Results 1 to 6 of 6
Thread: SD Card filename struggles
    Mar 2020
    2
    Hi All,
    First time posting on here, just reached my boiling point and need some assistance. I'm using a Teensy 3.6, with built in SD card, trying to create a filename that simply appends the datestamp to the filename, and appends also ".csv". As I'm looking to create a file titled "DataLog20200318.csv" and of course based on a trigger develop a few different data log file with unique timestamps. My code works fine when providing
    File dataFile = SD.open("datalog.csv", FILE_WRITE);
    However, getting so extremely fancy as to...
      char fname[] = "DataLog";
      char tmstmp[21];
      sprintf(tmstmp,"%d%02d%02d%02\0",year(),month(),day());
      char fext[] = ".csv";
      strcat(filename, fname);
      strcat(filename, tmstmp);
      strcat(filename, fext);
    If I simply substitue SD.open("datalog.csv", FILE_WRITE); ...with this... SD.open(filename, FILE_WRITE); it compiles but does not ever create nor find my file. I even tried \" thinking the SD library needed quotes around it as a complete character string to parse into the characters.
    I guess I don't understand the road block I'm running into... Am I overlooking some simply character array size or what is it?
    Here is the demo code I tried from the Data Logging demo that works until I change from a static text to the filename variable:
    // On the Ethernet Shield, CS is pin 4. Note that even if it's not
    // used as the CS pin, the hardware CS pin (10 on most Arduino boards,
    // 53 on the Mega) must be left as an output or the SD library
    // functions will not work.
    // change this to match your SD shield or module;
    // Arduino Ethernet shield: pin 4
    // Adafruit SD shields and modules: pin 10
    // Sparkfun SD shield: pin 8
    // Teensy audio board: pin 10
    // Teensy 3.5 & 3.6 on-board: BUILTIN_SDCARD
    // Wiz820+SD board: pin 4
    // Teensy 2.0: pin 0
    // Teensy++ 2.0: pin 20
    const int chipSelect = BUILTIN_SDCARD;
    char filename[26]= "";
    void setup() // ************************* SETUP *************************
       while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      Serial.println("Initializing SD card...");
    // establish the file name with timestamp and extension
      char tmstmp[] = "20200318";
      Serial.println(filename);
      // see if the card is present and can be initialized:
      if (!SD.begin(chipSelect)) {
        Serial.println("Card failed, or not present");
        // don't do anything more:
        return;
      Serial.println("card initialized.");
      // make a string for assembling the data to log:
      String dataString = "";
      // read three sensors and append to the string:
      for (int analogPin = 0; analogPin < 3; analogPin++) {
        int sensor = analogRead(analogPin);
        dataString += String(sensor);
        if (analogPin < 2) {
          dataString += ",";
      // open the file. note that only one file can be open at a time,
      // so you have to close this one before opening another.
      File dataFile = SD.open(filename, FILE_WRITE);
      // if the file is available, write to it:
      if (dataFile) {
        dataFile.println(dataString);
        dataFile.close();
        // print to the serial port too:
        Serial.println(dataString);
      // if the file isn't open, pop up an error:
      else {
        Serial.println("error opening datalog.txt");
    Thanks, your frustrated programmer
    10,935
    File names are 8.3 limited and :: "DataLog20200318.csv" is beyond that.
    Perhaps try more like : "DL200318.csv" or ""20200318.csv""
    10,935
    Confirmed commenting this line works: // strcat(filename, fname);
    This also works:
      char fname[] = "DL";
      strcat(filename, &tmstmp[2]);
    Another thing added to loop() to stop logging and safely remove the SD card - just use SerMon to send any character(s):
      if ( Serial.available()) {
      	while(1);
    Mar 2020
    2
    This also works:
      	while(1);
    Much appreciation defragster, the above worked and was able to construct a dynamic tmstmp as well. Next I'm going to tackle altering the library to increase the character allowance.
    Thanks again for the help in such a quick reply!!!
    10,935
    Quote Originally Posted by CP406 View Post
    Glad it worked there.
    I'd suggest it would be better to create subdirectories and leave the 8.3 naming alone. The 8.3 is deeply embedded and a reasonable restriction as the larger that get the fewer DIR entries fit into a block, so more paging.
    Also the root dir is typically 'special' and getting it full is unproductive as well.
    Would be better to have perhaps year_month directories with daily files in each - or something in that direction. If the files are pulled off the SD card they could be renamed at that time as needed.
    Dec 2013
    266
    @CP406
    Use SdFat-beta library, 255 character limit.
