and over again
    BotWhA = map(WAStart, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    TopWhA = map(WAEnd, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    BotGA = map(GAStart, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    TopGA = map(GAEnd, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    RL = map(RLine, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    BL = map(BLine, 0,MaxSpeed, 0, 195); // 195 is the number of pixels it displays
    case 1: PressureDigits[0] = 2; PressureDigits[1] = 9; PressureDigits[2] = 9; PressureDigits[3] = 2; break; // inHg
    case 2: PressureDigits[0] = 7; PressureDigits[1] = 6; PressureDigits[2] = 0; PressureDigits[3] = 0; break; // mmHg
    case 3: PressureDigits[0] = 1; PressureDigits[1] = 0; PressureDigits[2] = 1; PressureDigits[3] = 8; break; } // hPa
    NumTics = MaxSpeed/SpeedTics; // This is how many tics we will need
    HalfSpeedTics = (map(SpeedTics,0,MaxSpeed,0,195)/2); // 195 is the number of pixels it displays
    CurrentSpeed = 84;
    CurrentRoll = -0.5236; // Radians. 30 degrees to the left
    CurrentPitch = -0.17453/2; // Radians. 10 degrees up
    } // Fin setup()
    // Calcul Altitude
    PreviousAltitude = CurrentAltitude;
    float AltCallUnits = CurrentPressure;
    if (PressureUnits == 1) AltCallUnits = CurrentPressure * 25.4 * 1.3332; // inHg à mmHg à hPa
    if (PressureUnits == 2) AltCallUnits = CurrentPressure * 1.3332; // mmHg à hPa
    if (AltUnits == 1)CurrentAltitude = (3.28*Static.readAltitude(AltCallUnits+StaticCalib rationOffset)); // Pression en hPa et Altitude en Ft
    CurrentAltitude = (Static.readAltitude(AltCallUnits+StaticCalibratio nOffset)); // Pression hPa et Altitude en metres
    // Calcul Airspeed
    float CalcSpeed = 0;
    switch(SpeedUnits) { // Choisir les unités pour avoir KTS, m/h ou Km/h
    // case 1: CalcSpeed = (59.2484 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset * 1.15); break; // kts/hr
    // case 2: CalcSpeed = (68.1818 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset); break; // m/h
    // case 3: CalcSpeed = (109.7280 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset * 0.62); break; } // km/h
    case 1: CalcSpeed = (0.592484 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset * 1.15); break; // kts/hr
    case 2: CalcSpeed = (0.681818 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset); break; // m/h
    case 3: CalcSpeed = (1.097280 * sqrt(122.45*(Pitot.readPressure() - Static.readPressure()))) + (AirspeedCalibrationOffset * 0.62); break; } // km/h
    CurrentSpeed = CalcSpeed;
    // handle the input encoder section. This is activated by raising the button.
    EncMove = (OldEncoderPosition - NewEncoderPosition)/ECPD;
    if (ButtonDown and digitalRead(A15)) ButtonReleased = true;
    ButtonDown = !digitalRead(A15);
    if (ButtonReleased and !MenuSelected) { MenuSelected = true; ButtonReleased = false; }
    int oldunits;
    if (MenuSelected) // we are in a menu, and need to handle it
    if (ButtonReleased) // anything that happens when we leave a menu needs to happen now
    MenuSelected = false; // this has to happen
    switch(Menu) {
    case 1: // brightness
    if (ButtonDown) EncMult = 25; else EncMult = 3; // higher speed if you hold down the button
    brightness = brightness + (EncMove * EncMult);
    if (brightness > 255) brightness = 255;
    if (brightness < 6) brightness = 6; //don't want to be so low that you cant see to brighten it back up
    case 2: // bug
    if (ButtonDown) EncMult = 10; else EncMult = 1; // higher speed if you hold down the button
    HeadingBug = HeadingBug + (EncMove * EncMult);
    if (HeadingBug > 360) HeadingBug = HeadingBug - 360;
    if (HeadingBug < 0) HeadingBug = HeadingBug + 360; // corresponds to degrees. Wraps around the 360 point
    case 3: // compass
    CompassOffset = CompassOffset + (EncMove * EncMult * 0.5); // 0.5 is a half degree in degrees ;-)
    case 4: // Roll
    RollOffset = RollOffset + (EncMove * EncMult * 0.00872); // 0.00872 is a half degree in Radians
    case 5: // Pitch
    PitchOffset = PitchOffset + (EncMove * EncMult * 0.00872); // 0.00872 is a half degree in Radians
    case 6: // altimeter
    case 1: CurrentPressure = CurrentPressure + ((float)(EncMove * EncMult)/100); break; // inHg
    case 2: CurrentPressure = CurrentPressure + ((float)(EncMove * EncMult)/10); break; // mmHg
    case 3: CurrentPressure = CurrentPressure + ((float)(EncMove * EncMult)/10); break; } // hPa
    case 7: // altimeter units
    if (EncMove != 0) // we gonna covert us some units
    if (EncMove > 0) // we are going up
    if (PressureUnits == 1) CurrentPressure = CurrentPressure * 25.4; // Converting inHg to mmHg
    if (PressureUnits == 2) CurrentPressure = CurrentPressure * 1.3332; // Converting mmHg to hPa
    } // note - not conversion necessary for 3 becuase we have no other units
    else // we are going down
    { // and again, we aren't going down farther if we are at 1...
