Results 1 to 5 of 5
Thread: Wave file playback from internal SD card on Teensy 3.5
    I am on a project which needs to read a wav file from the internal SD reader of a Teensy 3.5, without the audio shield, directly on the DAC of the card, connected to a small amplifier PAM8403.
    Everything works fine if I use a waveform for example or any synth module.
    However, I cannot read a wav file from the sd card.
    I managed to read and write a text file, so I have no hardware problem.
    In the code, if I uncomment the part which tests if the card is ready (if(!(SD.begin(SDCARD_CS_PIN))...) , I have the error "BUILTIN_SDCARD was not declared in this scope".
    And of course, if I leave it in a comment, the code runs but the test file is not played.
    Any help would be welcome.
    Thanks in advance.
    AudioPlaySdWav playWav1;
    AudioOutputAnalogStereo  dacs1;
    AudioConnection patchCord1(playWav1, 0, dacs1, 0);
    AudioConnection patchCord2(playWav1, 1, dacs1, 1);
    #define SDCARD_CS_PIN BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN 11
    #define SDCARD_SCK_PIN 13
    Serial.begin(9600); AudioMemory(8); SPI.setMOSI(SDCARD_MOSI_PIN); SPI.setSCK(SDCARD_SCK_PIN); // if (!(SD.begin(SDCARD_CS_PIN))) { // while (1) { // Serial.println("Unable to access the SD card"); // delay(500); // } // } Serial.println("Playing..."); playWav1.play("TEST.WAV"); delay(5); while (playWav1.isPlaying()) { } Serial.println("Finish");
    } void loop() { }
    I finally forced the use of the SD library located in "hardware \ teensy \ avr \ libraries \ SD" (I deleted the one located in "Arduino \ libraries")
    I no longer have an error but unfortunately the wav file is still not playing ...
    Ok, that was definitely a library problem. I re-download the SD library from GitHub and finally everything works as I want.
    10,979
    ** cross posted while I played ... indeed the Teensy SD.h should work without error or having to delete any Arduino library
    I just altered and tested with Audio card and it won't play until this works :: if (!(SD.begin(SDCARD_CS_PIN))) {
    And with :: #define SDCARD_CS_PIN BUILTIN_SDCARD
    these lines are not needed as BUILTIN uses other dedicated SDIO pins::
    Thanks defragster, I modified my code as you suggest...
    Every thing works fine now, I can continue my project...