    if (PressureUnits == 2) CurrentPressure = CurrentPressure / 25.4; // Converting mmHg to inHg
    if (PressureUnits == 3) CurrentPressure = CurrentPressure / 1.3332; // Converting hPa to mmHg
    PressureUnits = PressureUnits + EncMove;
    if (PressureUnits > 3) PressureUnits = 3;
    if (PressureUnits < 1) PressureUnits = 1; // corresponds to altimeter units. no wrap
    break; } // and close the switch
    if (ButtonDown and ButtonReleased) {MenuSelected = false; } // you just moved out of whatever menu you are in
    else // we are not in a menu, and the encoder has turned to switch between menus
    Menu = Menu + EncMove;
    if (Menu > 7) Menu = 7;
    if (Menu < 1) Menu = 1;
    OldEncoderPosition = NewEncoderPosition; // Fin de la routine du menu
    PreviousHeading = CurrentHeading;
    // Gérer maintenant le calcul du temps qui nous permet de calculer le taux de virage TC et VSI
    previousMicros = currentMicros;
    currentMicros = micros();
    intervalMicros = currentMicros - previousMicros;
    // ROUTINE STILL NEEDS CALIBRATED AND SMOOTHED.
    // ROUTINE DES DONNEES COURANTES QUI ONT BESOIN TOUJOURS D'ETRE CALIBRES ET LISSES.
    // Je pense que j'ai aussi besoin d'une horloge plus précise.
    // Il peut également être nécessaire d'étudier le réglage des modes de puce BNO055.
    CurrentRateOfTurn = 500*(float)(CurrentHeading - PreviousHeading)/(intervalMicros);
    // Lecture des angles Euler du paquet d'octets du AHRS
    { // Nous avons un paquet d'octets, proceder au decodage
    //Serial2.read(); N'est plus nécessaire
    CP.binary[3] = Serial2.read(); CP.binary[2] = Serial2.read(); CP.binary[1] = Serial2.read(); CP.binary[0] = Serial2.read(); // Va aller dans CurrentHeading
    CH.binary[3] = Serial2.read(); CH.binary[2] = Serial2.read(); CH.binary[1] = Serial2.read(); CH.binary[0] = Serial2.read(); // Va aller dans CurrentPitch
    CR.binary[3] = Serial2.read(); CR.binary[2] = Serial2.read(); CR.binary[1] = Serial2.read(); CR.binary[0] = Serial2.read(); // Va aller dans CurrentRoll
    // CalibrationStatus = Serial2.read(); N'est plus disponible
    CurrentHeading = CH.floatingPoint * 57.2958 + CompassOffset; // Note: HDG est en degrés, Pitch et Roll en radians.
    CurrentPitch = CP.floatingPoint + PitchOffset; //- (0.008726 * 26.0); // Pitch en radians.
    CurrentRoll = -1*CR.floatingPoint + RollOffset; //+ (0.008726 * 4.5); // Roll en radians.
    if (CurrentHeading > 360) CurrentHeading = CurrentHeading - 360; // Correction pour toutes les valeurs hors limites.
    if (CurrentHeading <= 0) CurrentHeading = CurrentHeading + 360; // Correction pour toutes les valeurs hors limites.
    SensorError = false; // Nous avons pu faire une lecture
    ErrorStreak = 0; // et cela met fin à toute "séquence" de mauvaises lectures ...
    SensorError = true; // Nous avons donc échoué à lire le capteur
    ErrorStreak = ErrorStreak + 1; // et prolongé toute séquence d'échecs qui pourrait se produire
    if (ErrorStreak > 25) ErrorStreak = 25; // Cela indique à l'écran de se déconnecter en cas d'erreur de capteur à long terme
    // Section de correction et de demande de données série - Communication avec la puce AHRS
    while (Serial2.available()) Serial2.read(); // Vider toutes les erreurs de réception du port série. Cela doit être fait afin de restaurer les communications perdues.
    Serial2.write(247); // Start of Packet Byte
    Serial2.write(1); // Command Byte - "Read Filtered, Tared Orientation data in Euler Angle Format"
    Serial2.write(1); // Checksum Byte - in this case the exact same as the message, because it only sums the message byte.
    // Mise à jour l'écran
    DrawScreen();
    } // Fin loop()
    Germany NRW
    6,924
    Better to ask in a forum that supports the Arduno Mega.
    Here is not the right place.
    Mar 2020
    2
    I'm sorry you have raison
    Germany NRW
    6,924
    Maybe look here for Arduino Mega support: https://forum.arduino.cc/
    This forum is for PJRC Products - "Teensy" boards.
